Garden Hose for Gasoline Transfer?
by viscous - 07/05/20 11:55 PM
Changing coolant-water ratio of 50-50 premix?
by TrustyAutos - 07/05/20 11:27 PM
ring terminals - really?
by DirtyOilGuy - 07/05/20 11:27 PM
Which oil is better out of these
by Bazza32 - 07/05/20 11:08 PM
Automatic transmission shift feel
by Spetz - 07/05/20 10:51 PM
Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
41 registered members (Baddog, advocate, Bailes1992, awguy, A_Spruce, 4 invisible), 1,072 guests, and 21 spiders.
Topics307,468
Posts5,311,703
Members71,852
2017 Nissan Titan SV 5.6 #5439815 05/26/20 11:30 PM
T
ThrowinRocks Offline OP
T
Just purchased this 2017 Nissan Titan SV used but no way of finding what oil was used.
What's the most popular brand used in these 5.6 Liter engines?
Thanks
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5439827 05/26/20 11:59 PM
dave1251 Offline
don't use.
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5439888 05/27/20 06:11 AM
F
farrarfan1 Offline
F
Without polling thousands of Titan owners how would anyone know this?
2020 Ram 1500 Laramie 5.7L Hemi- Ivory White Tri-Coat Pearl
2019 Cherokee Limited 2.0L Turbo- Velvet Red Pearl
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5439890 05/27/20 06:15 AM
supton Offline
A number of posters here change oil brand on every change, and suffer no ill consequences. So I'm not sure I'd sweat over what other posters have used. Pick your favorite brand and go from there.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5439894 05/27/20 06:24 AM
Astro14 Offline
Switching brands causes no harm. I wouldn’t sweat the previous oil used in this truck, just pick what you like and go with that.
I once posted a thread (tongue in cheek) about using cheap oil, and changing brands all the time...take a look at that engine when it had 90K+ miles and see how it fared.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/2633310/1
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5439895 05/27/20 06:25 AM
V
Vladiator Offline
V
Don't know how different the 2017 5.6L is from 2005-ish 5.6L, but I know in early days of Titan some owners had occasional timing chain issues, similar to VQ v6 engines, and 40-grade motor oils were the saving grace. So I'd use 0w40/5w40 synthetic oil. Mobil1 0w40 and Delo XSP 5w40 are some good ones.
0W20 in summer at Death Valley is as good as 25w70 in winter at Alaska. Both can be done, neither is good for the engine long term. Oil grade is chosen by CLIMATE and OPERATING CONDITIONS.
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5439922 05/27/20 07:27 AM
A
ARCOgraphite Offline
A
Popular does not equal good.
Maybe passable, which mean you car will be passable since it has ho-hum oil in it.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5439951 05/27/20 08:04 AM
T
thastinger Offline
T
Thanks
The wife has a 14 armada with the 5.6
Long story short is that after several different UOA, the motor seems to "like" Mobil 1 Euro 0-40 better than the 5-30s
I use the mobil 110 filter on it
Re: 2017 Nissan Titan SV 5.6 [Re: thastinger] #5439968 05/27/20 08:35 AM
A
A
Thanks
Sounds like a good combination!
thumbsup
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5439979 05/27/20 08:54 AM
J
Jimzz Offline
J
I just ran what ever 5w30 Syn I had when I owned a Titan.
I did run the longer Honda sized filter instead of the small nissan filter.
yup
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5439985 05/27/20 09:03 AM
A
A
NISSAN filter = Proven Garbage on this forum.
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5440038 05/27/20 10:24 AM
U
UncleDave Offline
U
Thanks
Most popular - couldn't tell you. Titan talk can probably help you there.
What I can tell you is this gem of an engine shears oil like a puppy going after the Sunday paper.
Under towing loads it will shear almost anything a full grade down in 7500 miles.
Since 04 I've run everything from 20 for short 3K OCI's to 50 in it, and it's had a very hard life of towing and hauling.
It got fed mostly 0W-40, but Its quietest and "sounds" most happy with 5w-30 Mobil 1 EP.
My advice with any DOHC chain driven engine is to run the very best filter you can get and magnets to keep as many particles as you possibly can out of the chain once it wears past the tensioners range you've got a real job on your hands.
Ive run a Fram ultra XG7317 and magnets on the cans since very early on.
My "ancient" 04 titan crossed 100K just a month or so ago and I have no intention of getting rid if it.
The new NA gas trucks aren't better enough to force my hand and the titan with a tow rear end will still put lots of brand new half tons on the trailer 15 years after its introduction.
Congrats - enjoy.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5440056 05/27/20 10:49 AM
F
Fattylocks Offline
F
Thanks
Enjoy your new truck. I love my '11 king cab with the tow package.
At the moment I run Castrol magnatec 5-30 in it, quiet, no tics or tocs. Wix filter that's a bit longer than the stock Nissan.
94 Caprice Wagon Daily driver sold
05 Focus Wagon 2.0 Duratech city car sold
05 Mustang GT Convertible sold
05 P71 ex Homeland Security
12 Ford Explorer XLT Base
11 Nissan Titan SV King cab 4x4
Re: 2017 Nissan Titan SV 5.6 [Re: ThrowinRocks] #5440071 05/27/20 11:16 AM
AZjeff Offline
This truck calls for 0W-20. You'll get owner opinions here: TITAN TALK
FWIW I've been using Quaker State 0W-20 in my '18 with no apparent issues. Not sure it matters what the previous owner was running.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 2017 Nissan Titan SV 5.6 [Re: AZjeff] #5440097 05/27/20 11:50 AM
U
UncleDave Offline
U
Yup- Its also interesting to note:
That exact same engine called for 5-W30 from 04 to I think 2017.
The OCI now calls for 5K Max vs the 7500 the 5-30 allowed, I believe this is due to the shearing I mentioned earlier.
UD
Uncle Dave
