FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
27 registered members (ArrestMeRedZ, Brad1119, blufeb95, CleverUserName, BLND1, 4 invisible), 902 guests, and 39 spiders.
Topics307,396
Posts5,310,319
Members71,843
Downshift before WOT? #5439672 05/26/20 08:01 PM
A
Avery4 Offline OP
A
Hello everyone, I am wondering if it is better on an automatic transmission to manually downshift it to a lower gear before flooring it so it isn't downshifting under heavy load. For example, of I am going 50 and I decide to floor it, is it best to floor it and let the ECU downshift it to 2nd gear automatically or is it it best to manually downshift it to 2nd gear and then floor it? I would think it would be best to downshift to the appropriate gear before flooring it, it would seem that downshifting under full throttle would cause significantly more wear on the clutches than downshifting it under a light load before flooring it. Thanks in advance!
Re: Downshift before WOT? [Re: Avery4] #5439677 05/26/20 08:05 PM
F
fsdork Offline
F
I find the manual downshift function of most automatic transmissions to be fairly jarring. I imagine the exception would be something with a sport shift/flappy paddle setup. I will usually find the sweet spot in the accelerator travel that causes the transmission to downshift, then floor it from there, for the reason you are describing. I suppose it all comes down to how your particular vehicle feels when you use one method vs the other.
2003 Ford Explorer Limited 4.6L 4x4 - 219K km
2008 Ford CVPI 4.6L - 133K km
2011 Ford F-150 Lariat S/C 6.2L 4x4 - 90K km
Re: Downshift before WOT? [Re: fsdork] #5439688 05/26/20 08:10 PM
A
Avery4 Offline OP
A
Thank you. Manually downshifting my car (a 2005 Civic with higher than stock line pressure) under light load (just cruising) is quite jarring, even with the torque converter unlocked. Hard shifts actually generally cause less wear on the clutches than smooth shifts since they slip for a shorter period of time. However, the jarring doesn't bother me and I would think that shifting under a light load would cause significantly less wear on the clutches than shifting it at full throttle, especially since I modded my engine to make about 30 HP more than stock.
Re: Downshift before WOT? [Re: Avery4] #5439707 05/26/20 08:33 PM
1
14Accent Offline
1
That really depends on the situation and the vehicle. An old, hydraulic and vacuum operated auto? Possibly, but still probably wouldn't make too much difference.
A brand new vehicle, with a 10 speed auto and computing power that rivals NASA? No chance it will help. The new cars read accelerator position, load, throttle position, gear, TCC slip, and many more faster than you can decide to put on your turn signal. When you floor that throttle, believe you me the car is making MANY more decisions than just "full power and downshift". It's adjusting transmission line pressure, timing, fuel pulse, actual throttle position (on electronic throttles), and much more. You'd be hard pressed to get a better downshift than what a modern ECM can provide.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: Downshift before WOT? [Re: 14Accent] #5439720 05/26/20 08:47 PM
J
joekingcorvette Offline
J
+1
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Downshift before WOT? [Re: 14Accent] #5439721 05/26/20 08:48 PM
A
Avery4 Offline OP
A
That is true. I know that some vehicles will cut power briefly during shifts either by closing the throttle (on cars with an electronic throttle unlike mine) and/or by retarding ignition timing or cutting off the fuel injectors during the shift. However, I don't know that my old Civic's ECU is fancy enough to do anything like that. I don't feel it cut power during shifts, but I quite possibly wouldn't feel it.
Re: Downshift before WOT? [Re: Avery4] #5439732 05/26/20 08:54 PM
E
eljefino Offline
E
^ Yeah, my wife's HHR with electronic throttle did smooth downshifts.
Re: Downshift before WOT? [Re: Avery4] #5439753 05/26/20 09:35 PM
CT8 Offline
Why is it called an automatic transmission?
2015 F150 2.7
2018 F350 6.2
Re: Downshift before WOT? [Re: Avery4] #5439820 05/26/20 11:36 PM
H
Hermann Offline
H
When I choose to use the manual mode on my Ford 6R80 automatic, the manual downshifts are anywhere from smoother to much smoother. Note that I did not say quicker, I think the computer is retarding something to make this possible.
When I switch to Sport mode, the manual shifts both up and down are very quick and not that much harsher than in Normal Mode. To be fair, in Sport Mode the Automatic improves greatly with quicker and less sloppy shifts, also holds the lower gear longer. My only complaint with the tranny is a small percentage of the time, seems to downshift one to many gears. The times it downshifts one too many gears, the second one is from harsh to very harsh. Less harsh after the transmission fully warms.
I find myself using the Manual Mode semi frequently. I have this one country road where you come down a hill at about 50 mph. At the bottom there is about a 75 degree right hander. It is a blast to hit the apex in second at 45 mph and hit the gas hard and run through the gears at high RPM up a long slow rising hill. It's a blast
My 2ยข on the matter.
2018 Ford F-150 XL Reg Cab - 3.3L NA V-6
Motorcraft 5w-20 Syn Blend and Motorcraft FL-500s
1991 BMW R100GS 20w-50 Maxlife & Mahle OX36D filter
Re: Downshift before WOT? [Re: CT8] #5439869 05/27/20 05:24 AM
supton Offline
Because in the bad old days you had to manually pick the wrong gear--today it can automatically pick the wrong one for you!
From what I've read, some programming is excellent, other transmissions... a bit less so. I drove manuals for 20 years and still think I know how to pick a gear just fine.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Downshift before WOT? [Re: 14Accent] #5439871 05/27/20 05:29 AM
demarpaint Offline
I agree.
God Bless Our Troops
Re: Downshift before WOT? [Re: supton] #5439905 05/27/20 06:56 AM
CT8 Offline
I have driven 3 on the tree through 13 speed Road Rangers manual transmissions , thank you I know how to shift very very good myself.
2015 F150 2.7
2018 F350 6.2
Re: Downshift before WOT? [Re: CT8] #5439906 05/27/20 06:58 AM
supton Offline
Then surely you must know how annoying it is when the automatic transmission does the wrong thing, no? Or have you managed to avoid the poorly programmed ones?
Re: Downshift before WOT? [Re: supton] #5439909 05/27/20 07:08 AM
demarpaint Offline
Agreed! There are some really good automatic transmissions out there. I find a CVT to be annoying, extremely annoying in fact. There are also a few AT vehicles I've driven that shift too soon, and at times seem to hunt for the right gear. Having said that my NAG1 AT is the best automatic transmission I've ever owned to date. It seems to do everything right. I've driven the ZF 8 speed and that transmission is excellent too. I wasn't crazy about the Ford 10 speed or the ZF 9 speed in some of the Jeeps. Sometimes more doesn't always translate to better.
Re: Downshift before WOT? [Re: Avery4] #5439938 05/27/20 07:51 AM
A
ARCOgraphite Offline
A
Wife has CVT in the subaru - she wont use the paddles.
So she floors it - lets say when mergin - and the car goes to redline when all she needed to do its drop a 2 "ratios' and give it 1/2 throttle.
So In many cases YES apply 1/4 throttle moderate load then D/S then apply the load you need - then U/S.
And no cars need more than 6 speed to get on the fat torque belly - never mind 10.
In fact, 4 was enough for most 2 valvers.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
