How To Remove Overspray On Aluminum Wheels?
by NDL - 07/02/20 07:16 AM
Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
bigmike323, SolsticeSHO, Bazza32, Klink_II, williamshrader
71828 Registered Users
86 registered members (2K2AcuraTL, 555, 2015_PSD, 1978elcamino, 64bawagon, alarmguy, 7 invisible), 1,291 guests, and 21 spiders.
Topics307,317
Posts5,308,856
Members71,828
how much cca is necessary for a truck battery? #5439604 05/26/20 06:17 PM
A
apollo18 Offline OP
A
i wanted to ask tho how much CCA do our trucks even need tho?
for example my vehicle has a gm 6.0 lq4 in it and its factory spec is 840cca.
840 seems very high and much higher then other trucks with bigger engines.
correct me if i am wrong but the battery is just for starting the vehicle and once the vehicle is on, the alternator should take over and the battery is essentially not be using correct? however once the vehicle is shut off then obviously the lights, radio, etc etc will run off the battery which would have to do with the reserve capacity. higher reserve capacity meaning more time to use those gadgets
i dont really have any extra mods or anything and nor do i ever listen to music etc when the truck is off. so do i really need 840 cca?
but also on a second hand it seems like 840cca is a good thing correct me if i am wrong because when it degrades etc it will be at about 700cca for example. i am just pulling numbers out of the air.
however if i compare that to a regular 750cca battery, then over the same amount of time in theory the degradation would bring it down to 650 cca.
lets say my truck needs in theory 675 cca to start minimum, and then in this scenario the 840cca would still be able to crank my truck until a certain date while the smaller battery would have already degraded to the point where it cannot start the truck anymore
i do live in alberta and it does get pretty cold here in the winters
so in this case, is it a good idea to get the bigger battery or am i wrong?
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5439609 05/26/20 06:21 PM
O
oldhp Offline
O
Biggest battery with the highest Reserve Capacity. The RC is more important.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5439624 05/26/20 06:47 PM
Chris142 Offline
I was always told double the displacement. A 350 cu in engine should have a 700A battery or better. I do not know if that still true with today's electronics added.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5439625 05/26/20 06:57 PM
Dave9 Offline
It's not initial CCA that you need, as much as resultant CCA after it ages and is depreciated by temperature. Get one with lower CCA and all else equal, it'll need replaced sooner.
So yes, the bigger battery of the same type is better, but also because each time you start it using the bigger battery, it discharges it that much less. Starting batteries last much longer if not discharged much. Granted this isn't as big a factor as age and temperature.
Re: how much cca is necessary for a truck battery? [Re: Dave9] #5439626 05/26/20 07:01 PM
A
apollo18 Offline OP
A
ahnh great i was thinking the same however i heard larger battery has weaker plates or something?
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5439641 05/26/20 07:15 PM
E
eljefino Offline
E
Yeah more CCA means weaker plates, but if they make the battery physically larger that's a good thing-- more room for thick plates.
I bought a grand marquis with the 4.6 V8 and its battery was dead as a doornail. I jump started it with my saturn, with its stupid little tiny side post terminals. It chugged over and started, albeit slowly.
It depends on compression, cam profile, oil (!), RVP of fuel, if they use a direct-drive or gear reduction starter, etc.
Seems like the little 4 cyl cars often get batteries 90% as good as the truck ones... not counting the Hondas and Miatas, lol.
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5439644 05/26/20 07:27 PM
J
Jethro_Bob Offline
J
Here in the states, the ecm will limit the alternators output for cafe standards. I wonder if that "upgrade" is present on Canadian vehicles?
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5439684 05/26/20 08:08 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Pickups often had an "HD" electrical package with uprated alternator, and uprated battery or batteries. It was for various reasons including in plow packages, etc. Sometimes the battery can help buffer short term high draw loads.
Did this truck have an uprated electrical system either specifically or as part of a plow or trailering option package?
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5439712 05/26/20 08:37 PM
samven Offline
The biggest battery you can get, but like others already said, if it comes down to choosing between 2 or 3 get the one with the highest Reserve Capacity.
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5439735 05/26/20 09:00 PM
B
bullwinkle Online Confused
Online Confused
B
Bigger is pretty much always better, especially in arctic conditions-cranking amps start dropping pretty quickly below freezing, and oil viscosity, battery cables, fuel quality, and starter all make a big difference. For instance, the 7.3 IDI in my sig ALWAYS had issues starting at 32F/0C or below, new glow plugs, new 1000 CCA batteries, even 10W30 oil didn't help. Until I put in the newer style gear reduction starter in place of the OEM direct drive one-now it starts cold with no issues whatsoever. I installed one of the 34/78DT East Penn 1000 CCA batteries from my departed 6.2 diesel Sierra into the 6.0 LQ4 Express in my sig, hopefully it'll be big enough.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5439787 05/26/20 10:34 PM
clinebarger Offline
@300 amps is the most I've ever seen a LSx engine draw while cranking, And that's the initial spike to get the engine turning.
2001 Chevy Camaro L92/4L80E
Re: how much cca is necessary for a truck battery? [Re: eljefino] #5439879 05/27/20 05:43 AM
supton Online Content
Online Content
Yep. Bigger is always better, but, with the right oil in the sump and a good starter, it might not matter.
I killed the battery in my truck one winter, it wasn't too cold but maybe around freezing? don't remember now but it was below 9V on the battery. Hooked up my car and it cranked right over and started, easy peasy, with just the jumper cables. It starts so easily that it's still running that same battery, which is pushing 10 years of age! Cannot tell me that it has anything close to what it started out with.
Now I'd be wise to replace it sooner than later, but, I don't have a snow plow, a winch nor a thumpin' stereo. A smaller battery will serve it just fine.
I do stick with 0W oils though, so there is that factor (although 5W would serve me just fine too I bet).
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5439904 05/27/20 06:52 AM
Donald Offline
The owners manual should state what size battery the vehicle shipped with. So that size or larger.
2015 Ford F-250 w/Powerstroke
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5440194 05/27/20 02:38 PM
A
apollo18 Offline OP
A
well my owners manual wants a group 79 but i wont be able to find that at costco. it tells me to put in a 78 which is a little smaller then my 79
but from costco it seems like i am choosing between either a group 78 or a group 65 and it seems like the group 65 is a no brainer since its larger
hopefully it fits tho
Re: how much cca is necessary for a truck battery? [Re: apollo18] #5440222 05/27/20 03:00 PM
ABN_CBT_ENGR Offline
I'll answer that based on the guidance I had back in the day. However, this was a young engineer with Globe Union ( back then a division of Johnson controls) for Sears and Interstate batteries so its a little "dated" ( OK, a LOT dated) but I don't think the formula for establishing the requirements has changed much. Use this for a historical reference to form a baseline as I doubt the thought process has changed much on how to determine what the requirements should be.
CCA is amps at for 30 second at 0F without dropping below 7.2 VDC for a wet celled battery with a SG of 12.60 ( temperature corrected with a 65/35 mix) and 2.1 VDC per cell in series and OCV at 12.6 VDC
The engine displacement, oil viscosity, compression, number of cylinders and what used to be called magneto ( for older engines) was calculated and given to us to meet.
We took that figure and basically doubled it plus to account for performance degradation from the CA (cranking amps) and loss of estimated performance of a battery plate calcifying for one year.
Reserve capacity was all loads and a discharge of 1 hr.
A car battery has a reserve capacity but not like a deep cycle with denser plates to withstand charging cycles.
I'm sure things are different today and BCI has changed some things but back when that's how a CCA for a vehicle was calculated and given to us to construct against.
