Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
27 registered members (Ausfahrt, carviewsonic, celicaxx, blufeb95, 6 invisible), 597 guests, and 28 spiders.
Topics307,747
Posts5,316,936
Members71,910
Replacing my Group 27 battery with Group 31 battery. Is that ok? #5439384 05/26/20 01:47 PM
P
PetitFrereArmada Offline OP
P
I have oem battery which is Group 27 battery in my Infiniti QX56/80. I bought the battery brand new at the dealership on 7/16. It has lasted me almost 4 years now and still cranks ok, but it shows signs of dying. I got it checked at Autozone and they confirmed that it cranks just ok but power is going low every day.
My offroad lights do take a toll on my battery since I use them sometimes without even turning my engine on. They are wired directly to my battery. So, I want something more powerful now to handle the extra juice my lights draw from my battery.
I wanted to get the Interstate battery with 810 CCA from Costco, but the nearest Costsco carrying it is 300 miles away. The stores in my area do not carry and refuse to order it for me. It comes with 3 years FREE replacement.
[Linked Image from i.imgur.com]
I went to Walmart and almost got the Everstart Maxx with 810 CCA. It comes with 3 years FREE replacement.
I changed my mind and said I will take some more time to decide. I am leaning towards experimenting with something else if it will work. My small and basic research has shown me I could be able to make the group 31 battery fit. This battery is larger in size to my group 27, though I believe I can make it fit my battery tray.
So, my goal now is to purchase this Interstate Battery that I can get locally here for $169 plus tax. It has 950 CCA. Warranty on it is only 1 year free replacement, but I am hoping it would last me more than 3 years. Since my basic oem lasted 4 years, I hope this Interstate which claims better specs than my basic oem, would last too atleast 3 years.
What do you guys think about replacing my group 27 batteries with the group 31 battery. Will it be ok or not wise to do? Also, I have read a lot of good things about Interstate.
I hope if I buy this battery, it can last more than 3 years. That is the point at which I believe I would have had my money's worth and will not be mad if it dies after that. Since my basic oem can give me 4 years. And the Walmart group 27 offers 3 years free replacement.
2012 Infiniti QX56. 156,000 miles. Shell Rotella 5w30 truck with Fram XG oil filter.
2008 Nissan Maxima. 265,000 miles. Using 5w30 with stock filter.
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: PetitFrereArmada] #5439390 05/26/20 02:01 PM
Danno Offline
If it fits the tray, the height works, and if the tie down fits, good to go.
Higher CCA batteries may have thinner plates, which may make them more fragile, shortening battery life.
Things to consider.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: PetitFrereArmada] #5439415 05/26/20 02:24 PM
W
Wolf359 Offline
W
And stop using your lights without running the engine. That's what's killing your battery. They last the longest when they're fully charged. When you run them down and don't charge them up, that's how you kill them. A few cents worth of gas would save you about a hundred.
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: PetitFrereArmada] #5439417 05/26/20 02:28 PM
M
MParr Offline
M
East Penn shows that group 27 or group 34 batteries fit.
http://www.showmetheparts.com/dekamobile/
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: PetitFrereArmada] #5439422 05/26/20 02:35 PM
R
ripcord Offline
R
Also, if you run down a car battery, don't expect the alternator to fully charge the battery fully unless you are regularly making several hour long trips. In most cars the alternator is good at maintaining the batteries charge, but not really great at recharging a deeply discharged one; and due to the chemistry of lead acid batteries, they can't be fully charged more quickly. For longest battery life, it's good to throw a charger on it to top it off periodically, especially if you run it down.
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: PetitFrereArmada] #5439426 05/26/20 02:36 PM
O
oldhp Offline
O
With what you are doing you need a battery with a high Reserve Capacity ( RC ). The group 31 has 195 minutes @ max 25 amp draw. If it fits use this one. BUT. You still should charge it up from time to time because of how you use it as others have said. A battery powered LED lantern type light might fit your need better than you car lights, with no worry about a NO start situation. shrug
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: Wolf359] #5439429 05/26/20 02:41 PM
B
bbhero Offline
B
This ^^^^^^^^^
Is a very good point by Wolf...
If you do continue to do that... Charge that battery on a good charger routinely.
Nissan Altima 3.5 Coupe
Royal Purple 10w30+ Ceratec+ Carquest red 85358
"Treat your family like your friends and treat your friends like your family."
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: PetitFrereArmada] #5439448 05/26/20 03:07 PM
Dave9 Offline
Frankly, since you are in TX and want to run the lights with the engine off, I'd just get a deep cycle instead. A QX56 can't need many CCA in TX.
However, almost 4 years isn't all THAT bad. If you just get something top tier with a 5 year warranty, you can just get the remainder pro-rated on the new battery, as long as you're astute enough to recognize worn battery symptoms so it doesn't leave you stranded in BFE.
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: PetitFrereArmada] #5439455 05/26/20 03:11 PM
Danno Offline
Used to have the problem of high accessory battery draws on a commercial fleet.
Found that the Odyssey AGM battery worked well, it could draw down deep but recover and stay viable for 3x-4x a lead acid.
This was 10 years ago, not sure if Odyssey is same quality.
2010 Mazda 3 2.0L
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: MParr] #5439474 05/26/20 03:26 PM
P
P
My Group 27 is larger than Group 34.
If I have to go away from oem Group 27, I am thinking of only Group 31.
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: Danno] #5439475 05/26/20 03:26 PM
P
P
Things to consider.
It does not fit perfectly, but I think I can make it fit the stock tray.
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: PetitFrereArmada] #5439477 05/26/20 03:32 PM
B
bbhero Offline
B
You should.... Have enough length to make it fit...
My car specs a group 35... But a group 24F does fit even though it's longer.... 10 3/4 for group 24F vs 9 1/16 inch long for the group 35...
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: bbhero] #5439483 05/26/20 03:35 PM
P
P
This is not a routine or a habit, but I find myself doing it every now and then.
That is why I am looking at the Group 31. But I wish one of my 6 Costco in my area had the Group 27 battery with 3 years FREE warranty. That is my first choice. The fact that I can get it only about 220 miles away defeats the purpose of if I need warranty out of a sudden.
Yeah, I plan to stop doing that with my new battery. If I could easily get the Costco Group 27 battery, that would be nice. But I do not like that it is not easily accessible to me.
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: bbhero] #5439486 05/26/20 03:38 PM
P
P
Yup, I agree. I think I can make it fit for sure. What bothers me about it is how they claim only 1 year warranty. Seriously, will this battery fail before 3 years? It shows specs better than my OEM. But my OEM battery has lasted me almost 4 years now.
Re: Replacing my Group 27 battery with Group 31 battery. Is that ok? [Re: Dave9] #5439493 05/26/20 03:41 PM
P
P
The OEM battery in my car, I got from the dealership. It comes with 5 years warranty. 2 years FREE replacement and 3 years pro rated. I just called them and they said I would need to pay about $8X.XX drive out for a new one with another 5 years warranty.
But they claim they have to test it and if does not say BAD, they will not replace it. I tested it at Autozone and it was not bad. It tested as GOOD. But the CCA is lower now and they told me it is on its way out. Plus acid was low and I topped off at home with distilled water.
So, seems dealership wants mew to be stranded before they give me a prorated price on a new battery.
