Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
99 registered members (Audioquest, Avery4, 77GrandPrix, 4WD, Arob, 72te27, 8 invisible), 1,732 guests, and 18 spiders.
Topics307,463
Posts5,311,657
Members71,852
12 volt air compressor #5439119 05/26/20 08:42 AM
J
John_Conrad Offline OP
J
recomemdations for 12 volt air compressors?
any experience with this one:
https://www.harborfreight.com/12v-100-psi-high-volume-air-compressor-69284.html
Safety doesn't happen by accident.--author unknown
Re: 12 volt air compressor [Re: John_Conrad] #5439128 05/26/20 08:52 AM
Donald Offline
What is the intended use?
I have a Ryobi cordless one I use a lot so I do not need to drag out air hose from compressor in garage. It also will shut off at a selected pressure and I like that.
But if you want to carry one in car then a 12V one is what is needed.
2015 Ford F-250 w/Powerstroke
Re: 12 volt air compressor [Re: John_Conrad] #5439132 05/26/20 08:54 AM
J
J
intended use is carry in vehicle
cordless would be nice, glad i thought of that smile
i will look at those, thanks D
Re: 12 volt air compressor [Re: John_Conrad] #5439137 05/26/20 09:01 AM
R
ragtoplvr Offline
R
I used mine again this weekend. 5 yr old. Works good. Bought another and it has 10 minutes on it, worked great. Plugged a flat, re-inflated in less than 10 minutes. No overheating on one tire. More than that it would need to cool. I would not do a semi tire at 100 PSI. It might get too hot. Great little compressor, much faster than the 10 dollar ones.
Rod
Re: 12 volt air compressor [Re: John_Conrad] #5439161 05/26/20 09:33 AM
Z
Zaedock Offline
Z
I have a Viair 400H in my trail Jeep. I've had it for years and it's been flawless.
Viair indicates it can inflate a 35" tire from 0-30psi in 5:20. My Jeep is a trailer queen now with 38x16's that only runs 3 PSI, but if I need air, it inflates them pretty quickly.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: 12 volt air compressor [Re: John_Conrad] #5439162 05/26/20 09:34 AM
Z
Zaedock Offline
Z
Noticed you said cordless, so the 400P (portable vs hard mount) would be what you're looking for.
Re: 12 volt air compressor [Re: Zaedock] #5439175 05/26/20 09:49 AM
B
Bear Offline
B
I have the Ryobi and it's great.
https://www.homedepot.com/p/RYOBI-1...flator-Deflator-Tool-Only-P747/308746324
I bought the inflator only since I already have batteries.
2014 Ford F150 4X XLT
2008 Honda CRV
Re: 12 volt air compressor [Re: John_Conrad] #5439237 05/26/20 11:04 AM
K
Kawiguy454 Offline
K
I got the next motor up from the one in your link for like $59 Plus the usual 20% discount. The motor/compressor rod has Ball bearings and a metal base-plate with rubber isolators so it doesn't dance around on the ground while running.
Re: 12 volt air compressor [Re: John_Conrad] #5439242 05/26/20 11:11 AM
W
Wolf359 Offline
W
I have the older one of this model which was $20 at one point that had a regular analog gauge and this new one has a digital one. The one mentioned above sometimes goes on sale for $35. That might be a nicer one as you can just set the pressure. The one below you have to hold the trigger til it reaches the right pressure.
https://www.homedepot.com/p/RYOBI-1...-Digital-Gauge-Tool-Only-P737D/307627867
Re: 12 volt air compressor [Re: John_Conrad] #5439278 05/26/20 11:51 AM
W
wymi516 Offline
W
2016 KIA Forte SX 1.6L T-GDI Daughter
2013 Chevy Impala LT 3.6L GDI Mine
2014 Chrysler 200S 3.6L PFI Wife
Re: 12 volt air compressor [Re: John_Conrad] #5439364 05/26/20 01:23 PM
CELICA_XX Offline
Viair 88P
I like this model specifically because it connects directly to the battery as opposed to relying on the 12V cigarette lighter.
It has excellent reviews on Amazon.
20 Toyota RAV4 Hybrid - factory 0w16
06 Acura MDX - M1 EP HM 5w30 SN+
02 Toyota ECHO - Valv MaxLife Syn 5w30 SN
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - M1 EP HM 5w30 SN+
Re: 12 volt air compressor [Re: CELICA_XX] #5439365 05/26/20 01:26 PM
Donald Offline
Originally Posted by CELICA_XX
Viair 88P
You are limited to xx amps out of the cigarette lighter (fuse) vs clamps to battery post.
Re: 12 volt air compressor [Re: CELICA_XX] #5439372 05/26/20 01:30 PM
R
Reddy45 Online Content
Online Content
R
Viair 88P
Ditto . It's a very stout compressor and it can pull more power.
Re: 12 volt air compressor [Re: John_Conrad] #5439383 05/26/20 01:44 PM
M
Miller88 Offline
M
I've had a few of those. I did modify them so they can connect directly to the battery. Otherwise they have a propensity to melt the 12V power outlet when inflating 4 tires. One died after getting driven over, the second died after inflating 3 sets of Jeep tires from 15 to 35 PSI and had a few years of hard use before that.
Right now I'm using this one: https://www.harborfreight.com/12v-150-psi-compact-air-compressor-63184.html , it's a few years old at this point but seems to work great. I hook it up to a manifold and inflate 4 tires at once. Gets hot, but I lube it every use. And it connects to the battery directly without modification.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: 12 volt air compressor [Re: CELICA_XX] #5439589 05/26/20 05:56 PM
P
pharden Offline
P
I've got a Viair 88p and would recommend it. I like how it connects directly to the battery and the quality of the hose and the fittings. I throw it in the truck whenever I take a trip.
