Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Bazza32, Klink_II, williamshrader, 96JeepXJ, TxVet33
71826 Registered Users
65 registered members (AlienBug, alarmguy, anpconnors, antone, 4WD, 4 invisible), 1,041 guests, and 35 spiders.
Topics307,389
Posts5,309,654
Members71,826
I need advice on Toyota V6 timing belt #5439015 05/26/20 06:13 AM
M
michaelluscher Offline OP
M
I need advice
I'm planning on some long overdue maintenance work for my '06 Camry
It's at ~147K, on the factory timing belt and accessories
At 15 years old, I'm about 5 years and 60k late, gotta make that right
What do we think of AISIN timing belt and seal kits?
I ordered a kit w/tensioner and cam/crank/belt cover seals off Rockauto
TKT026 for $154
SKT004 for $24
Delivered for $193
I've taken pictures, because I've heard many stories of counterfeit and questionable substitutions thrown in the box
[Linked Image from i.imgur.com]
My main concern is the belt itself, and the cam/crank seals
I considered buying the belt and seals direct from Toyota for $75 extra or so, and still pocketing the significant savings on everything else
OTOH, what's wrong with a Mitsuboshi timing belt?
Horiuchi Shoten (THO) makes the seals, I've never heard of them before, but they look well made and say "Made in Japan"
Everything else should be the same thing my Toyota parts guy sells me, just for 1/3 the price? (NTN, Koyo, etc)
[censored], I even went all out on a $120 specialty tool for the cam seals, because I'm petrified of nicking the journals, where it'll never seal again
From a shady seller, for more money, because it's OOS everywhere else. I do hope it actually shows up
I don't know what I'm gonna do for the cam seal, the Lisle tool or a paint can opener?
[Linked Image from toolsource.com]
I'm gonna pick up a HF crank puller (with my jack stand that nearly killed me) refund
Do I need the special weighted 22mm socket, are they that much of a [censored] to remove?
I've got a 1/2 air impact and a 20 gallon compressor
Do I need this pulley holder to torque it down to spec after it's all done?
Can anyone recommend a cam pulley holding tool for when they come off for the cam seals?
Reviews are mixed
I'm trying to think of every possible little roadblock so I can have tools and backup plans on hand
Now I've got the slightly different and larger 3MZ-FE V6
I remember hearing how older Camry 2.2 5S I4 and earlier 3.0 1MZ V6 engines liked to leak real bad from some type of oil pump seal?
Is it a shaft seal against a pulley, or is it a pump seal to the block?
Does this apply to mine?
Should I replace it while I'm in there?
I'm planning a new Denso rad and new upper/lower hoses, with fresh SLLC so I don't waste coolant doing it twice
I've got the spill free funnel ready
I've got easy access to both block drains, hopefully that limits the mess when the pump comes loose
I've got valve cover gaskets with bolts coming, stop the leaks on the top end
Anyone with experience with this engine, experience and anecdotes are much appreciated
I've watched about 6 different videos back to front on this job, but I know many experts live here with something I don't know grin
'20 XT4 Premium Luxury 2.0T, breaking in all the toys
'06 Camry SE 3MZ-FE 146K
'06 Taurus SE Vulcan 65K
'01 Villager Estate VG33E 55K
'83 Grand Prix LJ 305 SBC 56K
Re: I need advice on Toyota V6 timing belt [Re: michaelluscher] #5439018 05/26/20 06:18 AM
B
blufeb95 Offline
B
Isn't Aisin Toyota OE?
Re: I need advice on Toyota V6 timing belt [Re: michaelluscher] #5439069 05/26/20 07:19 AM
K
kschachn Offline
K
The Aisin kit you have is all what Toyota installs as OEM. If you got it from a reputable seller as you say (Rock Auto) then it is genuine. If you purchased Toyota branded parts you'd get the exact same components.
I've changed out probably 10 timing belts on 1MZ-FE and 3MZ-FE engines and it's not that bad of a job as timing belts go. Get the FSM if you can for reference.
As for a cam sprocket holding tool and a seal remover, these are the ones I have. The seal remover is from Lisle and it works like a charm. I also have the same crankshaft holder you show.
[Linked Image from audiworld.com]
[Linked Image from images-na.ssl-images-amazon.com]
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: I need advice on Toyota V6 timing belt [Re: michaelluscher] #5439078 05/26/20 07:30 AM
PimTac Offline
Mitsuboshi makes good stuff. Seems like we had a thread on this just recently.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: I need advice on Toyota V6 timing belt [Re: michaelluscher] #5439085 05/26/20 07:39 AM
M
mk378 Offline
M
Do not try to replace the seals unless you find they are leaking.
Re: I need advice on Toyota V6 timing belt [Re: michaelluscher] #5439140 05/26/20 09:04 AM
F
Farnsworth Offline
F
If you have time you can make the holding tools. It doesn't have to look pretty. The wp has a stud to remove I believe, The rear valve cover gasket will not be fun. You bought a top quality belt kit, now the work begins,
Re: I need advice on Toyota V6 timing belt [Re: PimTac] #5439164 05/26/20 09:35 AM
G
Gebo Offline
G
We did.
FWIW, I just got a timing belt from Toyota dealer last month and it does not have "Mitsuboshi" written on it. I posted here asking why my timing belt didn't have "Mitsuboshi" written on it.
It only had the logo.
As far as what I think about Aisin TIming Belt kits? If I knew it was made by Aisin, I wouldn't be scared at all. That is the big question. You will never know if it is a true Aisin for certain.
I got a fake Aisin rear wheel bearing that failed and only after it failed did the Lexus mechanic see it was not made like their Lexus OEM Aisin Wheel Bearings which were about 50% more
in price.
I ain't buying a kit from anyone but a dealer. I may be stupid. I may be in error. I may be a conspiracy theorist. But I "know" my parts are legit.
happy
Will putting in copy cat parts destroy your car? Probably not. I would say the odds are in your favor. I say that to bring balance to my previous comments. Odds are you will be fine.
They are probably legit.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: I need advice on Toyota V6 timing belt [Re: Gebo] #5439195 05/26/20 10:19 AM
K
kschachn Offline
K
Originally Posted by Gebo
I got a fake Aisin rear wheel bearing that failed and only after it failed did the Lexus mechanic see it was not made like their Lexus OEM Aisin Wheel Bearings which were about 50% more in price.
If Aisin makes wheel bearings that's a new one on me.
1994 BMW 530i, 253K
Re: I need advice on Toyota V6 timing belt [Re: michaelluscher] #5439197 05/26/20 10:20 AM
F
Farnsworth Offline
F
Just to add when I did my Toyota timing belt the oe bearings were Koyo and the tensioner NTN from the factory. That set looks legit. Sometimes you can just see it, although I am big on buying dealer parts. I replaced the parts with less than Koyo and used a gates belt. Never an issue.
You will need more gaskets to get to the rear valve cover. I never want to do that job again and am amazed at mechanics who have to bend over an engine bay and deal with some of this work on a daily basis.
Replace the heater hoses too since you doing all that.
Re: I need advice on Toyota V6 timing belt [Re: mk378] #5439230 05/26/20 11:01 AM
J
JMJNet Offline
J
Why?
I would replace all the seals because if the seals leak, then the whole timing belt replacement have to be redone.
The Belt usually broke because of oil leaks dripping onto the belt.
Don't ask me how I know.
  • 2017 Toyota Sienna
Re: I need advice on Toyota V6 timing belt [Re: michaelluscher] #5439238 05/26/20 11:05 AM
Yah-Tah-Hey Offline
Looks like OEM components. Go for it.
Re: I need advice on Toyota V6 timing belt [Re: michaelluscher] #5439275 05/26/20 11:47 AM
M
mehullica Offline
M
That kit you bought is awesome. Use all of it. I’ve done many & the kit has the same parts that the factory uses. As for the oil pump, it’s not prone to leak lime the older 5S-FE style. Just replace the front crank seal & 2 cam seals. Valve cover gaskets are easy if you need to do them now, also makes the cam seals a breeze to with no special tools required with the valve cover off.
Re: I need advice on Toyota V6 timing belt [Re: michaelluscher] #5439295 05/26/20 12:04 PM
DGXR Offline
Yes Toyota uses many Aisin parts for factory assembly and dealer repairs/replacements. I would use this kit with confidence. It sounds like you are being extra careful in the areas that warrant it. Go for it, and good luck. thumbsup
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
Re: I need advice on Toyota V6 timing belt [Re: mk378] #5439345 05/26/20 12:59 PM
W
WyrTwister Offline
W
Wyr
God bless
Re: I need advice on Toyota V6 timing belt [Re: WyrTwister] #5439349 05/26/20 01:06 PM
K
kschachn Offline
K
Although if you are using the tool illustrated in the first post then it is about a 10 minute job. I have the camshaft tool but not the crankshaft one.
1994 BMW 530i, 253K
