Forums Migration
Please read this thread
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
80 registered members (92saturnsl2, Astro14, 77GrandPrix, bdcardinal, ammolab, AlienBug, 8 invisible), 1,686 guests, and 23 spiders.
Topics307,779
Posts5,317,657
Members71,917
Left Hand Drillbits #5438885 05/25/20 10:32 PM
Snagglefoot Offline OP
Finally got around to buying a set of left hand drill bits, handy to start drilling out a bolt and in hope it comes free, or as a way to start a hole for an Easy Out tool. Funny there were no markings on the case to indicate they were left hand. Might make a good gag gift for someone you know. laugh
Amazon.com. Left hand drill bits.
If you want the job done right......do it yourself.
Re: Left Hand Drillbits [Re: Snagglefoot] #5438887 05/25/20 10:37 PM
Chris142 Offline
They will not work in a chuck that is only tightened by hand. They loosen the grip.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Left Hand Drillbits [Re: Snagglefoot] #5438891 05/25/20 10:40 PM
B
Blkstanger Online Content
Online Content
B
I have had great success using them on broken bolts.
99 Jeep WJ 4.7 205,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 81,000mi. Castrol Edge 5w30 Fram Ultra.
Re: Left Hand Drillbits [Re: Snagglefoot] #5438933 05/26/20 12:51 AM
Silk Offline
I guess people these days don't sharpen drills by hand, but sharpening a left hand drill requires some serious thought processes, and that's not enough to overcome years of sharpening right hand drill bits.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Left Hand Drillbits [Re: Silk] #5439090 05/26/20 07:51 AM
Cujet Offline
So true! However, a DIY sharpening job on a LH drill bit can be ground (sharp and different angle) for aggressive bite. This helps a lot with stuck bolt removal.
Re: Left Hand Drillbits [Re: Snagglefoot] #5439671 05/26/20 07:56 PM
H
HangFire Offline
H
That's a great start, I have a set like that, that has gotten me out of several jams. Since then, I've added stubby cobalt LH bits, and a right angle air drill with a Jacobs keyed chuck.
As for the hand tightening chucks, it CAN work... at least for a minute or two at a time... as long as the chuck is fresh, and NOTHING touches it while you use it.
Various musings: http://hangfire.net
Re: Left Hand Drillbits [Re: Snagglefoot] #5440685 05/28/20 07:35 AM
T
Trav Offline
T
Stating the obvious but unless you have a direct drive drill press with reverse its a hand held drill bit only.
