Forums Migration
Please read this thread
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
76 registered members (bbhero, A_Spruce, alchargo, 92saturnsl2, Astro14, 77GrandPrix, 8 invisible), 1,675 guests, and 22 spiders.
Topics307,779
Posts5,317,659
Members71,917
any battery charger/repair that can fix sulfation? #5438755 05/25/20 07:28 PM
A
apollo18 Offline OP
A
it seems like my lead acid battery is sulfated or something is wrong after 2 years of use. its a group 78 ac delco
i have a noco genius 3500 hooked up to it but i cant get it to charge to fully 100%, secondly i tried using the repair mode but i got an error.
i was told to 100% charge the battery and then run the repair mode but it only lasted for x amount of time and then went into error state.
i believe it must be sulfated or something, is there anyhing i can buy that is better then the noco that can fix it? or am i out of luck
thx
Re: any battery charger/repair that can fix sulfation? [Re: apollo18] #5438779 05/25/20 08:03 PM
I
irad Offline
I
Did you and can you check the water level in the cells? Top off with distilled water and try to charge. The goal is to get the sulfate back into solution and off the plates. If that is unsuccessful you can add Epsom salt to each cell and charge. About a quarter teaspoon per cell.
Re: any battery charger/repair that can fix sulfation? [Re: apollo18] #5438783 05/25/20 08:06 PM
Chris142 Online Content
Online Content
I have tried desulfating them and epson salt. Nothing worked.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: any battery charger/repair that can fix sulfation? [Re: apollo18] #5438792 05/25/20 08:20 PM
I
irad Offline
I
Last thing to do is pour out all the liquid and replace with distilled water. Then try to charge. Be very careful the liquid is acid. You can neutralize it with baking soda. My other thught is what is the battery voltage? Under ten volts the battery probably has physical damage.
Re: any battery charger/repair that can fix sulfation? [Re: irad] #5438821 05/25/20 08:53 PM
A
apollo18 Offline OP
A
i dont think the voltage is that low i will check with my multi becasue i charged it up and installed it in my truck and it started up fine, maybe took a little longer cranking but that could be/was because my truck sat for a week with no starts.
however it fails the load test at the dealership and i noticed my noco genius cant get it perfectly to 100% battery and the repair mode failed
Re: any battery charger/repair that can fix sulfation? [Re: apollo18] #5438904 05/25/20 11:15 PM
CELICA_XX Offline
I had a dead battery that I ruined from from sitting too long.
When attempting to charge it with 6A or 30A, the charger read SUL (sulfated) ... but I was able to "revive" it with a 100A charger.
I'm sure the battery lifespan is diminished, but it does work now.
20 Toyota RAV4 Hybrid - factory 0w16
06 Acura MDX - M1 EP HM 5w30 SN+
02 Toyota ECHO - Valv MaxLife Syn 5w30 SN
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - M1 EP HM 5w30 SN+
Re: any battery charger/repair that can fix sulfation? [Re: CELICA_XX] #5438919 05/26/20 12:04 AM
A
apollo18 Offline OP
A
ahh kk thank for the tip, but dont alternators push high amps too? so i assume driving for a while could maybe fix it too?
Re: any battery charger/repair that can fix sulfation? [Re: apollo18] #5438938 05/26/20 01:20 AM
R
ripcord Offline
R
Most cars won't push a high number of amps for a long period of time to avoid damaging the battery in normal operation.
Lead acid batteries take a long time to charge. With a typical 6 or 10 amp charger, a totally dead automotive battery will normally take several hours or more to reach about 70% charged which is called the bulk charge period. The last 30%, or the saturation period, takes about as long as the first. If your battery is fully discharged, you can drive for hours and not reach a fully saturated state of charge. That's why a lot of batteries die a young death. They spend most of their life only partially charged. This is especially true in cold weather with mostly short trips. Partially charged lead acid batteries are more prone to sulfation.
The best way I've found to try to bring back a really dead battery is a prolonged slow charge. You want one of the old school trickle chargers, not a modern electronic controlled one, for really dead batteries. Preferably one that has a setting for one or two amps. You should also get a battery hydrometer.
First, pull the caps off if they are removable and verify that all the plates are fully submerged. Then test each cell with a hydrometer and record the values. What you want to see is that each cell is fairly close to all the others. If one is significantly lower than the rest, you probably won't be able to save the battery. Then, charge at the lowest setting. Check the voltage as it is charging. As the battery charges, the voltage will begin to rise. Once (and if) it reaches about 14.6 volts with the charger on, it is fully charged. If it hasn't reached 14.6 after 24 hours, remove the charger and test again with the hydrometer. If you see some cells that have a specific gravity of 1.26 and others that are 1.20 or lower, then you have bad cells. You can try charging further but chances are it won't help. If they are all less than 1.26 and all near the same values, then put the charger back on and continue monitoring voltage.
If you have some weak cells but most of the cells have reached 1.26 specific gravity, this is the point at which it might be worthwhile to try messing with desulfation gizmos. If you do it before fully charging the battery you won't know if it's helping or not without some solid before and after numbers. A lot of the time the bad cells are shorted internally and no amount of "desulfating" is going to help.
Re: any battery charger/repair that can fix sulfation? [Re: apollo18] #5439054 05/26/20 07:08 AM
M
mk378 Offline
M
If this battery is 2 years old and failing the load test shouldn't you warranty it?
Re: any battery charger/repair that can fix sulfation? [Re: apollo18] #5439066 05/26/20 07:17 AM
Donald Offline
I have a Battery Minder and it automatically does desulphation. But I have never seen it revive a battery that did not pass a battery test. It probably does do some desulfation but not enough to really fix the battery. When I talked to the company they said in some cases it can take weeks to desulfate a battery.
2015 Ford F-250 w/Powerstroke
Re: any battery charger/repair that can fix sulfation? [Re: apollo18] #5439075 05/26/20 07:25 AM
Driz Offline
I got one of those $75 European made wonder Desulphating chargers a couple years back. I have found it useful for batteries BEFORE you notice they are getting weak and starting to struggle. I tried it on a couple fairly poor ones and after repeat cycles they never hot much if any better on my load tester.
In the end I use mine as a maintenance tool. As others have reported using it regularly a couple times a year it’ll get you about another season or year out of a battery. I guess that makes it worth buying in the long run. As for fixing poor ones don’t expect any miracles. They only last so long ......... I’ve never seen more than 7 years from any battery usually more like 5.
Re: any battery charger/repair that can fix sulfation? [Re: mk378] #5439248 05/26/20 11:21 AM
A
apollo18 Offline OP
A
sadly it was a warranty replacement and as much as i dont agree with how the warranty replacement battery has no new warranty, i am out of luck:((
