I am debating over using either Maxlife ATF or the Valvoline Import ATF in a 2008 W4A5A 4-speed mitsubishi transmission. Both fluids contain SP-III certification. I know that Maxlife ATF is great fluid, but i like the idea of the Import being a little bit thicker (or the Maxlife is pretty thin it seems), but the Maxlife ATF is cheaper to get and better availability.
Edit: I also found Idemitsu Type HK, that specifies directly for Hyundai/Kia SP-III but "also works for" Mitsu, Chrysler, others that used it. At currently USD$6.32/qt, might use that.
