FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
40 registered members (bbhero, Amkeer, Dan55, carviewsonic, Aredeeem, DaHen, 5 invisible), 913 guests, and 19 spiders.
Topics307,396
Posts5,310,351
Members71,843
2014 Elantra delayed shift 4th to 5th #5438669 05/25/20 05:51 PM
Propflux01 Offline OP
I have a 2014 Elantra, 117K, runs great generally. When normal driving, no shift issues. I take a trip once a month to Kansas City from Little Rock.This goes through the Ozark "hills". When the car starts up these hills it downshifts as needed to the appropriate gear, which is usually from 6th to 5th. When its alittle steeper, 4th. The issue I have is when I crest the hill, and either remain level or start downhill, it delays the upshift out of fourth for quite some time. 10-15 seconds at times.If I manually shift it, it is immediate. It seems to only do this when I take a really long trip, doesn't do it on my daily drive to work, etc. Its only the 4th to 5th, works normally from 5th to 6th. Fluid has been changed twice, once at 70K, and again at 100K, using OE SP-lV-M.Other than that, the car shifts normally and when its supposed to. Any one have an idea? (Level check is good). It has done this for awhile (about 40K), and has simply been a nuisance, but lately the time lag seems to be getting longer.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5438690 05/25/20 06:13 PM
M
Mainia Offline
M
Has the filter been change with one those 2 fluid changes? Also were the changes just a pan dump or a 100% fluid change?
2018 Lowered Hyundai Kona AWD 1.6T https://www.hyundaikonaforum.com/showcase/2018-kona-awd-1-6t-lowered.1162/
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5438696 05/25/20 06:21 PM
Filter is inaccessible without complete teardown.1st fluid change showed no metal chunks, or excessive flakes, 2nd was way cleaner. Changes were pan dumps. Fluid looked and smelled good on both drains.
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5438706 05/25/20 06:35 PM
dave1251 Offline
Drain and fill with Lubegard and Maxlife ATF. You may add another 3 or 4 years to your AT.
don't use.
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5438715 05/25/20 06:44 PM
7
71Chevyguy Offline
7
Did it not do this before? Because this sounds to me like the car is sensing the load and holding the gear to save on shifts in case you continue uphill. I have driven some cars that do and others that don't. It may be normal unless you are sure it didn't do it before. I have a 98 Buick that does this and a 97 Pontiac that doesn't, all in the programming. Unless it didn't do this before, I don't think you are having an issue. Especially since you have maintained it properly.
14 Jetta Sportwagen TDI
14 Beetle TDI
98 Buick LeSabre Defy 10w30 / Fram Ultra 3387a
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5438716 05/25/20 06:45 PM
E
eljefino Offline
E
Sounds like "Fuzzy logic" eg it wants to engine-brake. Maybe the thinner air of the hills has it working harder and believing the hills are "steeper".
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5438720 05/25/20 06:48 PM
B
buddylpal Offline
B
How long have you had the car? Has it always done this? I’ve owned and driven several cars that do this and it was part of its grade logic anticipating more inclines.
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5438722 05/25/20 06:48 PM
B
buddylpal Offline
B
Cruise control always seemed to make it more pronounced.
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5438737 05/25/20 07:07 PM
R
Ram02 Offline
R
Like Dave 1251 said lubeguard and Maxlife is all you need .
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5438762 05/25/20 07:44 PM
M
Mainia Offline
M
I don't know if that car has adaptive trans learning, but for a Hail Mary, pull the battery cable for 15 minutes the night before you do the Ozarks and see if that helps. SP4-M is a quality ATF or at least it was. I had Hyundai documentation it was Ester based and then they pulled the document about a year after I found it.
I filtered my 2013Hyundai Elantra GT , my wife's Rav 4 (Redline D6) and my daughter Honda Civic (MaxLife) with this filter. And my daughter who is Gen Z who is ablivous to anything but a phone said she noticed that after I put filter on her car shifted faster and just plain better. It was another filter brand at the time (NTZ TransProtector) I too noticed the difference in the Elantra too. Because the filter filters down to 15 micron, the ATF solenoids move more freely and faster. Ryabestos copied the outside of the filter and it has a crappy common pleated filter in it. So I would ONLY trust ones coming from Russel Transmission Order your from the designer/tester. Rumor has it he sold the patent to Transmaxx, but I can't find this filter from them. You can then from Russel Transmission below. This IS the best $25-50 filter on the market. They say switch out at 30,000 miles. I switch the first one at 10,000 miles to get the oil filtered and THEN do the 30,000 mile run so I know I have good flow.
http://www.russellautoinc.com/about-us.aspx
2005 Honda Civic
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5438823 05/25/20 08:54 PM
OK, I tried some lubegard red in it, about 500 miles ago. I cannot use Maxlife, as I have used it in a sonata I had and it didn't work that well. For these, I stick with SP-lV. I have had the car since new. I didn't have this issue when new, it has slowly progressed over the miles.I don't use the cruise going on hills, as It will run the snot out of the car trying to keep speed. Perhaps it is anticipating, it just seems once the gas pedal is let up, it should shift much quicker, as it does from 5th to 6th. I wil try the battery cable removal, it is an adaptive transmission.
Re: 2014 Elantra delayed shift 4th to 5th [Re: Propflux01] #5439343 05/26/20 12:57 PM
dubber09 Offline
I had similar thing, Forte would stay in 4th longer.
Drain and fill with MaxLife was an instant fix. This D/F was due, and I do D/Fs every 30K miles.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: 2014 Elantra delayed shift 4th to 5th [Re: dave1251] #5440323 05/27/20 05:39 PM
N
nicholas Offline
N
I second this idea.......
LG is some great stuff to help those shift solenoids.
2019 2.0T Santa Fe
2010 3.5 Santa Fe
