Forums Migration
Please read this thread
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
JDMorgan, sycboi, Chuck_Ellison, BakonBittz, ssoH
71870 Registered Users
87 registered members (ABN_CBT_ENGR, 4WD, 2015_PSD, 86cutlass307, aba4430, 77GrandPrix, 7 invisible), 1,636 guests, and 37 spiders.
Topics307,541
Posts5,312,730
Members71,870
Water drainage issue #5438581 05/25/20 04:39 PM
P
Paul_Siu Offline OP
P
Recently, I got hit with two mega rainstorm, both of them seemed to have dump 4-5 inches of rain in a day. The biggest problem is that the rain was severe enough that it actually overloaded the gutters. Even with no gutter clogged, water actually spilled over the side of the gutter because it wasn't carried away fast enough. Water got so bad that it pour into the window well and started coming through the window.
I am trying to solve multiple issues here.
1. The gutters drain into a tube out of the ground. In heavy rain storms, I notice that it doesn't seemed to carry away the water fast enough. This only seemed to happen on two of the gutters. I am now thinking of diverting it externally via a long elbow to the lawn where I hope the water will be diverted away from the foundation.
2. Gutter tend to get clogged with all sorts of weird stuff like string like seed, cotton like item. Pine needles. I am going to experiment with tryout out some leaf gutter at the most troublesome spot before paying the money to do the rest of the house.
3. The secondary sump pump keeps going off occasionally, which is not good. The primary should be enough to handle things. I currently have a sump pro battery driving the primary and a basement watchdog secondary. I haven't had a power outage that last long enough to drain both. Batteries are replaced every 5 years. I am debating that whether I need a stronger sump pump. When I purchased the house, it had a Hydromatic DA-1 with 1/3 hp. It worked for several years, but then I start noticing an issue where it wasn't keeping up, I upgraded it to a Liberty L289 1/2 hp. Now it's not keeping up. I am contemplating zoeller M98, but I am wonder if that will be enough. Keep in mind that most of the time the sump pump barely goes off, It's just that we often get these terrible large rain falls that seems to last for hours.
Has anyone notice an increase issue with rain? When I moved here 10 years ago, I never had issue with large rainfalls. Now it seems to happen more and more. I was wondering if anyone had experience dealing with this and whether I am on the right track?
Paul
Re: Water drainage issue [Re: Paul_Siu] #5438598 05/25/20 04:54 PM
M
MasterSolenoid Offline
M
You say, "a tube out of the ground"
Where does it go ? …. Is it plugged up ?
Gutters come in different sizes. What are yours ?
Several years ago, I replaced my (standard) 2"x3" Downspouts with 3"x4"
Good luck.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Water drainage issue [Re: Paul_Siu] #5438602 05/25/20 04:56 PM
E
edwardh1 Offline
E
mine was clogged by debris left by roofers, pieces of tar paper and pieces of flashing
find a kid with a drone to inspect
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Water drainage issue [Re: Paul_Siu] #5438614 05/25/20 05:03 PM
M
M
I clean my relatives gutters twice a year.
They are always filled with leaves & seeds from trees.
I put these filters at the tops of downspouts and it prevents them from getting plugged.
But would this help the OP, I don't know.
[Linked Image]
2 Wheel Drive
3.0 Liter Engine
Re: Water drainage issue [Re: Paul_Siu] #5438698 05/25/20 06:25 PM
cjcride Offline
For the window problem go to Youtube and search Window Well Drainage.
Re: Water drainage issue [Re: Paul_Siu] #5438782 05/25/20 08:06 PM
W
walterjay Offline
W
The Zoeller sump pump model that you are considering should do the job. If you are pumping about 8-10' in elevation it will give you about 60 gallons per minute. I have not been impressed with Liberty pumps and have avoided them.
Re: Water drainage issue [Re: Paul_Siu] #5438789 05/25/20 08:17 PM
dlundblad Offline
Oversized eves and spouts are a good start, but you never had this issue before?
Perhaps the drainage tile/ line has roots growing in it?
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Water drainage issue [Re: Paul_Siu] #5438791 05/25/20 08:19 PM
P
Paul_Siu Offline OP
P
I don't know what to call the drain out of the ground? French Drain? I do know that it carries water to an outlet pipe. To test it, I stuck a hose in it and ran it for 5 -10 minutes. It did not fill up, so clogging is not an issue. The big issue is that the pipe is corrugated and has hoses along the side, when the water is coming down, it spray out the side. I coat it the inside and outside with some rubberize coating, which did help, but too much water leak out the sides.
The gutter are not clogged. The house came with 4 inch wide gutters. After they got damaged by a storm, I replaced them with 5 inch gutter. Apparently, 5 inch gutter are enough 99% of the time but not last week's storm. I think the storm was unusual, all of my neighbor had issue with water going into the window well. The window well has a drain that drains into the weeping tiles, but apparently, the water was coming in faster the drainage can drain.
In my latest update, I routed the downspout with the most water to the driveway because it's steep downhill. If this work I may divert it to the lawn since it may erode the pavers
Re: Water drainage issue [Re: Paul_Siu] #5438868 05/25/20 09:56 PM
B
bcossa2001 Offline
B
About how many square feet is your roof and what is the slope?
How many feet of gutter is on your house???
Finally, how many downspouts do you have and how large are they?
I can run some calculations if you can give me the above information....
"Facts are pesky things"
2003 Town & Country--143 k
2016 Fusion 8 k
2016 Fusion 40 k
2017 Santa Fe 8k
Re: Water drainage issue [Re: Paul_Siu] #5438875 05/25/20 10:03 PM
T
Triple_Se7en Offline
T
I prefer external. Make sure your downspout gutter extension is running at least 6ft from the house and depending on soil, you may need to carve away / remove grass and redirect water flow further away from the house. Make sure your dirt height has a slight pitch - highest level of ground dirt at the house - then running slightly lower the rest of the route that the gutter water travels. Your dirt height should always cover the foundation against the house. Build that up.... intending as a barricade wall of dirt if necessary.
Fixing gutters so they flow correctly and direct proper is an easier fix than redirecting water flow at ground level sometimes.
Stay Safe - Stay Healthy
Do a 2nd thought, before walking down the wrong path
Keep Your Korean TGDI / GDI engines clean-4k OCI
Pennzoil Ultra Platinum // Mobil-1 EP // Valvoline Synthetics
Re: Water drainage issue [Re: Paul_Siu] #5439110 05/26/20 08:31 AM
dinofish Offline
Yes, much, much more rain and hardly any snow. Complete opposite from a decade ago. I hope they fix this global warming. Actually, I noticed a substantial increase in rains in the past four years.
Re: Water drainage issue [Re: dinofish] #5439115 05/26/20 08:41 AM
K
kschachn Online Content
Online Content
K
What ever next.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Water drainage issue [Re: bcossa2001] #5439179 05/26/20 09:55 AM
P
Paul_Siu Offline OP
P
Thank you. I am entire sure about the square foot, but the floor is 1500 sq ft.. There are 6 downspouts that are 4" x 3". The room appears to be 45 degree.
The majority of the issue comes from 2 of the rain gutter at the front that divert water from the attached garage and the water from the roof next to the garage. The water from the roof empties into the garage roof which then goes into the garage gutters. This means the garage gutter does twice the work of the other gutters.
Previously with the old gutters, when the rain is super heavy, the water coming from the roof gutter will shoot over the garage gutter due the velocity. When the roofers redid the gutter, they angled it so that it would shoot across the garage roof instead and also place it closer to the garage gutter. This worked fine, but last week I notice that when it rain super hard and I notice that the water was still overflowing from the gutter even with no clog from the garage gutters. However, it appeared we might had about 10 inch of rainfall in about last week, most of it on 2 days (average rainfall is 1 inch per week), that is unusually high. Actually, my concern is that this is the new normal and I have to figure a way to mitigate that.
Paul
Re: Water drainage issue [Re: Triple_Se7en] #5439182 05/26/20 10:00 AM
P
Paul_Siu Offline OP
P
One reason I like external is that stuff eventually falls down down downspout and there is a risk of clogs. Due to erosion, I probably have less dirt than I used to. I have been meaning to build that back up, so think you for the reminder.
Another reason to is that buried piped often collapse. My neighbor's sump pump backed up because his drainage pipe appeared to have collapse. The main difference is that his pipe appears to be corrugated while mine appears to be PVC. Mines didn't collapse but I do have to clean out roots growing into the pipe, which can be like 50 feet in length.
One reason to use the buried pipe is that the emptied water tend to create sheets of ice during the winter. Emptying it into the ground eliminates that.
Paul
Re: Water drainage issue [Re: MasterSolenoid] #5439199 05/26/20 10:23 AM
P
Paul_Siu Offline OP
P
[Linked Image]
Thanks I need way more than this unfortunately, the whole gutter in certain time of the year gets filled completely with leaves.
Paul
