Forums Migration
Please read this thread
1992 Chevy 1500 Truck
by HowAboutThis - 07/09/20 12:01 PM
Window Tint
by The Critic - 07/09/20 11:59 AM
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
107 registered members (4WD, 28oz, 2015_PSD, 2004tdigls, 77GrandPrix, 77Se7en, 12 invisible), 1,995 guests, and 46 spiders.
Topics307,640
Posts5,314,813
Members71,897
Atf for my E4od #5438546 05/25/20 04:04 PM
R
R1jake Offline OP
R
After all of my research I am not sure maxlife would be good for my 94 E150 so I was going to go with mobile 1 synthetic ATF. now I’m finding it’s only available in quarts which puts it higher than I would pay for amsoils best. I so wish I knew that maxlife would be good for my application being it’s quite a bit cheaper and great stuff. Money isn’t really the concern though. I want what is the best to run in my E4OD and just can’t decide. At this point I’m thinking amsoil would be best.
Yamaha R1 5vy
94 Ford E150
09 Pontiac vibe AKA Toyota Matrix
02 dodge neon my winter car, refuse to drive my van in the salt.
Re: Atf for my E4od [Re: R1jake] #5438587 05/25/20 04:42 PM
K
krismoriah72 Offline
K
26 year old transmission...
Stick with what got u this far. (or dont change it at all).
I will let others chime in but i probably wouldnt go with a full syn.
Re: Atf for my E4od [Re: R1jake] #5438659 05/25/20 05:47 PM
slacktide_bitog Offline
Maxlife will be fine it the van calls for a Mercon type ATF smile
Re: Atf for my E4od [Re: R1jake] #5438662 05/25/20 05:48 PM
B
bullwinkle Offline
B
We had a LOT of trouble with those in E250s & E350s of that era, seemed like mounting the biggest auxiliary cooler we could fit, and NEVER towing in overdrive was the best way to lengthen the service life on them. We had an E350 cutaway 14 foot box truck with the 351 (modified?) and E4OD that was rebuilt THREE TIMES in 150K miles! They would run hot, burn the OEM Mercon, and major problems would result, including front pump issues. If you don't go syn, put on a BIG external cooler, and I would run a deep trans pan with a gauge to monitor fluid temperature-it'll be worth every penny!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Atf for my E4od [Re: R1jake] #5438671 05/25/20 05:53 PM
dogememe Offline
A high viscosity quality full syn ATF... AMSOIL (Not the "fuel efficient" version) or Royal Purple Max ATF or something else comparable.
Alternately whatever Dex/Merc you find for cheap but change it every 30K miles.
2010 Ford Escape 2.5 ~104K Miles: AMSOIL Signature Series 0W-30, Wix Filter.
2001 Chevy Suburban 5.3 ~293K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Atf for my E4od [Re: bullwinkle] #5438684 05/25/20 06:03 PM
L
Lubener Offline
L
I remember our work van, E150 had an E40D that burned up on us on the freeway with a smoke screen behind us.
The "thinking" man's friend.
Re: Atf for my E4od [Re: R1jake] #5438726 05/25/20 06:53 PM
R
ripcord Offline
R
My strategy with my old 96 F-250 has been to use the cheapest regular dex/merc I could find and change it every 15K to 20k miles. At least up to 96, there is a drain plug in the torque converter so you can replace 12 or 13 out of 16 quarts with every change. It seems to have worked well with mine, as it's made it to 190K so far.
Re: Atf for my E4od [Re: krismoriah72] #5438745 05/25/20 07:17 PM
R
R1jake Offline OP
R
26 year old transmission with 29,000 miles on it. Picked it up a couple years back with 19,800 miles on the van absolutely mint. I want to keep it nice. I do have paperwork where the sellers had it all gone over and serviced at the dealership after a long sit in a garage. The dealership used motorcraft mercon v. I want a synthetic In it.
Yamaha R1 5vy
94 Ford E150
Re: Atf for my E4od [Re: bullwinkle] #5438747 05/25/20 07:19 PM
R
R1jake Offline OP
R
Definitely going synthetic I’ve heard plenty of horror story’s on this trans. Also getting a cooler installed.
Yamaha R1 5vy
94 Ford E150
Re: Atf for my E4od [Re: ripcord] #5438751 05/25/20 07:23 PM
R
R1jake Offline OP
R
My plan is synthetic and adding a drain plug to the pan to replace 5 quarts every oil change. I only use this van on vacations and joy rides to keep it from sitting so at 3,000 miles I change it twice a year at most. I think it’s almost 3 years I’ve had it now and put 10,000 on it.
When removing pan and draining convertor after all is together and time to add fluid is it best to add half first then run it a bit and add the other half?? Surely you can’t just throw all 13 quarts in at once.
Yamaha R1 5vy
94 Ford E150
Re: Atf for my E4od [Re: R1jake] #5438759 05/25/20 07:38 PM
B
blufeb95 Online Content
Online Content
B
If you're gonna replace it that often just use the finest harvest king you can find at your local rural king, only $20 for a 2 gallon jug of Dex3/Merc
Re: Atf for my E4od [Re: R1jake] #5438768 05/25/20 07:55 PM
R
R1jake Offline OP
R
Only going to replace 5 quarts of it probably once a year possibly twice. Out of 16 or so quarts it holds it’s not much. So more like on one of my possible 2 oil changes per year.
Yamaha R1 5vy
94 Ford E150
Re: Atf for my E4od [Re: R1jake] #5438769 05/25/20 07:58 PM
R
R1jake Offline OP
R
What’s this transmission additive I hear all the time good for?? Think it’s called lubegard red?
Yamaha R1 5vy
94 Ford E150
Re: Atf for my E4od [Re: R1jake] #5438796 05/25/20 08:25 PM
B
bullwinkle Offline
B
I'm not sure Mercon V is the correct fluid for it (although Ford may have superseded the original Mercon since then), but there are many good synthetic Dex/Merc ATFs out there, I use (pricy) Red Line D4 in my F-450's parking brake unit, and there have been good reports on (now fully synthetic) Maxlife ATF. I've just only used (Dexron III) Mercon in them.
Re: Atf for my E4od [Re: R1jake] #5438806 05/25/20 08:34 PM
K
kstanf150 Offline
K
Amazes me how stories blossom into real life truth around here
OP had a low mileage Ford with an E4OD tranny and there’s already a future problem that hasn’t even happen yet
Give me some lotto numbers !!!!!
