Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
19 registered members (carviewsonic, Alaskanmont, blufeb95, Capt, ChristianBerg, 4 invisible), 675 guests, and 29 spiders.
Topics307,747
Posts5,316,934
Members71,910
FJ cruiser knock sensors #5438529 05/25/20 03:51 PM
Chris142 Offline OP
Our FJ threw a p0333 code. It is a problem with a knock sensor. Labor to replace it is 20+ hrs which includes removing the cylinder heads!
I saw a video where a guy was hacking stuff up with a sawzall to do this job faster. anybody familiar with this terrible engine design?
The car is currantly in limp mode and unsafe to drive.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: FJ cruiser knock sensors [Re: Chris142] #5438557 05/25/20 04:12 PM
CT8 Offline
I had a 92 v6 3 litre truck and the knock sensor was under the intake manifold
2015 F150 2.7
2018 F350 6.2
Re: FJ cruiser knock sensors [Re: Chris142] #5438558 05/25/20 04:13 PM
slacktide_bitog Offline
I just looked it up real quick, and apparently it's usually from animals chewing up the wires crzy
Would it be possible for you to relocate the knock sensor? I have heard of people doing this on some cars
Re: FJ cruiser knock sensors [Re: Chris142] #5438571 05/25/20 04:26 PM
02SE Offline
Most likely mice or rats chewing the wires right at the knock sensors. They are in a difficult spot under the intake plenum. But if you have someone with small hands, and it is indeed chewed wires, you can get the old connector off the knock sensor, solder on a new connector, re-connect it, and likely be good to go.
Re: FJ cruiser knock sensors [Re: 02SE] #5438638 05/25/20 05:22 PM
Chris142 Offline OP
Ya we went camping friday night.
Re: FJ cruiser knock sensors [Re: Chris142] #5438667 05/25/20 05:51 PM
E
eljefino Offline
E
See if you can get in there with an endoscope?
Re: FJ cruiser knock sensors [Re: eljefino] #5438784 05/25/20 08:08 PM
Chris142 Offline OP
It is under the intake as well as under an edge of the head.
Re: FJ cruiser knock sensors [Re: Chris142] #5438837 05/25/20 09:13 PM
02SE Offline
If it turns out to be the sensor(s) themselves, you can get those out (once the intake plenum is removed) with a slim 13mm (IIRC) box-end wrench and some ingenuity. But most likely rodents crawling up there to enjoy the residual heat radiating from the block overnight, and chewing on the tasty insulation on the wires right there.
I hate rodents. shoot
Re: FJ cruiser knock sensors [Re: 02SE] #5438879 05/25/20 10:13 PM
Chris142 Offline OP
Can I block the entrance? Foil?
Re: FJ cruiser knock sensors [Re: Chris142] #5438892 05/25/20 10:40 PM
02SE Offline
Not really, they can get there from numerous points. Of course you need to confirm that it is chewed wires first. There are products available that claim to deter them. Such as Peppermint oil sprays. Moth balls has supposedly worked for some.
It probably wouldn't hurt to wrap the wires in foil as a possible deterrent, but the trick would be getting hands in there to wrap them.
Re: FJ cruiser knock sensors [Re: Chris142] #5438947 05/26/20 02:32 AM
02SE Offline
Thinking about it, I'm thinking it was a ratcheting wrench, and the sensor bolt is 12mm. That makes more sense as Toyota rarely uses an oddball size like a 13mm.
Re: FJ cruiser knock sensors [Re: Chris142] #5438966 05/26/20 03:54 AM
The Critic Offline
2020 Ram 1500 5.7L eTorque - <1K - Factory Fill
2011 Toyota Prius 1.8L - 209K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: FJ cruiser knock sensors [Re: 02SE] #5438975 05/26/20 04:40 AM
W
WyrTwister Offline
W
I have watched videos where Eric O. wrapped with with a Rodent tape , containing Capsaicin , made by Honda , to repel rodents .
Wyr
God bless
Re: FJ cruiser knock sensors [Re: The Critic] #5439291 05/26/20 12:02 PM
02SE Offline
Originally Posted by The Critic
It can be done without cutting through the pipe supports, but it is tricky. Still better than pulling the heads just for knock sensors.
Re: FJ cruiser knock sensors [Re: Chris142] #5441355 05/28/20 09:25 PM
Chris142 Offline OP
My friend and I got it done. Removed the intake then were able to pull the wires up and crimp the replacement onto the existing wires. It's tight and there is no way to replace those sensors without getting those pipes out or the heads off.
Very poor design.
