Blue Driver OBDII
Al
Elizabethtown, Pa
After much research I bought one. Totally impressed. And I don't impress easily. 24/7 tech support. Online videos. You put in the vin# of your vehicle and it knows everything about the vehicle. Recalls, technical bulletins, maintenance requirements, data points that can be used and it can display only those. They list a phone # to call right on the module. Its very short so it doesn't stick out much. You can set it up for multiple vehicles and when you move it select the vehicle.
One thing I initially saw when I set it up was it noted the hi and lo value for a particular trip/period. I now don't remember how I did it. Maybe I was dreaming..lol. I put in a question to email. Did not get an answer. I should have called but since I already submitted the question I didn't bother.
Any have one and knows the answer here?
Originally Posted by rubberchicken
I have a Blue Driver, but I do not know the answer. I will try to check on it tomorrow.
They said it can't be done. They liked the idea. Maybe they will change the software.
