Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
87 registered members (97tbird, 555, 928, 2015_PSD, 55Test, addyguy, 14 invisible), 1,478 guests, and 29 spiders.
Topics307,432
Posts5,310,888
Members71,847
2012 Dodge Charger patrol car alternator meltdown #5438304 05/25/20 11:25 AM
IMSA_Racing_Fan Offline OP
When I took over the car there was a faint odor that I couldn't pin down, sniffed all around the dash and under the hood. About an hour into the shift smoke was coming out of the hood. No warnings at all in the information center. Shut it down, popped the hood again and found the alternator smoking. It didn't stop, in fact got worse. Grabbed my Leatherman out of my bag and it took all my strength to break loose the 10mm negative battery bolt in the trunk.
Re: 2012 Dodge Charger patrol car alternator meltdown [Re: IMSA_Racing_Fan] #5438328 05/25/20 11:40 AM
V
Vladiator Offline
V
Back when I had a 2001 Lexus IS300 I actually had the alternator wire catch on fire while I was driving. Came to a stop, put out the fire (wasn't much). Turned out that wire somehow got loose in the crimped connector that bolts to the alternator, and created enough spark to light the insulation. After little re-crimping (thankfully had my Avionics tool bag in the trunk) it was back to life. Changed that cable same week, no issues afterwards.
0W20 in summer at Death Valley is as good as 25w70 in winter at Alaska. Both can be done, neither is good for the engine long term. Oil grade is chosen by CLIMATE and OPERATING CONDITIONS.
Re: 2012 Dodge Charger patrol car alternator meltdown [Re: IMSA_Racing_Fan] #5438330 05/25/20 11:43 AM
Nick1994 Offline
Is it part of the recall? My grandpa's 14' Grand Cherokee had the alternator recalled for this being a common problem.
A friend of mine who owns a mechanic shop had some car with the Pentastar come in with a melted down alternator. He found it had a recall and called the Dodge dealer who had it towed there and fixed for free.
2015 Hyundai Genesis 5.0L 62k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: 2012 Dodge Charger patrol car alternator meltdown [Re: Nick1994] #5438343 05/25/20 11:52 AM
I'll pass this on thanks.
Re: 2012 Dodge Charger patrol car alternator meltdown [Re: IMSA_Racing_Fan] #5438351 05/25/20 11:58 AM
E
eljefino Online Content
Online Content
E
I had a starter where the braided connection between solenoid and motor corroded, until one day it had enough and turned red hot before vaporizing in a stinky, oil-soaked "poof".
I know it was red hot, because I thought, gee that's weird, and had someone hit the key while I went looking for what's wrong.
Re: 2012 Dodge Charger patrol car alternator meltdown [Re: IMSA_Racing_Fan] #5438355 05/25/20 12:01 PM
1
14Accent Offline
1
Dodge Charger recall S68
There's actually two separate recall's on those cars, one for the 160A alternator used in most of the civilian cars, and the one above that's specifically for the 220A, police package equipped Chargers. The S68 recall directly calls out "rapid thermal failure of the internal diode's causing a possible short to ground situation". Sounds like what you experienced.
Mopar recall check
You can punch your VIN into that site and see if the recall is still open on your car.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: 2012 Dodge Charger patrol car alternator meltdown [Re: IMSA_Racing_Fan] #5438518 05/25/20 03:36 PM
AZjeff Offline
Sounds like this is a problem for his fleet manager.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 2012 Dodge Charger patrol car alternator meltdown [Re: AZjeff] #5438674 05/25/20 05:57 PM
M
Mazomopar Offline
M
How come that never happens when they're in my rear view mirror with all their lights running..
