Forums Migration
Please read this thread
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
sycboi, Chuck_Ellison, BakonBittz, ssoH, Sumpter_al
71869 Registered Users
83 registered members (86cutlass307, 2010Civic, 2009Edge, AndyB, alarmguy, ajchien, 11 invisible), 1,206 guests, and 28 spiders.
Topics307,536
Posts5,312,678
Members71,869
MMO vs Oil Consumption. #5438298 05/25/20 11:19 AM
V
Vladiator Offline OP
V
Here I am sharing my more recent experience with MMO and hope it helps some who may experience a similar issue with their vehicle.
Vehicle is a 2000 Honda CR-V, AWD and 5-speed manual. I became its owner at 201k miles, it currently has 210k miles. I started adding 4oz of MMO per 10 gallons of fuel on every tank, without adding anything to the oil. Wanted to see if it consumes any. Over the first few fill-ups I had to add 1qt of oil per every full tank of gas driven. That rate increased with longer highway drives, and high RPMs. Also on Higher RPMS (4500-6500) there was a mild visible blue smoke cloud out of the tail pipe. At 206k mies I added a quart of MMO to the oil instead of the now usual top-off at fuel fill-up. Since adding that one botttle of MMO to the crankcase I did not have to add any more oil as it stays at the full mark on the dipstick.
Almost 210k as of this morning, still at full mark. And no more smoking out of the tail pipe when I have to rev it up on highway ramps. Driving style did not change, still same ratio of city vs highway driving.
Just my experience, take it with a grain of salt. Not claiming it to be a fix-in-the-bottle for any engine problems, but it certainly does have it's place and works well, at least for me.
2000 Honda CR-V 2.0L I4, RTAWD and a 5-speed manual. 215k miles.
2010 Volvo XC70, 3.2L I6 AWD. 255k miles.
2006 Toyota Camry 3.0L V6 FWD 200K miles.
2000 Lexus GS300 3.0L I6 RWD 365k miles.
Re: MMO vs Oil Consumption. [Re: Vladiator] #5438329 05/25/20 11:42 AM
R
ripcord Offline
R
Sounds like you might have a gummed up oil ring. Since it seemed to work well for you, maybe you should consider a few shorter oil change intervals adding a pint of MMO per change.
Re: MMO vs Oil Consumption. [Re: Vladiator] #5438390 05/25/20 12:44 PM
P
pandus13 Offline
P
Hello OP/Vladiator.
User Demarpaint has used for many many years MMO using an "oiler" in his older vehicles over many miles.
I personally used in 3 of my vehicles ('04 Hyundai Elantra, '08 Toyota Yaris, '13 Mazda5), but the vehicles where in very good shape and burned no oil. Both in gas and oil, before a change. So I used more for my peace of mind.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: MMO vs Oil Consumption. [Re: Vladiator] #5438400 05/25/20 12:52 PM
7
71Chevyguy Offline
7
I know it has been discussed at length that this stuff isn't some miracle cure and makes no sense to use regularly,also can affect certain gaskets negatively. I do have to admit that I have had success with many vehicles that were either really abused or neglected. I won't say it will cure all problems or necessarily prevent them from happening, but I feel it has its place for many situations. I won't say I use it unless I need it, but I have used it with great success when working at a used car dealership before. That way I got to see that it fixed the issues at the time and they didn't come back. The vehicles were fine when they came back for further maintenance over and over again. My only concern with it is that it is very thin and thins out the oil if you put in an entire bottle. I always used heavier oil when adding a decent amount of it to the crank case.
14 Jetta Sportwagen TDI
14 Beetle TDI
98 Buick LeSabre Defy 10w30 / Fram Ultra 3387a
Re: MMO vs Oil Consumption. [Re: Vladiator] #5438422 05/25/20 01:18 PM
Z
Zaedock Offline
Z
I'm glad you had good results!
I've been using MMO as an UCL for years, especially in OPE's. With all the recent talk of MMO, I went ahead and added a quart to my son's new-to-him 1987 Wrangler with the 258. The Jeep has been sitting for at least a decade to 15 years and was only started periodically. I'm hoping it does some cleaning.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: MMO vs Oil Consumption. [Re: 71Chevyguy] #5438423 05/25/20 01:22 PM
V
V
That may have been the case, as the maintenance history is unknown.
Originally Posted by pandus13
Hello OP/Vladiator.
I am really looking into getting a top end oiler for the 2013 Volkswagen Tiguan, as it is direct injection and those 2.0TSi engines could really use something to clean the intake valves. Still researching. Maybe water/methanol injection is what I'm going to go with.
Agreed. I had Pennzoil SRT 0w40 in the crankcase, and used same oil for top-off as well, as that is what I had in my stash. I put that oil in as soon as I got the CR-V, then changed the oil filter at 205K, as I was topping oil off so often that it made no sense to drain whatever was in there. Between 201k and 206k I added 17 quarts of Pennzoil SRT 0w40. Then added a quart of MMO and level stayed at full since then, from 206k to 210k now. Put that much oil in there hoping that Pennzoil will clean something up and reduce consumption, but that didn't happen after 21 total quarts of oil (4qts initial OCI and 17qts of top-offs). But with MMO results were pretty quick, thankfully.
Re: MMO vs Oil Consumption. [Re: Zaedock] #5438425 05/25/20 01:27 PM
V
V
I really hope so, and have no doubts in MMO. If there are no mechanical issues, then you should see improvement soon.
Re: MMO vs Oil Consumption. [Re: Vladiator] #5438431 05/25/20 01:35 PM
K
kschachn Offline
K
I still would like to know what it is in the UC that isn't being L by the oil and needs a UCL.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: MMO vs Oil Consumption. [Re: ripcord] #5438440 05/25/20 01:45 PM
G
GSCJR Offline
G
This. ^^^^
Which is good news!
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 158KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: MMO vs Oil Consumption. [Re: Vladiator] #5438448 05/25/20 01:56 PM
R
ripcord Offline
R
Vladiator, 25% MMO seems kind of high. I wouldn't leave it in there like that as that is more than even the recommendation on the bottle.
Re: MMO vs Oil Consumption. [Re: ripcord] #5438570 05/25/20 04:25 PM
V
V
Bottle says up to 20% of total volume. I'm at 25%, but after taking it on a 500-mile trip this weekend (4 adults, a baby, plus all beach gear in hatch/trunk and on roof rack) it didn't burn any oil and had no abnormal sounds/lights/etc. I guess 3qts of 0w40 and 1qt of MMO kept the overall viscosity close-ish to a "light" 30-grade. I'll be changing the oil this weekend and will go with full capacity of Pennzoil SRT 0w40 to see if oil consumption is gone, or if it will try to make a comeback, which I highly doubt.
Re: MMO vs Oil Consumption. [Re: Vladiator] #5440735 05/28/20 08:44 AM
P
pandus13 Offline
P
on the vwvortex forums, there was one DI Golf user who made a contraption to connect a sprayer through a port for cleanup.
every 10k miles and he used connectors available at big box stores.
he used a mixture of gas + couple others ingredients as a "wash"/cleaning agent.
My memory is a bit rusty but he had an youtube video also....
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: MMO vs Oil Consumption. [Re: Vladiator] #5456651 06/18/20 08:06 AM
03s Offline
I've been using Marvel Ultimate Fuel and Motor Treatment since last summer, threw 1/4 bottle in with the oil and it ran smoother and also added a few ounces occasionally when I put gas in. Last oil change added 1/2 bottle and have started putting in a couple of ounces when i put gas in regularly. Does anyone know the difference between this and MMO? All I could find online is that seems to for newer GDI and Hybrid engines and High Mileage engines.
2005 Chevrolet Optra
Quaker State High Mileage Synthetic 5W30 Fram Tough Guard TG3387A
Re: MMO vs Oil Consumption. [Re: Vladiator] #5457180 06/18/20 06:21 PM
V
V
I got my 2000 Honda CR-V, (AWD and 5-speed manual), at 201k miles. Put Pennzoil SRT 0w40 as first oil change, and between 201k and 206k I ended up adding another 17 quarts of oil, due to oil consumption. Then added 1qt of Marvel Mystery Oil, and did not have to add any oil since then. 212Kmiles now, oil stays at the level that I fill it up to throughout the full oil change interval. Worrth a shot at less than $4 per quart from Wal-Mart. And if it does not help - your engine is at least a little cleaner inside.
Re: MMO vs Oil Consumption. [Re: Vladiator] #5457438 06/19/20 05:52 AM
T
Triple_Se7en Offline
T
That's interesting. Your Honda was using almost three quarts per thousand miles.
How much oil does your Honda hold?
Stay Safe - Stay Healthy
Do a 2nd thought, before walking down the wrong path
Keep Your Korean TGDI / GDI engines clean-4k OCI
Pennzoil Ultra Platinum // Mobil-1 EP // Valvoline Synthetics
