Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
87 registered members (antonmnster, 4WD, andy2001, Alfred_B, Arrechera, Atrocious, 5 invisible), 2,088 guests, and 23 spiders.
Topics307,450
Posts5,311,404
Members71,850
Oil filter – clean/empty – reuse #5438269 05/25/20 10:40 AM
2
2K2AcuraTL Offline OP
2
Yes…. its beckons to be asked… WHY…??? just why?? Or why bother…?? Yes, go ahead and roll your eyes here… LOL
Here is it…. I have a new to me, Husq lawn tractor [ 59 hours on the clock when I got it.. ] has gas seeping in crankcase issue, I discovered when I did my first OCI. Yes most likely a float/needle issue I plan to address as soon as I can find a suitable replacement carb.
Since then, I’ve installed a gas shutoff valve on the fuel line and did 3 OCI.
On one of those OCI I drained and reinstalled the same filter as it had less than one hour service, so IMO its still a new filter…. gas in new oil smell remains - suspect it came from the filter and possibly residual gas-oil in the sump..
This filter is now drained [ 95%? ] sitting open in my shop… just letting it air out.. until next year or whenever..
Has anyone ever tried to clean/clear out a filter of oil/contaminants…??
Yah it seems silly… thought id ask before I start tossing new filter in the recycle program… im funny that way.
Any constructive or face-palm comments welcome… 😉
Cheers
J.
2002 Acura TL-P --- 2013 Acura MDX-Elite --- 2008 Civic
ALL on PP and PP Ultra & Petro-Can Duradrive synth ATF
2007 Chev Trailblazer LT
1998 Pontiac Transsport
1984 Firebird SE
Re: Oil filter – clean/empty – reuse [Re: 2K2AcuraTL] #5438273 05/25/20 10:50 AM
wwillson Offline
Administrator
Administrator
I don't know how you would remove contaminants without destroying the filter, but what solid contaminants could there be? Gasoline will eventually evaporate out over a few weeks. With one hour on the filter, it's brand new and can be used.
Re: Oil filter – clean/empty – reuse [Re: 2K2AcuraTL] #5438276 05/25/20 10:51 AM
IMSA_Racing_Fan Offline
What does a filter cost?
What does an engine cost?
Re: Oil filter – clean/empty – reuse [Re: 2K2AcuraTL] #5438349 05/25/20 11:57 AM
danez_yoda Offline
How does tht gas affect the rubber antibackflow valve. I'm sure it will shorten its life.
Re: Oil filter – clean/empty – reuse [Re: 2K2AcuraTL] #5438356 05/25/20 12:03 PM
T
Triple_Se7en Offline
T
95% contents removed and it's been hardly used and somewhat recently purchased?....... then reuse it.
Sleep well.
Stay Safe - Stay Healthy
Think things out - b/4 jumping on the wrong daily path.
Keep Your TGDI / GDI engines clean....4k OCI.
Pennzoil Ultra Platinum // Mobil-1 EP // Valvoline Synthetics
Re: Oil filter – clean/empty – reuse [Re: wwillson] #5438447 05/25/20 01:56 PM
2
2
indeed i wasnt worried too much about solid contaminants... it was more about removing the little gaz contaminated oil left behind..
also, as mentioned above... i suspect the gas will vap-off over time
1984 Firebird SE
Re: Oil filter – clean/empty – reuse [Re: 2K2AcuraTL] #5438470 05/25/20 02:32 PM
Z
ZeeOSix Offline
Z
Only way you could "flush" out the filter of old "gassy" oil is fill it with new oil through the center tube until it won't take any more. Then turn it base down and let the oil drain out. After that, take a couple of Q-Tips and bend them in half and carefully put them into a couple of the ADBV inlet holes in the base to crack open the ADBV, then put the filter base down in a funnel and let the rest of the oil drain out. That will only flush out any old oil. Anything debris trapped in the filter media will stay there, which won't hurt anything.
Or you could just use a new filter since it sounds like a lot of hassle. grin2
Re: Oil filter – clean/empty – reuse [Re: wwillson] #5438485 05/25/20 02:47 PM
CR94 Offline
... Gasoline will eventually evaporate out over a few weeks. With one hour on the filter, it's brand new and can be used.
Exactly. There won't be enough fuel left in the filter to matter, compared to fuel that might get into the oil. Just use it!
2011 Toyota Prius now at 111K
Re: Oil filter – clean/empty – reuse [Re: 2K2AcuraTL] #5438650 05/25/20 05:38 PM
dwendt44 Offline
The 3614 Fram is $4 at Wal-mart. Their house brand, Supertech 3614 is $3.
Just change it and forgetaboutit.
My ¢
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Oil filter – clean/empty – reuse [Re: 2K2AcuraTL] #5439325 05/26/20 12:34 PM
Yah-Tah-Hey Offline
WHY?
Re: Oil filter – clean/empty – reuse [Re: 2K2AcuraTL] #5439425 05/26/20 02:35 PM
DGXR Offline
:rolleyes: OK I got that out of the way laugh
If you must reuse a filter, just wipe off the exterior and put it back on. Do not try to clean the insides, you will do much more harm than good.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
Re: Oil filter – clean/empty – reuse [Re: dwendt44] #5439446 05/26/20 03:05 PM
Malo83 Offline
My ¢
x2, duh
Re: Oil filter – clean/empty – reuse [Re: ZeeOSix] #5439628 05/26/20 07:03 PM
2
2
Interesting recommendation... just may try it...
thx
1984 Firebird SE
Re: Oil filter – clean/empty – reuse [Re: DGXR] #5439631 05/26/20 07:06 PM
2
2
thats what I thought as well on my first OCI ... wrong...!!... too much gas left in the filter.... brand new oil was immediately contaminated...
1984 Firebird SE
Re: Oil filter – clean/empty – reuse [Re: Malo83] #5439634 05/26/20 07:09 PM
2
2
My ¢
x2, duh
yah ok guys.. its only 3-4 bucks...maybe for you... we ALWAYS pay more for ordinary stuff up here... if I start throwing away good filters for nothing... it cut into me Scotch budget... wink LOL
1984 Firebird SE
