Forums Migration
Please read this thread
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
116 registered members (4WD, 1911CHAMPION, 2004tdigls, 55hambone, 77Se7en, 2015_PSD, 11 invisible), 1,758 guests, and 37 spiders.
Topics307,632
Posts5,314,629
Members71,894
APR dyno: Passat 2.0T 87 vs 93 Octane #5438216 05/25/20 09:31 AM
wemay Offline OP
A 21 hp difference?
https://www.goapr.com/
19 Passat Wolfsburg 2.0 TSi: Castrol Edge LL 0W-20
13 Santa Fe Sport 2.0T: Castrol GTX Magnatec 5W-30
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5438268 05/25/20 10:39 AM
Marco620 Offline
I'd believe that.More timing to work with.
15' Civic r18, 344,000 mi M1 5w30(3qt)/Redline 5w30(1qt),Castrol CVT Fluid,Redline Si-1
Doberman Whisperer! Honda/Acura nerd; detest ethanol,wind,"green" ,solar & vegan.
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5438284 05/25/20 11:05 AM
wemay Offline OP
I believe the APR numbers but also think the VW numbers are underrating the actual stock power. Many manufacturers do this.
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5438306 05/25/20 11:25 AM
Astro14 Offline
Makes sense - with a boosted engine, you can lose a lot of timing to prevent detonation.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5438333 05/25/20 11:45 AM
Y
y_p_w Offline
Y
Just remember that 2 AKI numbers is huge.
I remember the head of operations of the Honda Swindon factory talking with someone who was getting his Civic Type R delivered. He was mentioning that the "fuel requirements" were for a certain octane rating that I believe was for regular premium, but that a higher RON fuel would actually produce another 12 HP. He was using RON, but I believe what he was mentioning was equivalent to 91 and 93 AKI.
And it's really weird. Years ago I got into a discussion with someone about timing and knock sensors. His argument seemed to be that it was crazy to trust that a knock sensor would work all the time given that once there was severe detonation an engine would be toast. But these days nobody has a second thought about it.
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5438407 05/25/20 01:01 PM
B
benjy Offline
B
if you had a boost gauge you would see Vag cars are tuned very mildly!! 2001 1.8T jetta max 7 lb + a very restrictive exhaust. 2.5" + turbo back + apr tune for 93 octane woke it up boosting to 18 lb, my 2001 TT 1.8 T sees 25 lb at times, a fun car thats economical off boost + NO DI issues!! with port injection but not as powerful as DI offerings that controls knock better
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5438433 05/25/20 01:36 PM
O
oily boyd Offline
O
The low vs high octane hp would be valid if APR would have done same car/engine on their dyno wiht both fuels under similar atmospheric conditions ... otherwise too many variables. Interesting though, thanks for posting.
I have this engine in my 19 Tiguan. Came this close to buying the passat!
Kind Regards,
Boyd
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5438483 05/25/20 02:46 PM
R
Rand Offline
R
you dont have 2 results there to compare..
you have the manufacturer spec vs a dyno test.
but that result seems reasonable.
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: Rand] #5438494 05/25/20 03:01 PM
wemay Offline OP
Yes, agreed. But even in that context, the hp spread seemed too large. But from the answers here, I appear to be mistaken.
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5438503 05/25/20 03:17 PM
dparm Offline
I don't know a ton about the Passat implementation of the 2.0T, but that motor is available in numerous tunes across the VAG lineup. 20ish horsepower from higher octane doesn't seem that unreasonable, really. Modern knock sensors and ECUs are pretty good at making a whole range of fuel qualities work.
2017 Chevrolet Corvette Grand Sport
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5438595 05/25/20 04:49 PM
O
oily boyd Offline
O
No worries, mate... all in good fun!
I can tell you that i have put premium in my Tiguan a few times due to these low gas prices latley. No difference in fuel mileage or hp improvement on my arse dyno that i can feel, anyway.
Maybe try that yourself, maybe your car will respond well.
Kind Regards,
Boyd
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: oily boyd] #5438750 05/25/20 07:23 PM
wemay Offline OP
Hey oily,
I have, with equal results. I would think a 20hp increase would be noticeable. Fuel mileage was the same as well. We're on the same page it appears. Maybe it will be different now that it's broken 12k miles.
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5452397 06/12/20 08:17 PM
dareo Offline
On my old GSW 1.8 i had the IS20 87 octane tune and it was only 7lb ft of torque different between 87 an 91 octane levels, 18 peak hp. It's not much and i wanted to have a little more timing cushion for hot days or an iffy tank of 91. For my new Alltrack i think i will go the same, and get the APR Plus, its the same 87 octane tune but with APR covering the powertrain warranty.
2019 VW Golf Alltrack, 2018 Regal TourX, 2016 GMC 1500 SLT 6.2, 2007 GMC Savana 6.6 Duramax
Re: APR dyno: Passat 2.0T 87 vs 93 Octane [Re: wemay] #5452494 06/12/20 11:19 PM
U
UG_Passat Offline
U
1. VW has a history of under-rating the power and torque figures of their published specs. No surprises here.
2. Those APR figures are "crank" HP, which means it is estimated by some pre-determined fudge factor by the dyno software.
I prefer using wheel hp, because that is what the dyno is measuring. Most aftermarket companies don't have a water brake dyno, that large manufacturers have.
The figures that are screen captured is for the 1.8L TSI motor, not the 2.0T budack engine.
APR has cracked the security for the ECU, but tunes and hardware is still in development.
2016 VW Tiguan
