Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
103 registered members (72te27, 2010Civic, 18LateModelFan, 14Accent, 4WD, 8 invisible), 1,857 guests, and 23 spiders.
Topics307,462
Posts5,311,615
Members71,850
Frankenbrew question #5438188 05/25/20 08:40 AM
J
jdw1222 Offline OP
J
Need roughly 4 qts of 10-30 for a n205 transfer case
I have tons of 5w-20 and a bunch of 15w-40 laying around but don’t have any 30w
Can I mix 2qts of 5-20 and 2 qts of 15-40 together and be close ?
2013 Toyota Tundra
Re: Frankenbrew question [Re: jdw1222] #5438199 05/25/20 08:55 AM
Z
Zaedock Offline
Z
If it's the NP205, that case was spec'd from ATF to 80W90, so mixing the two oils you have would work.
Personally, unless it's chain driven, I like to use gear oil. I use Supertech 80W90 in the Dana300 in one of my project vehicles.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Frankenbrew question [Re: jdw1222] #5438272 05/25/20 10:50 AM
J
JimPghPA Online Content
Online Content
J
I would be concerned with the ability of the thinner oils molecules to keep the moving parts apart with the high loads inside a transfer case. If it were mine I would not chance it. Oil is cheap, transfer cases are not.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Frankenbrew question [Re: jdw1222] #5438398 05/25/20 12:48 PM
Z
Zaedock Offline
Z
Jim, are you referring to the protective film that EP gear lubes typically provide? If so, I agree.
I'm not sure gear driven T-cases operate without boundary lubrication (as opposed to any type of hydrodynamic action taking place - maybe under low loads?).
Re: Frankenbrew question [Re: jdw1222] #5438508 05/25/20 03:23 PM
N
nascarnation Offline
N
The US Army uses 15W40 in theirs (they like commonality of oil for the engine, transmission, and t-case) and it works fine.
Re: Frankenbrew question [Re: jdw1222] #5438700 05/25/20 06:27 PM
J
jdw1222 Offline OP
J
It is a chain drive.
2013 Toyota Tundra
Re: Frankenbrew question [Re: jdw1222] #5438833 05/25/20 09:09 PM
Z
Zaedock Offline
Z
If it's chain drive, then it's not a NP205. All NP205's are gear driven.
If it has a chain then it's a NP203 or NP208.
What vehicle is it in?
Re: Frankenbrew question [Re: Zaedock] #5439037 05/26/20 06:43 AM
J
jdw1222 Offline OP
J
Good catch. 100% sure It is a np203. It’s in a 74 f250. From what I have seen it is spec to run a 30 or 40w motor oil
2013 Toyota Tundra
Re: Frankenbrew question [Re: jdw1222] #5439039 05/26/20 06:47 AM
4WD Online Confused
Online Confused
I had one for 17 years … 15w40 Delvac and working good when sold to a ranch who took the plates off …
Re: Frankenbrew question [Re: jdw1222] #5439156 05/26/20 09:28 AM
Z
Zaedock Offline
Z
The spec back in the day was probably SAE30. Delvac 15W40 would be a good substitute and flow better when cold.
The 203 doesn't have a pump like other chain drive cases, so I wouldn't go too thick. Your Frankenbrew would be fine.
