CarbonSteel Joined Sep 26, 2010 Messages 9,791 May 25, 2020 #1 Saw this today and thought it was really cool to see an engine this old crank up and run. Enjoy!
B bullwinkle Joined Oct 9, 2004 Messages 14,506 Location Cincinnati, OH, USA May 25, 2020 #2 6000 pounds, 30 HP (if lucky), requires constant attention & lubrication to run, diesels have come a long way in 111 years!
Zaedock Joined Sep 10, 2005 Messages 5,532 Location Massachusetts May 25, 2020 #3 I'd love to participate in starting that bad boy up. Just the fumes would be motorhead heaven. Thanks for sharing!
OVERKILL $100 Site Donor 2021 Joined Apr 28, 2008 Messages 57,913 Location Ontario, Canada May 25, 2020 #4 So quiet! I was waiting for it to start for a bit there, lol
4WD $50 site donor 2024 Joined Sep 21, 2010 Messages 24,984 Location Texas via IAH May 25, 2020 #5 Finally … Rat 540's test jig exposed !!!
E ecotourist Joined Jul 9, 2008 Messages 4,418 Location British Columbia, Canada May 25, 2020 #6 Very cool. From an era when you didn't have to worry about exhaust, or even oil drips for that matter. Would be a great way to use up your (well filtered) used oil - as long as you needed a low horsepower engine that required constant attention.
R ripcord Joined Apr 1, 2020 Messages 4,486 Location Pacific Northwest May 25, 2020 #7 Very interesting. I wonder if it is a hit and miss engine? How does it control RPMs? This is the sort of line belt system an engine like this could have provided power for, though a factory that large most likely used a steam engine.
OVERKILL $100 Site Donor 2021 Joined Apr 28, 2008 Messages 57,913 Location Ontario, Canada May 25, 2020 #8 Originally Posted by 4WD Finally … Rat 540's test jig exposed !!!
AZjeff $50 Site Donor 2023 Joined Jan 14, 2011 Messages 8,622 Location in Az where the Deer and Antelope play May 25, 2020 #9 Wonder how many millions of revolutions it's made? It could use some bushing work in the pivots, quite visible play.
