Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
80 registered members (addyguy, 555, 928, 55hambone, Alfred_B, 02F250XLT, 17 invisible), 1,477 guests, and 32 spiders.
Topics307,430
Posts5,310,868
Members71,843
Collection of Euro Oils #5437977 05/24/20 10:29 PM
J
js1956 Offline OP
J
[Linked Image]
Approvals and Recommendations
M1
MB-Approval 229.3 MB-Approval 229.5 VW 502 00 VW 505 00 Porsche A40 Nissan Genuine Performances
EDGE
ACEA A3/B3, A3/B4 API SN/CF Meets Ford WSS-M2C937-A MB-Approval 229.3/ 229.5 Porsche A40 VW 502 00 / 505 00
PP
AMSOIL
MB-229.5 Porsche A40 VW 502.00, 505.00 BMW LL-01 GM LL-B-025 Renault 0700, 0710
2015 VW Golf Mk7 2dr HB Man 1.8 TSI S
Re: Collection of Euro Oils [Re: js1956] #5437996 05/24/20 11:05 PM
M
Mainia Offline
M
What about Redline Euro Series? 5W-30 and 5w-40? The 5w-30 has the low calcium if who ever is concerned about LSPI like I am.
2018 Lowered Hyundai Kona AWD 1.6T https://www.hyundaikonaforum.com/showcase/2018-kona-awd-1-6t-lowered.1162/
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Collection of Euro Oils [Re: Mainia] #5438014 05/24/20 11:26 PM
J
js1956 Offline OP
J
Sorry I've never used Redline so it wasn't on my radar. Just oils I have good experience with and thought some people might find it useful.
Re: Collection of Euro Oils [Re: js1956] #5438142 05/25/20 07:28 AM
dbias Offline
Castrol certainly goes about building their oil differently. The other 3 looks to be carbon copies of each other when comparing the listed parameters.
2011 VW JETTA RIP totaled at 180k 😥
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
2019 VW Jetta SE factory fill
Re: Collection of Euro Oils [Re: js1956] #5438270 05/25/20 10:44 AM
IMSA_Racing_Fan Offline
I was curious as to the titanium used by Castrol so I performed a search, found this report, and this is the conclusion.
When TiO2 nanoparticles were added to the engine oil, the co efficient of friction was reduced by 86% with 0.3% concentration by weight of the oil as compared to the oil without TiO2 nanoparticles for load 4 kg. This effect could be due to the rolling of the sphere like nanoparticles between the rubbing surfaces, thus reducing friction. With an increasing concentration of nanoparticles the co-efficient of friction increased but not more than the coefficient of friction of oil without TiO2 nanoparticles, this effect can be observed due to the agglomeration of TiO2 nanoparticles. The anti-wear mechanism can be attributed to the deposition of TiO2 nanoparticles on the worn surface, which in turn decreased the shearing resistance, thus improving the tribological properties. Nanoparticles can be considered as nano-bearings on the rubbing surfaces. The TiO2 nanoparticles are deposited only under mixed and boundary lubrication. Experimental studies report that the deposition of TiO2 nanoparticles on the rubbing surfaces improves the tribological properties of the base lubrication oil exhibiting reduction in friction and wear.
The wear of Aluminium alloy (Al 25) with time was observed to be increasing with an increased value of the load. However the wear was significantly reduced with TiO2 nanoparticles as additives for the same load value. Thus, TiO2 nanoparticles can be used as a multifunctional additive. The UV spectroscopic study indicates that TiO2 nanoparticles possess good stability and solubility in the lubricant.
https://www.sciencedirect.com/science/article/pii/S101836391600012X
Learn something new everyday.
Re: Collection of Euro Oils [Re: IMSA_Racing_Fan] #5438278 05/25/20 10:55 AM
J
js1956 Offline OP
J
I was wondering if you'd mix 50/50 M1 or PP with Edge and got the best of both worlds of Mo and Ti or would that have some adverse effects.
Re: Collection of Euro Oils [Re: js1956] #5438289 05/25/20 11:10 AM
K
kschachn Online Content
Online Content
K
One thing you'd get for sure is an oil with no licenses nor approvals.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Collection of Euro Oils [Re: kschachn] #5438315 05/25/20 11:30 AM
O
OVERKILL Online Content
Online Content
O
This. Oils are carefully balanced, and tested, formulas, just mixing two together and expecting to improve that performance is a fool's errand.
2020 Jeep Grand Cherokee SRT Ravenol SSL 0w-40, FRAM Ultra
Re: Collection of Euro Oils [Re: Mainia] #5438317 05/25/20 11:31 AM
O
Online Content
O
If you are talking about the black bottle products, the only thing "Redline" about them is the name on the bottle, they are just re-bottled CP oils.
Re: Collection of Euro Oils [Re: kschachn] #5438326 05/25/20 11:39 AM
J
js1956 Offline OP
J
Fair enough.
But the actual question was. would those two elements mix together have some adverse effect on a internals of engine,
In that example I posted above one oil has Mo and no Ti, and the other has Ti and no Mo.
Mo is sufficient enough that Ti is not necessary and other way around?
Amsoil has none of those two. What's their secret?
Just trying to understand the chemistry of antiware additives, purpose of each element and how they interact with each other.
Re: Collection of Euro Oils [Re: OVERKILL] #5438339 05/25/20 11:48 AM
J
js1956 Offline OP
J
"This. Oils are carefully balanced, and tested, formulas, just mixing two together and expecting to improve that performance is a fool's errand."
Agree and I don't want to be one of those. Just curious tho. about one. lack of other and why.
Re: Collection of Euro Oils [Re: js1956] #5438377 05/25/20 12:28 PM
53' Stude Offline
Please don’t mix the two. Kschachn and OVERKILL are trying to help you.
I mixed oils in a 97’ Bonneville that was a “spare/winter driver with over 270k on it. Did it
To use up excess oils I had.
Re: Collection of Euro Oils [Re: js1956] #5438413 05/25/20 01:09 PM
edyvw Offline
[Linked Image]
M1
EDGE
PP
AMSOIL
What is source of this? In all VOA Castrol Edge is 12.9-13.1cst.
Also, approvals and recommendations are not the same.
Recommendation means company is hiding something.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: Collection of Euro Oils [Re: js1956] #5438512 05/25/20 03:28 PM
O
Online Content
O
AW chemistries are chosen, and tested, in a particular application based on the desires of the blender, what they are trying to achieve and of course cost. Diluting those individual chemistries by 50% is unlikely to result in a synergistic blend that offers as good or better performance than those chemistries by themselves, if anything, the performance will be reduced, but by how much is not readily apparent. We do know of course that the result is untested.
