Forums Migration
Please read this thread
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
First time UOA. Questionable potassium levels
by chknkatsu - 07/06/20 07:38 PM
STP oil treatment
by wymi516 - 07/06/20 07:12 PM
Oil Life Monitor
by rrretiree7 - 07/06/20 06:57 PM
94 F 150 Engine control module replaced
by Electromotive - 07/06/20 06:43 PM
OIL UDDER Q+A
by OIL_UDDER - 07/06/20 05:46 PM
Devil's Lake State Park near Baraboo, WI
by wwillson - 07/06/20 05:43 PM
New vehicle bug bit me again
by JTK - 07/06/20 04:56 PM
2012 Ram 2500 Delvac 15W40 3,000 miles
by tnt_motorsports - 07/06/20 04:43 PM
BakonBittz, ssoH, Sumpter_al, Jeffham87, chknkatsu
71867 Registered Users
44 registered members (Bailes1992, 14Accent, bbhero, Alex38, Bonz, 2 invisible), 1,274 guests, and 46 spiders.
Topics307,526
Posts5,312,574
Members71,867
00 grease in my brush mower #5437959 05/24/20 09:55 PM
E
Elkins45 Offline OP
E
I decided my field needed a trim yesterday so I started my tractor which still had the 5’ King Kutter brush mower attached from last fall. I greased the PTO shaft and remembered to check the gearbox oil before mowing. It’s a good thing I did because it was empty. All the gear oil had drained out over the winter. I couldn’t find a replacement seal locally so I decided to attempt a fix that a lot of people apparently do when their oil seals fail, which is to fill the gearbox with 00 grease. Tractor Supply has cotton picker spindle grease for <$6 a quart. It comes in a squeeze bottle like gear oil and will squeeze through a spout but is just thick enough it didn’t leak out the bottom.
https://www.tractorsupply.com/tsc/product/super-s-cotton-picker-spindle-grease-00?cm_vc=-10005
I mowed an acre with the grease and the gearbox was still cool enough to touch. So far, so good.
Re: 00 grease in my brush mower [Re: Elkins45] #5437965 05/24/20 10:07 PM
N
NormanBuntz Offline
N
Nothing wrong with Smitty's.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 13K, 2nd owner
2007 Honda Ridgeline RTS, 98K, original owner
2007 Infiniti M35, 116K, original owner
Re: 00 grease in my brush mower [Re: Elkins45] #5437967 05/24/20 10:08 PM
J
jhellwig Offline
J
Corn head grease also works well in gear boxes. It comes in tubes instead of bottles as it is slightly thicker.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: 00 grease in my brush mower [Re: Elkins45] #5438081 05/25/20 05:56 AM
L
Lubener Offline
L
Good to know. So far my brush hog holds its oil well.
The "thinking" man's friend.
Re: 00 grease in my brush mower [Re: Elkins45] #5438798 05/25/20 08:26 PM
dlundblad Offline
Rotary cutters don’t get too warm. They’re slow spinning unlike a finishing mower.
I’d not run the machine until the seal is fixed. Grease isn’t gear oil.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: 00 grease in my brush mower [Re: dlundblad] #5438850 05/25/20 09:27 PM
E
Elkins45 Offline OP
E
Apparently King Kutter is shipping them filled with 000 grease now. It’s not gear oil, but it’s not really what you typically think of as a “grease” either.
Re: 00 grease in my brush mower [Re: dlundblad] #5438969 05/26/20 03:58 AM
L
Lubener Offline
L
It is a temporary fix, I doubt the grease is going to find its way into the tiny openings of a bearing to fully lubricate it very well. I am more in favor of a home made mix of gear oil and grease.
Re: 00 grease in my brush mower [Re: Elkins45] #5438974 05/26/20 04:19 AM
dlundblad Offline
Yes bearings not getting fully lubed would be another concern.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: 00 grease in my brush mower [Re: Lubener] #5439160 05/26/20 09:32 AM
E
Elkins45 Offline OP
E
Wheel bearings in trailers go thousands of miles after being packed with a thick grease. I would think a flowable grease would do an even better job of getting into bearings than a thick one once the bearing has spun a few thousand times and slung out some of the packing.
When I opened the check plug after mowing a while (but after it had cooled down to ambient temperature) the 00 grease flowed out easily.
Re: 00 grease in my brush mower [Re: Elkins45] #5439169 05/26/20 09:43 AM
dlundblad Offline
I like your thinking, but wheel bearings are packed by hand or pumped in with a grease fitting and some decent pressure. A gear box would be poured in. At first, no I do no think the grease was contacting everything until things stirred and warmed up.
After use, it is good to see it poured out though.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: 00 grease in my brush mower [Re: dlundblad] #5439340 05/26/20 12:53 PM
E
Elkins45 Offline OP
E
It didn’t start out completely dry. I started just pouring in some gear oil but when I had added half the bottle and it still wasn’t full I decided to investigate. That’s when I discovered the stump jumper was sloshing with oil. I drained most of the oil back out when I tilted it to remove the blades and tighten up the mounting bolts, but the bearings were definitely still wet when I started using it.
I’m thinking this stuff would be the perfect lube for fishing reels.
Re: 00 grease in my brush mower [Re: dlundblad] #5441122 05/28/20 04:29 PM
J
jhellwig Offline
J
They do get warm. Very warm. A lot of power is transmitted and they take a beating. These thin greases are specifically meant for gearboxes.
2014 Toyota Sienna
1983 Chevy K5 350
Re: 00 grease in my brush mower [Re: Elkins45] #5454994 06/16/20 07:47 AM
J
jeepman3071 Offline
J
00 grease will work fine. I use that in my Gravely walkbehind tractor's 30" brush hog gearbox, and several older Ariens snowblowers without issue. John Deere Cornhead grease also works great in this application.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (63k) - Liqui Moly 5w40, MANN HU816X
Re: 00 grease in my brush mower [Re: jhellwig] #5455350 06/16/20 03:22 PM
L
Lubener Offline
L
My gear box on my Ford five foot brush hog only gets luke warm after mowing five acres with waist high grass. It never got hot.
Re: 00 grease in my brush mower [Re: Lubener] #5457424 06/19/20 04:47 AM
dlundblad Offline
I should’ve been more clear, but yes a rotary cutter box will not reach temperatures as high as an equivalent finishing mower. They aren’t geared the same.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
