Forums Migration
Please read this thread
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
First time UOA. Questionable potassium levels
by chknkatsu - 07/06/20 07:38 PM
STP oil treatment
by wymi516 - 07/06/20 07:12 PM
Oil Life Monitor
by rrretiree7 - 07/06/20 06:57 PM
94 F 150 Engine control module replaced
by Electromotive - 07/06/20 06:43 PM
OIL UDDER Q+A
by OIL_UDDER - 07/06/20 05:46 PM
Devil's Lake State Park near Baraboo, WI
by wwillson - 07/06/20 05:43 PM
New vehicle bug bit me again
by JTK - 07/06/20 04:56 PM
2012 Ram 2500 Delvac 15W40 3,000 miles
by tnt_motorsports - 07/06/20 04:43 PM
BakonBittz, ssoH, Sumpter_al, Jeffham87, chknkatsu
71867 Registered Users
33 registered members (blufeb95, carlprop, BlakeB, alcyon, Bailes1992, 2 invisible), 944 guests, and 30 spiders.
Topics307,526
Posts5,312,589
Members71,867
Seemingly small coolant leak - could it be a bigger problem? #5437806 05/24/20 06:51 PM
P
PWMDMD Offline OP
P
I have a 2020 Tundra Platinum with 3000 miles. Today I was driving and all of a sudden I could smell coolant - I have been in cars with a heater core leak. The two other occupants also both made a comment about the smell. The A/C was on at the time. Everything else on the car is normal. I have an OBD-2 scanner and all temps were normal and the evaporator fin temp was 32-35F the entire time and the A/C was working well.
When I got home I looked under the hood and found a small coolant leak where a hose meets the water pump (see pics). The coolant level is 1/2" ABOVE the full line. While I know this is not normal I have a hard time believing that was the source of the smell - It was NOT subtle - it was very obvious and all three of us noticed it at the same time. We were in the car for 2 hours and the smell persisted. I cleaned the dried coolant and drove to the store - round trip about 5 miles and there was a fresh droplet of coolant.
I have an appt for next Saturday and while it's obvious there's something wrong with the seal of that hose are there any other issues that could cause that leak and would account for the very strong smell of coolant in the cabin? Some issue with the heater core or this is just an incidental finding and there's an evaporator leak? I'm just trying to prepare for the inevitable easy blowoff from the dealership of changing the hose and not addressing the real issue.
Current: 2020 Toyota Tundra Platinum (PP 0W-20 and Toyota OEM Filter) and 2019 Lexus RX 350 (PP 0W-20 and Toyota OEM Filter)
Re: Seemingly small coolant leak - could it be a bigger problem? [Re: PWMDMD] #5437824 05/24/20 07:15 PM
Chris142 Offline
Take 2 minutes and put a screw clamp on it. Do not even have to drain the coolant.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Seemingly small coolant leak - could it be a bigger problem? [Re: PWMDMD] #5437826 05/24/20 07:17 PM
T
Trav Offline
T
It only takes a drop of coolant to stink the place out, yes the amount you are finding can cause it. Looks like a very minor issue, let the dealer repair it under warranty and forget it.
Re: Seemingly small coolant leak - could it be a bigger problem? [Re: PWMDMD] #5437829 05/24/20 07:21 PM
E
E150GT Offline
E
That is some pink coolant
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 253k 5w30
2016 Mazda6 Touring 6MT - 81k 5w30
2006 Buick Lucerne CXL 3.8 50k 5w30
Re: Seemingly small coolant leak - could it be a bigger problem? [Re: PWMDMD] #5437871 05/24/20 07:46 PM
E
eljefino Offline
E
Let the dealer, well, deal with it.
I'm worried there might be some casting flash or roughness on the nipple that's causing a not-great seal. They could hit it real quick with some sandpaper when it's apart, for example. IMO it should be taken apart for inspection, not just have another clamp jammed on.
I'm trying to find a reason why this would be going on with a brand new car. The tension of those spring clamps is usually spot on, and the rubber won't have degraded from age already.
Re: Seemingly small coolant leak - could it be a bigger problem? [Re: eljefino] #5437875 05/24/20 07:48 PM
spasm3 Offline
This.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Seemingly small coolant leak - could it be a bigger problem? [Re: PWMDMD] #5438063 05/25/20 04:03 AM
Char Baby Offline
Don't touch anything. If you do, you'll be to blame.
Let the dealer handle the problem.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Seemingly small coolant leak - could it be a bigger problem? [Re: PWMDMD] #5438143 05/25/20 07:28 AM
B
bullwinkle Offline
B
Thank your lucky stars your truck is Toyota & not Ford-I've been fighting small leaks like this on the company Transit 250 in my sig since the lease began 60K ago. Dealer couldn't be bothered to fix it, so I just dumped a whole pack of ginger root Bars Leak tablets into it, leaks stopped (for now)!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Seemingly small coolant leak - could it be a bigger problem? [Re: E150GT] #5442014 05/29/20 05:58 PM
A
Anduril Offline
A
Someone filled it with Pepto Bismol by mistake!
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: Seemingly small coolant leak - could it be a bigger problem? [Re: Trav] #5442271 05/30/20 07:16 AM
W
wag123 Offline
W
+1
Re: Seemingly small coolant leak - could it be a bigger problem? [Re: PWMDMD] #5442709 05/30/20 06:56 PM
P
PWMDMD Offline OP
P
Brought it to the dealership today. They had it for about 5 mins and said they need to order parts - a "housing", some clamps and the hose. They'll call next week when it arrives. Said I need to leave the truck - "...while it may look quick it will take some time."
