Forums Migration
Please read this thread
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
First time UOA. Questionable potassium levels
by chknkatsu - 07/06/20 07:38 PM
STP oil treatment
by wymi516 - 07/06/20 07:12 PM
Oil Life Monitor
by rrretiree7 - 07/06/20 06:57 PM
94 F 150 Engine control module replaced
by Electromotive - 07/06/20 06:43 PM
OIL UDDER Q+A
by OIL_UDDER - 07/06/20 05:46 PM
Devil's Lake State Park near Baraboo, WI
by wwillson - 07/06/20 05:43 PM
New vehicle bug bit me again
by JTK - 07/06/20 04:56 PM
2012 Ram 2500 Delvac 15W40 3,000 miles
by tnt_motorsports - 07/06/20 04:43 PM
BakonBittz, ssoH, Sumpter_al, Jeffham87, chknkatsu
71867 Registered Users
34 registered members (19elantragt, Bailes1992, Bazza32, 97prizm, A_User55555, Bebop, 1 invisible), 1,152 guests, and 32 spiders.
Topics307,526
Posts5,312,578
Members71,867
recommended 5w30 for ticking and engine noises #5437783 05/24/20 06:29 PM
A
apollo18 Offline OP
A
for my gm 6.2l which has piston slap and lifter tick, i noticed when i got castrol edge 5w30 it reduced the engine noise quite a bit, it was very much noticeable.
however i believe over the length and life of the oil and whatever property lowered the noises in the oil has worn out or something happened to it and now im back to noisy engine again.
i was wondering if you guys recommend any oil that queits down better then castrol edge 5w30?
thx
Re: recommended 5w30 for ticking and engine noises [Re: apollo18] #5437789 05/24/20 06:35 PM
IMSA_Racing_Fan Offline
Try a 5W40 or 10W40. Have you cleaned your injectors? Stuck injections may be diluting your oil.
Re: recommended 5w30 for ticking and engine noises [Re: IMSA_Racing_Fan] #5437818 05/24/20 07:08 PM
T
TheBig2003 Offline
T
Agreed. Any of the GM V8's I have owned in the past were notorious for various injector issues including fuel dumping.
Also may wish to try Pennzoil Platinum Euro 5W40. Not the thickest of 40 weight, but exceptional at reducing valve train noise and provides superior protection based on my experience with it in light-duty diesel engines. Has even helped with hydraulic lifter tick in VW VE diesels (my own experience). If that doesn't solve it then throw some Rotella T6 or Valvoline Extreme Blue in 5W40 flavours in and see if that helps.
02 Jetta ALH TDI 241whp/403tq - 5W40 Rotella T6
04 Touareg BKW TDI 623whp/1011tq - 5W40 Rotella T6
09 Elantra Sport (Daily) - 5W30 Mobil 1
19 Kona 2.0 AWD (Wife) - 5W20 Syntec
Re: recommended 5w30 for ticking and engine noises [Re: apollo18] #5437828 05/24/20 07:18 PM
T
Trav Offline
T
What year is this?
Re: recommended 5w30 for ticking and engine noises [Re: apollo18] #5437845 05/24/20 07:29 PM
U
UncleDave Offline
U
My titan is a bit noisy and always had a slight drivers side tick even from day 1 considering its a DOHC 32V engine a tiny bit of noise is really good.
Im hard on this truck in that I tow a lot of weight up hills in the desert most specifically the j2807 hill as I go to the desert lakes for boat tests often.
I loaned the truck to a friend for a significant period of time and he did an oil and filter change using Mobil 1 5w-30 EP not something I would have normally ever picked the truck is quieter on this than anything I ever ran- including the 0w40 Id run religiously for years.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: recommended 5w30 for ticking and engine noises [Re: apollo18] #5437886 05/24/20 08:06 PM
stanlee Offline
Pennzoil platinum quiets all.
Re: recommended 5w30 for ticking and engine noises [Re: UncleDave] #5437897 05/24/20 08:20 PM
Quote
Huh?
Re: recommended 5w30 for ticking and engine noises [Re: apollo18] #5437914 05/24/20 08:49 PM
Z
Zaedock Offline
Z
My Coyote DOHC 32V engine doesn't make any noise at all on anything from Harvest King 5W20 to PP10W30.
To the OP, historically, QS and PZ oils have had good results quieting engines. My old '03 Z71 5.3L ran quietest on Quaker State conventional 5W30.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: recommended 5w30 for ticking and engine noises [Re: apollo18] #5437922 05/24/20 08:55 PM
W
walterjay Offline
W
I have found Castrol to be the most quiet oil. Try a 0W-40
Re: recommended 5w30 for ticking and engine noises [Re: walterjay] #5437926 05/24/20 09:00 PM
Z
Zaedock Offline
Z
That's a good choice too!
Re: recommended 5w30 for ticking and engine noises [Re: IMSA_Racing_Fan] #5437931 05/24/20 09:08 PM
U
UncleDave Offline
U
Quote
Huh?
What is remotely confusing about that?
UD
Uncle Dave
Re: recommended 5w30 for ticking and engine noises [Re: walterjay] #5437934 05/24/20 09:09 PM
Spartanfool Offline
My experience as well (in 0w40).
Re: recommended 5w30 for ticking and engine noises [Re: apollo18] #5438026 05/24/20 11:41 PM
B
Bullwinkle007 Offline
B
I have heard redline 5/30 works well, at least when ppl talk about the hemi tick. Idk bc I don't own one
Re: recommended 5w30 for ticking and engine noises [Re: apollo18] #5438097 05/25/20 06:23 AM
Mr Nice Offline
T5 or T6.
Re: recommended 5w30 for ticking and engine noises [Re: Bullwinkle007] #5438102 05/25/20 06:31 AM
K
kstanf150 Offline
K
I’m about to see if RL helps valvetrain tick in a 6.2 Ford
Just bought RL 5W-30 a few days ago
