Forums Migration
Please read this thread
2017 CR-V Next Oil
by Ruby2013Elantra - 07/08/20 02:31 AM
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
16 registered members (Gene K, Bjornviken, GMguy84, alcyon, farrarfan1, GumbyJarvis), 717 guests, and 33 spiders.
Topics307,584
Posts5,313,572
Members71,876
Interesting observation, a/c on lowers coolant temp. #5437730 05/24/20 05:42 PM
J
Jeff8820 Offline OP
J
My 2001 Camry 4cyl has always had ice cold a/c, and still does. I recently downloaded a ECM Bluetooth app
that shows coolant temp , I was under the assumption that at idle running the a/c also raised the coolant temp, but I'm observing the opposite. it's 90 degrees F outside and if I let the car idle with no a/c it gets up to about 208 and the cooling fan kick on and the coolant temp drops a few degrees within one minute. If I turn the a/c on, it's stays right at 195-196 degrees indefinitely.
This is all at idle in a fully warmed up car.
Just out of curiosity I tried a couple different apps and they are all within 1 degree variance. I googled "coolant temp drops with a/c on" and all I see is the opposite, people with overheating with the a/c on.
Also the a/c stays ice cold at idle, it always has. The best a/c I've ever had. Thoughts?
Re: Interesting observation, a/c on lowers coolant temp. [Re: Jeff8820] #5437735 05/24/20 05:47 PM
Char Baby Offline
Turning on the AC also kicks on the cooling fan(s).
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Interesting observation, a/c on lowers coolant temp. [Re: Jeff8820] #5437740 05/24/20 05:53 PM
J
Jeff8820 Offline OP
J
Now I don't feel so bad about letting my car idle so much with the a/c on which I've done for years in this car, I always assumed the actual coolant temp raised about 10-15 degrees but apparently it's the opposite./
Re: Interesting observation, a/c on lowers coolant temp. [Re: Char Baby] #5437743 05/24/20 05:54 PM
danez_yoda Offline
YUP! learned that trick when my coolent temp sensor died and my fans never came on. Caused my 97 Misubishi eclipse to overheat inline at the bank. Called the dealership (I was young back them) and they said just turn on the AC and drive on in. I thought they are crazy and argued with them that I wasn't the one overheating the engine was. " AC doesnt cool the ENGINE you idiot!!! "
Welp..... ate those words. turns out AC does cool the engine. smile
Re: Interesting observation, a/c on lowers coolant temp. [Re: Char Baby] #5437763 05/24/20 06:14 PM
L
Lolvoguy Offline
L
+1
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Interesting observation, a/c on lowers coolant temp. [Re: Char Baby] #5437764 05/24/20 06:16 PM
Char Baby Offline
Because running the AC puts more stress on the engine which is why the fans turn on.
Re: Interesting observation, a/c on lowers coolant temp. [Re: Jeff8820] #5437770 05/24/20 06:23 PM
J
Jeff8820 Offline OP
J
I just didn't expect the a/c being on to actually lower the coolant temp, incidentally at the same outside temp at 75mph with the a/c on or off the coolant temp. pretty much goes to 195 and stays there. My wife's 2016 Explorer at idle very noticably starts losing a/c coolness until you start moving 30mph+, somehow this old Toyota keeps it chilled no matter. I wasn't planning on keeping the Camry this long but one of the main reasons is the a/c, I don't know how Toyota made the a/c so efficient , but it worked!
Re: Interesting observation, a/c on lowers coolant temp. [Re: Jeff8820] #5437780 05/24/20 06:27 PM
A
ammolab Offline
A
AC does turn on the cooling fans...but so does rising temp in the cooling system. If your temp sensors, switches and relays are working you should never need to turn on AC to lower coolant temp.
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Interesting observation, a/c on lowers coolant temp. [Re: ammolab] #5437787 05/24/20 06:33 PM
J
Jeff8820 Offline OP
J
Without the a/c on at idle the fan fans? come on at 208 degrees according the Bluetooth dongle, very quiet though you have to listen hear it click on. If I'm sitting at idle in 90 degree weather with the a/c cranked and the coolant temp won't go above 196 degrees I don't think my engine is having any trouble staying well within it's engineered temp. If anything this car has a tendency to run cool, years ago the thermostat stuck open and in 50 degree weather you couldn't get any heat and the temp actually dropped going anything above 40mph. Incidentally the beck/arnley thermostat I put in it was a piece of junk, replaced it with aisin brand one and that fixed it.
Re: Interesting observation, a/c on lowers coolant temp. [Re: Jeff8820] #5437795 05/24/20 06:43 PM
J
Jeff8820 Offline OP
J
I also never realized how important those cooling fans were at idle, seeing real time temps, now I know.
Re: Interesting observation, a/c on lowers coolant temp. [Re: Char Baby] #5437810 05/24/20 06:59 PM
B
bbhero Offline
B
Good point CB....
With my scan tool I have seen the same phenomena as the op... So now it makes sense to me.
Nissan Altima 3.5 Coupe
Royal Purple 10w30+ Ceratec+ Carquest red 85358
"Treat your family like your friends and treat your friends like your family."
Re: Interesting observation, a/c on lowers coolant temp. [Re: Char Baby] #5437819 05/24/20 07:10 PM
dishdude Offline
I thought it was to pull air through the condenser.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Interesting observation, a/c on lowers coolant temp. [Re: dishdude] #5437844 05/24/20 07:28 PM
J
Jarlaxle Offline
J
It is.
1979 Coupe de Ville, 542 stroker, Super Tech 15W-40, Super Tech filter
2013 Challenger SRT8 Core, Valvoline synthetic 0W-40, Purolator
2011 Sportster 883, SYN3 20W-50, HD black
Re: Interesting observation, a/c on lowers coolant temp. [Re: dishdude] #5437855 05/24/20 07:34 PM
Skippy722 Online Happy
Online Happy
It is. The load from AC on a modern engine is relatively insignificant.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Interesting observation, a/c on lowers coolant temp. [Re: Jeff8820] #5437872 05/24/20 07:46 PM
B
bullwinkle Offline
B
Need to pull air through the hot condenser at idle (no airflow otherwise) to condense the hot refrigerant vapor into a liquid, so it can evaporate again in the evaporator & make it cold.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
