How To Remove Overspray On Aluminum Wheels?
by NDL - 07/02/20 07:16 AM
Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
bigmike323, SolsticeSHO, Bazza32, Klink_II, williamshrader
71828 Registered Users
91 registered members (1978elcamino, ArrestMeRedZ, alarmguy, Astro14, anpconnors, 55hambone, 6 invisible), 1,269 guests, and 35 spiders.
Topics307,393
Posts5,309,707
Members71,828
spider gears fell out.... #5437591 05/24/20 03:30 PM
M
MrTruckDriver Offline OP
M
hi everyone. I'm changing a rear axle seal in my truck today. its an open diff. when i removed the locking pin to take the c clip out i rotated the axle and both spider gears fell out of place. i cleaned everything up and re installed the spider gears. my concern is i mixed them up, they look exactly the same im just not sure if they could be different and have to go in one way.
one other question. the manual says to use non hardening thread locker for the pin bolt. can i use blue locktight instead?
thanks everyone.
Re: spider gears fell out.... [Re: MrTruckDriver] #5437600 05/24/20 03:38 PM
Chris142 Online Content
Online Content
They rotate around inside the carrier. Does not matter where you put them back in. There may be shims under them. Don't lose those.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: spider gears fell out.... [Re: MrTruckDriver] #5437603 05/24/20 03:40 PM
G
Gebo Online Content
Online Content
G
Out of my pay grade. You may try a generic permethrin.
Seriously, if you just use some Red Line or Amsoil gear oil it won't matter.
I'm sorry. Had a great day at work just feeling a little giddy.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: spider gears fell out.... [Re: MrTruckDriver] #5437611 05/24/20 03:44 PM
M
M
thanks. no shims just "thrust washers" and they are exactly the same thickness.
Re: spider gears fell out.... [Re: MrTruckDriver] #5437673 05/24/20 04:48 PM
T
Timmastertech Offline
T
You have 2 side gears and 2 spiders, doesnt matter where they go as long at the thrust washers are there. While they are out inspect the washers for wear, surfaces should be perfectly smooth. If not, replace the spider gear set. Cant honestly say I have ever put thread locker on the lock bolt, usually just torque to spec.
