This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
electro, SilentC, paolo9fla, SunnyB, Mullady76
71849 Registered Users
89 registered members (77GrandPrix, Astro14, 4WD, antonmnster, Atrocious, bdcardinal, 9 invisible), 2,221 guests, and 26 spiders.
Topics307,444
Posts5,311,321
Members71,849
Page 1 of 3 1 2 3
The BITOG forum fascination with zero weights #5437539 05/24/20 02:43 PM
IMSA_Racing_Fan Offline OP
I'm puzzled with the obsession towards retro-adding 0Wxx oils, especially by people with California, Arizona, etc in their profiles.
Please explain.
Re: The BITOG forum fascination with zero weights [Re: IMSA_Racing_Fan] #5437554 05/24/20 03:02 PM
B
bbhero Offline
B
Ahh because they can use a 0w and it's no big deal...
LOL
Well that and the "better" oils typically are say a 0w30 or 0w40 or 0w20... Mobil 1 0w40 carries many high level approvals like Porsche a40 and MB 229.5 etc etc...
Nissan Altima 3.5 Coupe
Royal Purple 10w30 Carquest red 84356
"Treat your family like your friends and treat your friends like your family."
Re: The BITOG forum fascination with zero weights [Re: IMSA_Racing_Fan] #5437556 05/24/20 03:03 PM
F
fsdork Offline
F
I see that your question is more focused on those in hot climates, but I use 0W-20 in my 5W-20 spec vehicles because I'll take whatever help I can get for cold starts at -40°C.
As for warmer climates, I would suggest that if one can get comparable protection from a 0W-20 at operating temperatures (as compared to 5W-20), then why not take advantage of improved flow at startup? On the other hand, if running 0W-20 costs you an appreciable amount of protection at operating temps, then 0W-20 wouldn't make sense.
2003 Ford Explorer Limited 4.6L 4x4 - 219K km
2008 Ford CVPI 4.6L - 133K km
2011 Ford F-150 Lariat S/C 6.2L 4x4 - 90K km
Re: The BITOG forum fascination with zero weights [Re: IMSA_Racing_Fan] #5437558 05/24/20 03:04 PM
PimTac Offline
The W does not stand for weight.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: The BITOG forum fascination with zero weights [Re: IMSA_Racing_Fan] #5437559 05/24/20 03:05 PM
G
gregk24 Offline
G
Because it is superior?
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: The BITOG forum fascination with zero weights [Re: bbhero] #5437560 05/24/20 03:06 PM
Cujet Offline
True in properly designed engines. Not so in others, Ford, GM, Hyundai/Kia, BMW, Honda and a few others come to mind.
Re: The BITOG forum fascination with zero weights [Re: Cujet] #5437567 05/24/20 03:11 PM
B
bbhero Offline
B
I can't think of a Ford or GM motor where a 0w would hurt a thing....
A 0w30 or 0w20 say in a Ford Fusion 3.0 would not do anything wrong with it...
Only thing a 0w means is it is thinner at very cold temps.... Which would be beneficial for any vehicle if it were truly very cold out.
The operating temp like a 20 operation viscosity may well not be the best with some very old vehicles. Like +20 year vehicles. Ok I can agree with that.
Let's say a 1993 Ford ranger which speced a 5w30 from the owners manual...
If someone put a 0w30 in it... That Ford Ranger would be just fine. .
Re: The BITOG forum fascination with zero weights [Re: IMSA_Racing_Fan] #5437583 05/24/20 03:25 PM
Delta Offline
I just use what's easily obtainable and in spec. When I lived in Mississippi I used Edge 0w40 in my old MK5 Jetta. Didn't need the 0w, but it was the most affordable and easily obtainable oil that I was able to get. Same situation with the SLK, while it gets colder here in PA and MD, 0w is not needed since it's a summer car. Again the 0w40 is easily obtainable...
'17 VW GTI 2.0T - 6MT - 22K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 27K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 142K - RGT 5w30
Re: The BITOG forum fascination with zero weights [Re: bbhero] #5437585 05/24/20 03:26 PM
Chris142 Offline
How about a 6.4l diesel? Prolly should not put it in that.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: The BITOG forum fascination with zero weights [Re: IMSA_Racing_Fan] #5437587 05/24/20 03:27 PM
M
mpack88 Offline
M
My 2018 Taurus is using 0w20 RGT because $10/5qrt was to good of a deal to pass up on. Also got some 5w20 aswell.
Re: The BITOG forum fascination with zero weights [Re: IMSA_Racing_Fan] #5437590 05/24/20 03:29 PM
Quattro Pete Offline
Please explain.
Retro-adding? Please explain.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: The BITOG forum fascination with zero weights [Re: Chris142] #5437593 05/24/20 03:31 PM
B
bbhero Offline
B
Not talking about diesels...
Easy enough.....
Re: The BITOG forum fascination with zero weights [Re: IMSA_Racing_Fan] #5437594 05/24/20 03:31 PM
dave123 Offline
New mid engine corvette specs 0w40 can’t see much winter driving in them their engineers must also be obsessed with zero weight oils?? Don’t know
Re: The BITOG forum fascination with zero weights [Re: Quattro Pete] #5437597 05/24/20 03:36 PM
G
Gebo Offline
G
Please explain.
Quattro Pete, seriously? USA Even I know that one. Actually, I think it is a perfect description. Just tilt your head a little to the right and wink with your left eye.
Retro Diner, Backwards compatible, etc.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: The BITOG forum fascination with zero weights [Re: IMSA_Racing_Fan] #5437598 05/24/20 03:36 PM
53' Stude Offline
Please explain.
My 09’ Camry specs 0w20 oil. What’s wrong with that?’
2009 Toyota Camry LE
Page 1 of 3 1 2 3
