FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
58 registered members (Char Baby, BigGeo, 2002 Maxima SE, BigCahuna, Astro14, BAJA_05, 5 invisible), 1,201 guests, and 26 spiders.
Topics307,398
Posts5,310,380
Members71,843
Mixed dex-cool with green stuff in Ford Ranger #5437534 05/24/20 02:39 PM
J
jac962 Offline OP
J
I'm looking for a Ford Ranger and I found a 2000 with low miles and very little rust (near impossible to find for this age in New England). Everything looked great on the engine, it has a minor oil leak somewhere (looks like the valve cover?) When I opened the radiator cap I noticed some gunk on it and it had an orange/reddish color which was odd because I was pretty pretty sure Ford uses green or yellow. He's owned the car for 8 months and put a few thousand miles on it. I took it for a 10 minute drive and it got up to temp and didn't start to overheat at all so it doesn't seem like it's having the typical overheating issues. I left to go look at another truck and the first guy sent me a picture of the other stuff he's giving me with the truck and in the picture there's a bottle of Prestone Dex Cool so I'm almost positive he's the one that added it. I haven't called him back yet and I have a few questions before I call him back. There's a lemon law in Massachusetts where I'm buying it so if it's a massive problem I can return it to him for a full refund.
1. How much/what kind of damage can 8 months of dex-cool mixed with green do to the system? I didn't see any coolant leaks anywhere and it doesn't look like there was any K-Seal or any sort of leak stop used.
2. Would it be any different if he flushed the system at the radiator before adding the dex cool rather than just topping off with green? I doubt if he flushed he flushed at the block I'll ask after I call
3. If I do a complete flush of the system from the block, radiator, and water pump and refill with distilled and Ford green, will I be able to mitigate the damage?
Thanks for the help.
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: jac962] #5437542 05/24/20 02:47 PM
IMSA_Racing_Fan Offline
Flush that crap out asap
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: jac962] #5437550 05/24/20 02:58 PM
Dex-cool = Dex-KILL
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: jac962] #5437551 05/24/20 02:58 PM
Chris142 Offline
The lemon law in you're state covers a 20 yr old car?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: jac962] #5437563 05/24/20 03:07 PM
B
bbhero Offline
B
I would do like you are saying.... Total flush with distilled water and use appropriate Ford approved full strength antifreeze... Also I would go ahead and replace thermostat and radiator hoses.... and possibly replace water pump too whole your at it...
Nissan Altima 3.5 Coupe
Royal Purple 10w30 Carquest red 84356
"Treat your family like your friends and treat your friends like your family."
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: jac962] #5437564 05/24/20 03:10 PM
csandste Offline
Question-- 'cause I don't know.
Doesn't the universal "fits everything" kind of coolant resemble Dex-Cool? If it does, and "everything" means the green stuff, what's the problem?
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: jac962] #5437592 05/24/20 03:31 PM
G
Gebo Offline
G
Just do a few plain distilled water flushes first and make sure you have the temp to max hot. After 3 flushes and run ups to normal operating temp, replace with whatever Ford calls for. If it's me, I'd then run the Ford Coolant
for a while and then replace with fresh and be done. I'm assuming you mix this coolant so on the first mix of Ford Coolant, I'd mix it 70% coolant and 30% distilled water. On the last mix I would go a little heavier on the coolant
Say 60/40 coolant and water.
And I would make sure I drained the block if possible. Leave the heat on max hot.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: Chris142] #5437658 05/24/20 04:29 PM
bdcardinal Offline
Seriously, that's news to me.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: jac962] #5437677 05/24/20 04:53 PM
If it were mine I'ld flush with a radiator product, remove replace the thermostat (rather than just clean it since you're there) and fill with 50/50 ETHYLENE GLYCOL ANTIFREEZE.
https://www.walmart.com/ip/Super-Tech-Antifreeze-Coolant/16645420
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: jac962] #5437678 05/24/20 04:53 PM
R
ripcord Offline
R
I highly doubt that 8 months or less of having Dex-cool in there is going to have caused any significant issues. If I were buying this car, I'd probably do a citric acid cleaning with full back flush followed by a couple of distilled water flushes to get most of the tap water out, then add half the capacity of the cooling system of conventional green coolant and top off with water. After that, a biannual drain and fill with will likely keep it happy.
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: jac962] #5437709 05/24/20 05:28 PM
J
JohnG Offline
J
Yeah, what's with the "full strength" statement? No engine that I know of ever called for full strength (100% Glycol) coolant. 50% mixture is your target.
Dexcool does not have silicates, so it does not prevent corrosion of internals. It was designed for aluminum heads and block, hence the OAT additive package on top of the glycol.
Dexcool, not having silicates, will offer longer life water pump seals, among other benefits such as 5 year life.
Once silicates (green stuff) is introduced into any engine, even those designed for dexcool, you can't get rid of them. That means a two year service life forever after that. No exceptions.
Flush it however you want, refill it with Ford Green stuff @ a 50% mixture, and change it every two years or so. Simple.
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: Chris142] #5437853 05/24/20 07:33 PM
E
eljefino Offline
E
Apprently, yes, even on private party sales:
https://www.mass.gov/video/lemon-law-overview-presentation-2
Mostly seems to do with passing the safety/emissions inspection, and disclosing known faults.
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: csandste] #5437969 05/24/20 10:11 PM
clinebarger Offline
More of a Yellowish-Neon Green tint to the universals. Delco Dex-Cool is almost Red-Darker Orange, Prestone Dex-Cool is more Orange.
Dex-Cool is a very good coolant when used by itself with distilled water!! I even run it in both my Toyota's!
2001 Chevy Camaro L92/4L80E
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: JohnG] #5438039 05/25/20 12:31 AM
J
Jake_J Offline
J
Dexcool not having silicates = it does not offer corrosion protection of internals is a 100 % wrong statement. Dexcool was among the first OAT coolant formulas used by a OEM, and the Organic Acid Technology means it has additives that are carbon based (unlike silicate and phosphate) which handle corrosion protection. When GM introduced Dexcool in 1997 their entire engine lineup was almost entirely all iron block and heads, so to say it was developed for aluminum block and head engines is flat wrong. In 1997 common GM engines like the gen 1 SBC V8, the Buick 3800 V6, the 60 degree V6, the GM122/Vortec 2200, the Quad Four, etc where all iron or iron block with aluminum heads, and all aluminum engines where rare birds like the Corvette only gen 2 LT5 V8.
There's nothing inherently wrong with mixing silicate and a pure OAT coolant like Dexcool, in fact most European cars come with silicated OAT (Si-OAT) coolants from the factory. The OP's coolant issues are not related to Dexcool or mixing Dexcool with a green IAT coolant, it's most likely the classic lack of maintenance (ie didn't change the coolant in 20 years) or the all too common "it had a coolant leak so I kept topping up with tap water" and then the coolant was mostly water with little to none corrosion protection + time + iron block engine = rusty coloured gunk.
Re: Mixed dex-cool with green stuff in Ford Ranger [Re: jac962] #5438041 05/25/20 12:43 AM
J
jac962 Offline OP
J
Thanks for all the help. I ended up buying the truck. He said he flushed the system and refilled with orange and didn't know the difference. I'l be doing a complete flush of all the components and the block tomorrow followed by a few refils and flushes with distilled water until I feel like she's sufficiently clean. The guy tossed in a water pump and timing kit so I'll just replace those while I'm in there along with a thermostat and new rad hoses.
I swear there should be a law against the way they advertise coolants. People that don't know about cars walk in and see the green stuff and right next to it they see the "100,000 mile long life coolant" stickers on the jug and they go "oh that one must be better I'll buy that". I don't even want to think about how many engines have probably been bricked because of people mixing orange and green and not knowing the difference.
