65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
89 registered members (55hambone, AlienBug, BAJA_05, BHopkins, ABN_CBT_ENGR, 12 invisible), 1,811 guests, and 27 spiders.
Topics307,414
Posts5,310,638
Members71,843
Need Emergency Tire #5437196 05/24/20 05:32 AM
A
artbuc Offline OP
A
For my 2010 Acura MDX. Nail a good inch in from sidewall. Got it plugged but thinking about trying to find a replacement tire before I get on the interstate to drive 70 mph for 5 hours. Looks like only tire available will be from Walmart...brands I never heard of. After I get home, my plan is to buy a full size rim and use new off-brand as spare and buy a new Bridgestone to exactly replace the repaired tire. Beggars can’t be choosers, but if Walmart has more than one brand in my size, which one is the best?
Other alternative is to drive home on plugged tire. Unlike the RMA, I consider plugs a permanent repair. Have driven on plugged tires for many many decades and never had a problem. This one concerns me only because it is borderline close to sidewall.
Thanks to all, especially our Vets on Memorial Day.
Re: Need Emergency Tire [Re: artbuc] #5437202 05/24/20 05:42 AM
E
Egg_Head Offline
E
Can you share the brand names/speed rating of the tires at Walmart?
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
2011 MB E350 4Matic wagon
1979 CJ-7
1978 K-5 Blazer 400ci
Re: Need Emergency Tire [Re: artbuc] #5437212 05/24/20 06:01 AM
A
artbuc Offline OP
A
Don’t know...they are closed until Tuesday. Heck, maybe they don’t have my size. Lexani, Fuzion and Atturo are some of the brands. I was hoping someone familiar with Walmart brands could tell me which are ok and which should be avoided, even in emergency.
Re: Need Emergency Tire [Re: artbuc] #5437214 05/24/20 06:06 AM
E
eljefino Offline
E
I have a plug right on the shoulder that's been there for god-knows-how-long on the truck I just picked up. It's doing fine.
This isn't a motorcycle-- if that corner pops, you're more than likely staying upright.
Are all the other stores really closed? Craigslist? FB marketplace? Buy a used name brand?
Are you sure the tire part of walmart is open? Mine's closed UFN due to [censored]-19.
Are these 255-55r18?
Re: Need Emergency Tire [Re: eljefino] #5437220 05/24/20 06:15 AM
A
artbuc Offline OP
A
I am in VA with many stores starting to open. The Walmart in Staunton is closed today and Monday but will be open Tues. Yes, 255/55-18.
Re: Need Emergency Tire [Re: artbuc] #5437225 05/24/20 06:48 AM
E
edwardh1 Offline
E
the hot patch plug method is ok by Michelin.
old style with glue will fail eventually
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Need Emergency Tire [Re: artbuc] #5437243 05/24/20 07:18 AM
N
Nukeman7 Offline
N
Quote
There is a Discount Tire about 10 miles away in Waynesboro, VA that will be open on Tuesday. You should give them a call.
https://www.discounttire.com/store/...MTU0MTYyNzItNzE1LWxvY2F0aW9uLndlYnNpdGU=
Eavers Tire Pro is a bit closer in Fishersville, VA and may be open on Memorial Day.
https://eaverstirepros.com/
Mr. Tire is also located in Waynesboro and open on Monday.
https://locations.mrtire.com/va/waynesboro/2400-w--main-street.html
Good luck and travel safe!
Re: Need Emergency Tire [Re: artbuc] #5437268 05/24/20 08:08 AM
Driz Offline
An inch in from the sidewall? I can’t remember how many of mine picked up nails in that area and I fix the plugs Through the years. Never a single problem, not one. A dose of tire Slime alone will typically seal any typical nail hole by itself. Try to find something that is safe for sensors if yours still work if you want to go that route.
Come to think of it I got a nail in that area on my 18 Camray about a year back. It hasn’t lost a bit of air ( mine has actual TP readout, very nice) since I plugged it. No slime used because of the sensor either. The only time I’ve ever seen a plug not work for me long term is if it’s worn right to the wear bars. Then all it did was a slow leak.
I wouldn’t lose any sleep over a 5 hour tip on a tire I plugged as long as it had a few days driving on it to make sure its ok. Check the pressure a time or two along the way and use common sense and you’ll be fine. If the plug still worries you cut your speed a bit, you’ll still get there.
Re: Need Emergency Tire [Re: artbuc] #5437322 05/24/20 09:37 AM
E
Eddie Offline
E
If the hole is inside the first tread you are good to plug imo. Ed
2014 CX5 Touring 2.5L :-)
Re: Need Emergency Tire [Re: artbuc] #5437394 05/24/20 10:57 AM
U
UG_Passat Offline
U
Fuzion is a label owned by Bridgestone. It is their "value" brand.
2016 VW Tiguan
Re: Need Emergency Tire [Re: UG_Passat] #5437410 05/24/20 11:23 AM
K
KenshinHimura Offline
K
yep and all made in China. Guy i know from work had bought 4 new Fuzions and had 3 with a broken belt within the first week. Only "value" brand i would get is Douglas at Walmart. Any other tire i would be looking at would be the next step up such as Mastercraft, Kelly, ect
1997 Mitsubishi Eclipse Spyder Valvoline Max Life HM Full Synthetic 10w30 Napa Platiunum
2019 Hyundai Veloster Turbo QS 5W-30 OEM filter
Re: Need Emergency Tire [Re: artbuc] #5437486 05/24/20 01:41 PM
A
artbuc Offline OP
A
Thx to all for responding. I measured with a quarter and repair is a good 1-1/4” in. Logged some good miles at 60-65 plus up/down windy mountain roads. So far, so good. I’ll make some calls tomorrow just in case.
Re: Need Emergency Tire [Re: artbuc] #5450160 06/09/20 11:01 PM
N
Newman88 Offline
N
Ive plugged many tires, I have yet to see a plug fail, I've only see them fail in bias plys tires those get dismounted and patched up.
Re: Need Emergency Tire [Re: Newman88] #5450310 06/10/20 08:00 AM
CapriRacer Offline
You've never seen a plug fail, but you've seen them fail in bias ply tires? So which is it??
And just for reference, I've seen many plugs fail (I'm was in a position to be able to see them!) - and of the ones I have done or were done for me, the rate is 50% failure (2 out of 4).
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Need Emergency Tire [Re: CapriRacer] #5450407 06/10/20 10:40 AM
N
Newman88 Offline
N
Bad wording on my part, and yes I haven't seen a plug fail in any radial tire Ive plugged. You might have seen many fail because of installer error. This is on my fleet of trucks which consists of 50 trucks, that get punctured frequently in job site areas.
