Forums Migration
Please read this thread
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
35 registered members (bmod305, 07hemi, carlprop, ArrestMeRedZ, 4 invisible), 863 guests, and 25 spiders.
Topics307,580
Posts5,313,560
Members71,876
Oil Cooler Questions #5437193 05/24/20 05:28 AM
ChristianReske Offline OP
Gentlemen,
i am thinking about maybe adding a oil cooler to my Honda S2000.
Searching the internet, most of my questions are answerd. But there is one specific problem with the S2000 engine, oil flow. The engine makes 9.000 RPM and has a more unusuall high oil pressure, around 7 bar / 100 PSI. The engine needs a high oil flow.
So, here are my questions i came up:
- Is the are difference in Oil flow between the old fashioned "Mocal" cast aluminium sandwich plates and the new CNC milled (Like Mishimoto) sandwich plates?
- Some people say that the thermostat in the sandwich plate will reduce oil flow. Are they right?
- Is it better for the oil flow to use a sandwich plate without thermostat and add a extra thermostat into the lines to the oil cooler?
Re: Oil Cooler Questions [Re: ChristianReske] #5437201 05/24/20 05:42 AM
ABN_CBT_ENGR Offline
Relax and listen to the pump system engineer
There is no significant difference you would ever know about- in a closed system.....
Flow is "restricted" by dimension, turns, overall distance/height and surface roughness ( very basic list and not going into Reynolds and all that)
None of that exists in the sandwich plate to any significant degree.
The thermostat probe is no different than me sticking gauges in other instrumentation in the system- again insignificant.
Re: Oil Cooler Questions [Re: ChristianReske] #5439123 05/26/20 08:47 AM
Thank you!
Re: Oil Cooler Questions [Re: ChristianReske] #5439320 05/26/20 12:32 PM
DGXR Offline
You're installing an oil cooler to help oil flow? Or are you installing an oil cooler anyway, and you're concerned that this additional part may interfere with oil flow?
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
