Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
19 registered members (Bjornviken, blufeb95, alcyon, CARJ, Bailes1992, ctechbob, 2 invisible), 654 guests, and 25 spiders.
Topics307,388
Posts5,309,620
Members71,821
2003 Cummins Extended OCI 10k? w Pics #5437140 05/24/20 12:23 AM
R
RateNate Offline OP
R
Hello everyone I have a 2003 cummins that has no egr components or cat on it as well.
It has 176k miles and I am wanting to extend the oci to 10k if possible, I will be using a dbl 7349 for the first time so I will be running that for 3k miles with the new delvac 15w40 I bought today from walmart. I have never used a low micron rated filter like this which is why I am doing a 3k oci.
I was planning to use T6 15w40 with the DBL filter and go 10k if possible, or would the delvac 15w40 work as well?
Is this a good route to go for the future or should I do a oil sample after my 3k oci with the donaldson filter in it? I want to do the 10k oci so I can also change the fuel filter at the same time so its less work, thanks!
Here is the filter and the delvac oil that I bought today from walmart for 10.97
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: RateNate] #5437218 05/24/20 06:12 AM
B
BlastChamber Offline
B
I also have a 2003 Dodge Ram with the Cummins and have always done 10k mile oil changes and changed the filter at 5k miles with a quart of make-up oil.
I use Mobil One 5w-40 full synthetic and Fleetguard Stratapore filters and have never had any issues. This truck is about to turn 100k miles and still runs like new.
'11 Toyota Sienna SE 3.5 V6
'08 Pontiac Vibe 1.8 I4
'03 Dodge Durango SLT 4.7 V8
'03 Dodge Ram 2500 SLT QC Cummins 24-valve
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: RateNate] #5437327 05/24/20 09:45 AM
B
Bighorn2500 Offline
B
I do 10k changes using Donaldson DBL with T6 or VPBE.
That filter could easily go 15k, maybe further on a well maintained engine.
Don’t see why the Delvac couldn’t go 8k-10k on non emissions engine. Run it then sample it.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: RateNate] #5437572 05/24/20 03:20 PM
R
ruSSrt Offline
R
01 Cummins here. Unless you use and abuse your truck 3k OCI is overkill. I've done sample test at 5k on the same delvac 1300, that's when I change my oil, and black stone told me I'm safe to go till 7k or more with easy driving. I also use fleetguard LF16035. If you do fully synthetic 10k with good filter no problem at all.
2001 Ram 2500 Cummins
2005 VW Passat TDI
2011 Jeep Liberty 3.7L
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: RateNate] #5437578 05/24/20 03:23 PM
U
UncleDave Offline
U
Seem like a good time to see if the very best filter on the market fits- the cummins stratapore venturi dual element filter.
Suppose to scrub down to something like 5 microns using a stacked disc internal bypass.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: RateNate] #5443099 05/31/20 10:54 AM
A
A_Harman Offline
A
I've run Delvac 1300 in my trucks. Didn't like it much. Not enough wear protection for my comfort. Rotella T4 is much better in that respect.
The Cummins engine is easy on the oil if it doesn't have emissions controls. I ran extended oil change intervals on my '01 Ram on Delvac 1300.
Here is a link to the UOA's: https://www.bobistheoilguy.com/foru...-delvac-1300-super-27k-miles#Post5161610
I don't see any real problem, though in running the 10kmile oil change interval. Donaldson makes good filters, and Delvac 1300 is OK oil.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: A_Harman] #5443157 05/31/20 12:18 PM
L
LubricatusObsess Offline
L
Quick story: back in 1984, Mobil Delvac 1300 Super 15W-40 was new on the market, & I was a Mobil Commercial Lubricants Engineer. A Distributor driver ran a Mack, don't recall which engine, and tried it. He had been using an Amoco product (Distributor was dual-flag). His UOA showed high chromium that the lubricant guys couldn't explain. I advised going back to Amoco, and never got an answer from Mobil Lube Lab. Seems their antiwear package for HTFS was inadequate, by my best educated guess. I run Shell Rotella T6 5W-40 because it meets Ford's antiwear spec and is listed on Ford's approved oil list.
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: RateNate] #5443173 05/31/20 12:51 PM
Strjock81 Offline
That 03 Cummins will last forever on decent oil and 10k changes.
Personally if I planned on keeping it forever I’d run the bypass filter mentioned above and HPL 5W-40 which is based on the tremendous CI-4+ add pack and then top treated with even more anti wear additives and friction modifiers and shoot for a 20,000 mi oci.
2016 White Town and Country Touring
2015 White Yukon XL Denali
2014 White Ram 2500 CCSB 4x4 Cummins Bighorn
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: BlastChamber] #5456552 06/18/20 05:26 AM
R
RateNate Offline OP
R
@BlastChamber What filter are you running? From what ive seen many people say these donaldsons last 10k+ so I am willing to go that far.
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: A_Harman] #5456554 06/18/20 05:28 AM
R
RateNate Offline OP
R
I was planning on t615w40 for 10k
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: ruSSrt] #5456555 06/18/20 05:29 AM
R
RateNate Offline OP
R
Agreed 3k is too early but I dont want to risk clogging this filter since its the first time ive ever ran something with this good of a filtration for engine oil.
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: RateNate] #5457260 06/18/20 08:26 PM
U
userfriendly Offline
U
It is possible to filter the additives out of the oil.
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: userfriendly] #5457614 06/19/20 10:20 AM
T
tundraotto Offline
T
At what micron level does this occur?
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: userfriendly] #5457739 06/19/20 01:30 PM
Dodgetracker Offline
Doubtful with todays filters.
2008 Dodge Ram 2500 4x4 6.7 CTD 68RFE.
2004 Jeep Wrangler 4x4 4L Straight 6 Auto.
Re: 2003 Cummins Extended OCI 10k? w Pics [Re: RateNate] #5457788 06/19/20 02:48 PM
U
U
There is no need to get creative when it comes to oil filters.
search; Yes you can filter additives out of lubricants
www.chevronlubricants.com
There are several other articles on this subject.
I am not a robot
