Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
91 registered members (4WD, 2K2AcuraTL, 97tbird, 92saturnsl2, 2010Civic, Audios, 8 invisible), 2,102 guests, and 23 spiders.
Topics307,449
Posts5,311,370
Members71,850
Grease gun woes! #5437071 05/23/20 10:06 PM
7
73guna Offline OP
7
Maybe its just me but I have a lot of trouble with manual grease guns. Its absolutely the worst part of doing a LOF on my vehicles.
Everyone Ive owned, sooner or later, will stop pumping right in the middle of the hardest zirk to reach. I have to disassemble, remove the tube and reassemble and it works for God only knows how long.
Its so frustrating!
Some of my grease guns have even went flying across the garage floor at a high rate of speed!
Thinking about air or cordle$$.
Any opinions?
Re: Grease gun woes! [Re: 73guna] #5437100 05/23/20 10:55 PM
cdlamb Offline
If you don't know how to purge the air when changing grease in a manual grease gun, you will have the same problems with electric grease gun.
When adding a new tube to a manual grease gun, I lock the spring loaded plunger back insert the tube remove the pull tab, & only screw the tube back onto the gun minimally just a turn or 1.5 threads holding it on, then unlock the plunger tube, & it will expel some of the air past the threads. You should also be able to lock the plunger so you can put pressure to the grease in the tube, & advance it up into the port.
Re: Grease gun woes! [Re: 73guna] #5437137 05/24/20 12:12 AM
W
wkcars Offline
W
Re: Grease gun woes! [Re: 73guna] #5437176 05/24/20 03:39 AM
sloinker Offline
Some of the better grease guns have a button on the head for expelling air. I still hand pack a gun from time to time if I can't find what I want in the tube or if the bulk barrel is near empty and I have to scrape up enough for my motors.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Grease gun woes! [Re: 73guna] #5437198 05/24/20 05:34 AM
L
Lapham3 Offline
L
One of mine has a 1/8" pipe plug in the head for air burping.
Re: Grease gun woes! [Re: 73guna] #5446947 06/05/20 01:49 PM
G
George7941 Offline
G
Air pockets are precisely why I gave up on tubes of grease a long time ago and I fill up my grease gun from a 5 gal pail of grease using a loader pump. No air pockets when filled up this way.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Grease gun woes! [Re: 73guna] #5450995 06/11/20 04:44 AM
R
Redright9 Offline
R
I thought I was the only one!! I have the same issue. I thought I was mechanically inclined to some degree, but was amazed how a grease gun seemed to kick my butt. I bought a few tried different brands of grease, checked tutorials, and sometimes one of them works.
Re: Grease gun woes! [Re: 73guna] #5451753 06/12/20 04:52 AM
dlundblad Offline
I struggle too, but strangely enough mine hasn’t flown across the garage yet. crackmeup
No matter how hard I try, I can’t keep the thing clean either. Greasing is such a dirty job.
My tractor has 25 fittings and that’s excluding the loader. Ick.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Grease gun woes! [Re: 73guna] #5452407 06/12/20 08:28 PM
J
jhellwig Offline
J
Use good Lincoln grease guns and good grease and there is never a problem. I have an Milwaukee m18 one that always looses prime because it pumps to fast. Leaving the pull rod out helps.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
