FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
35 registered members (Aredeeem, Dan55, carviewsonic, Danno, DaHen, d00df00d, 2 invisible), 822 guests, and 32 spiders.
Topics307,396
Posts5,310,345
Members71,843
3rd wheel bearing. Still grinding noise. #5436694 05/23/20 11:46 AM
M
Micahmcmeen Offline OP
M
This will be my third wheel bearing replacement. I replaced the fist 2 because the thought was maybe i just got a faulty one. They were the same brand bought from the same place. It sounds just like a bad bearing. I doubt I just have bad enough luck to buy 3 bad bearings in a row. What else could it be? It doesn't have to do with braking or taking turns. Noise increases with speed.
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436696 05/23/20 11:51 AM
J
JMJNet Offline
J
What car make/model/year are we talking about?
  • 2017 Toyota Sienna
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436698 05/23/20 11:52 AM
2
2strokeNorthstar Offline
2
There are a lot of junk. Roll of the dice with cheaper brands. I’ve had 2 bad right out of the box. 3 is possible but not likely. Any play when trying to rock the wheel while lifted?
2001 F150 5.4L
2013 Nissan Juke Nismo
2000 Honda S2000
1998 BMW 328i
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436702 05/23/20 11:55 AM
M
mk378 Offline
M
Have someone drive the car slowly past you while you stand outside and listen for the noise. It's easy to mis-identify the source of car noises. A truly bad wheel bearing will almost always make some noise when you turn the wheel by hand with the car jacked up. It gets a lot louder with the weight of the car on it of course.
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436709 05/23/20 12:02 PM
M
M
2010 jeep commander commander 3.7 4x4 . I putbon 2 timken and the last one a moog. There isn't any play.
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436711 05/23/20 12:07 PM
spasm3 Offline
What bearings are you buying, and how long are they lasting?
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436718 05/23/20 12:13 PM
ABN_CBT_ENGR Offline
not entirely surprising
do you have a stethoscope of any kind of electronic ear?
I presume the run out was in spec and it free spun by hand before installation?
Re: 3rd wheel bearing. Still grinding noise. [Re: spasm3] #5436719 05/23/20 12:15 PM
M
M
Stated above. When I originally replaced it the noise did go away almost. Over the next few months the noise got bad again. Assumed it was a bad bearing replaced it got a little quieter but picked up the noise to where it was with a day of driving. Same with this third one.
Re: 3rd wheel bearing. Still grinding noise. [Re: ABN_CBT_ENGR] #5436721 05/23/20 12:17 PM
M
M
Yeah in storage. They aren't expensive really i might just buy another. Yes it free spun.
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436727 05/23/20 12:21 PM
spasm3 Offline
I would make sure you have the correct torque numbers. If your numbers are wrong that could be the problem. The timken hub bearings have done fine for me.
Usually the axle nut to hub torque was around 130lb/ft.
Check somewhere else in case your source is incorrect.
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436729 05/23/20 12:24 PM
Then spin it (installed) and listen- if "this" bearing has a grind you should hear it.
Then remove the nut ( free float) and see if there is a difference.
Process of elimination- this "grind" is either coming from the new hub ( it has a force exerted on it and taking the clearance out of the bearings) or another bearing/component is failing along the shaft.
Leaving them together and careful listening should help isolate it.
If it has a force exerting on the hub then it either has to be axial or radial. Grossly misaligned ( which I would think would be visibly obvious and hard to reassemble) or taking all the clearance out of the hub ( pushing out or pulling in)
Need to check all of those possibilities
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436733 05/23/20 12:29 PM
M
M
Something that I feel really stupid about is i replaced my front shocks and struts a short time ago. I planed to have an alignment done but got busy and forgot about it. Could this be the issue?
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436735 05/23/20 12:37 PM
Definitely a possible contributing factor but to me if this was (is) the sole cause I would think if it was so far off ( to stress a hub assembly) that you wouldn't be able to drive the vehicle if you were able to fully reassemble it in the first place.
But every possible contributing factor has to be examined and confirmed/eliminated
The only "fact" we seem to have now is a statistical impossibility that the hub is the problem since you now have gone through 4 (this brings the original diagnosis now in question as well)
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436739 05/23/20 12:45 PM
F
Falkirk88 Offline
F
Check the ABS components. I don't know how these hubs are, but some have internal ABS reluctors and sensors.
Re: 3rd wheel bearing. Still grinding noise. [Re: Micahmcmeen] #5436780 05/23/20 02:10 PM
sloinker Offline
Wheel bearing and hub assembly? Replaced as a unit usually. You also have CV joints which can make noise.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
