FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
27 registered members (ArrestMeRedZ, Brad1119, blufeb95, CleverUserName, BLND1, 4 invisible), 920 guests, and 38 spiders.
Topics307,396
Posts5,310,319
Members71,843
Rough idle when cold #5436638 05/23/20 10:20 AM
M
M119 Offline OP
M
Hi there, for a few weeks now my car has been stumbling during the first 30 seconds after starting it, it sounds like it is misfiring with a loud sound in the exhaust (or intake?) like a backfire when rpm is higher during warm up. It almost stalls sometimes.
It gets smooth once rpm drops after warm up. Any idea ? Sparkplugs and coils were replaced 13k miles ago. The car is a 1998 mercedes with the M111 engine. 94k miles on the clock.
1998 Mercedes W202 C180 - 155K kms (Daily)
1995 Mercedes S124 E250 Diesel - 480K kms
Re: Rough idle when cold [Re: M119] #5436642 05/23/20 10:23 AM
Marco620 Offline
Air Intake Temp sensor or Oxygen Sensor going lazy possibly?/
15' Civic r18, 342,000 mi M1 0w30(3qt)/Redline 5w30(1qt),Castrol CVT Fluid,Redline Si-1
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind,"green" ,solar & vegan.
Re: Rough idle when cold [Re: M119] #5436647 05/23/20 10:27 AM
M
M119 Offline OP
M
I've cleaned the MAF so i start thinking about the o2 sensor... Do you think that running E85 with a flexfuel kit could lead to such issues ?
Re: Rough idle when cold [Re: M119] #5436653 05/23/20 10:31 AM
Chris142 Offline
Is it losing any coolant?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Rough idle when cold [Re: Chris142] #5436662 05/23/20 10:52 AM
M
M119 Offline OP
M
Not losing a drop of coolant.
Re: Rough idle when cold [Re: M119] #5436826 05/23/20 04:08 PM
P
PowerSurge Offline
P
Does that engine have an idle air control valve? If so, clean it. Also, I would look at the new coils if they weren’t replaced with MB coils.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
America First
Re: Rough idle when cold [Re: M119] #5436841 05/23/20 04:48 PM
M
M119 Offline OP
M
I am not sure about that but i don't think so, never heard of it. When i changed the coils i used the exact same Bosch part as the original ones.
Re: Rough idle when cold [Re: M119] #5436936 05/23/20 06:58 PM
R
ripcord Offline
R
Did you buy the coils on Amazon? Could they be fakes?
Re: Rough idle when cold [Re: M119] #5437240 05/24/20 07:14 AM
M
M119 Offline OP
M
I bought them from Oscaro, the most famous online auto part store here.
Re: Rough idle when cold [Re: Marco620] #5437304 05/24/20 09:04 AM
L
Lubener Offline
L
Oxigen sensor information is not used in open loop mode which the first 30 seconds would surely fall into that.
I would check to see where the fuel pressure is at startup and thereafter.
The "thinking" man's friend.
Re: Rough idle when cold [Re: M119] #5437418 05/24/20 11:40 AM
DrDanger Offline
I had a slightly different issue, which lasted a few minutes after cold start, engine was noisy and jittery and would occasionally stall with a small load. It went away almost completely in warm weather.
Turned out my garage was giving me bulk el cheapo oil, resulting in all sorts of issues.
Did 3 short OCI's with synthetic, ran a bunch of fuel system cleaner and intake valve cleaner.
Engine runs much better now, I still wait/warmup for a minute before driving on a cold engine.
Check "oil drop test paper" on google to gauge if oil is at all involved, or if its something else completely.
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3033196
Re: Rough idle when cold [Re: M119] #5439436 05/26/20 02:52 PM
M
M119 Offline OP
M
I will clean the maf and change the sparkplugs tomorrow and report. I have no way to check fuel pressure now. Of course the problem is worse with E85 in the tank.
Re: Rough idle when cold [Re: M119] #5440235 05/27/20 03:28 PM
M
M119 Offline OP
M
I've changed sparkplugs and cleand the MAF but there's no improvement. I think the only thing i can do now is check fuel pressure and replace the fuel pump and/or the fuel pressure regulator.
Re: Rough idle when cold [Re: Chris142] #5440247 05/27/20 03:42 PM
L
Lubener Offline
L
What I was thinking. Had it happen to me with same symptom as OP then headgasket blew out.
Re: Rough idle when cold [Re: M119] #5440662 05/28/20 06:55 AM
caprice_2nv Offline
Or intake manifold gasket? They can leak vacuum when cold, although I know nothing about that particular engine.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
