Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
18 registered members (bbhero, 340_Magnum, blufeb95, BlakeB, ArrestMeRedZ, bachman, 2 invisible), 1,153 guests, and 67 spiders.
Topics306,047
Posts5,286,354
Members71,593
dielectric grease ? #5436145 05/22/20 07:12 PM
H
hardheaded Offline OP
H
I am going to install a ignition module on my sons 04 bonneville and was wondering if i should put dielectric grease under the module before installing ? Thanks !
Re: dielectric grease ? [Re: hardheaded] #5436170 05/22/20 07:54 PM
J
Jimzz Offline
J
NO!!! Thats the wrong grease. You want thermal grease. You can find it at microcenter, bestbuy, or any place that has computer CPU grease. A little is all it takes so don't buy to much.
yup
Re: dielectric grease ? [Re: hardheaded] #5436205 05/22/20 08:29 PM
gathermewool Offline
Do you mean when you plug it in? Yes, dielectric grease.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: dielectric grease ? [Re: Jimzz] #5436254 05/22/20 09:20 PM
CT8 Offline
This.
2015 F150 2.7
2018 F350 6.2
Re: dielectric grease ? [Re: hardheaded] #5436261 05/22/20 09:36 PM
sloinker Offline
If it's for heat transfer use heat sink compound. T he electrical connection doesn't require anything.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: dielectric grease ? [Re: hardheaded] #5436302 05/22/20 10:36 PM
Dave9 Offline
In theory a good quality heatsink grease would perform a little better, but in practice silicone grease is good enough and is what's in the packet that comes with some GM ignition modules, but the contact area has to be clean, no corrosion buildup.
If you ordered OEM (or even aftermarket) but don't have it yet, I'd wait and see if it comes with grease.
Re: dielectric grease ? [Re: hardheaded] #5436309 05/22/20 10:56 PM
P10crew Offline
Dave the ignition modules came with the white high heat conductive paste for many many years. Thanks to the cal nazi’s mfg’s no longer supply the white paste. They supply of all things dielectric grease.
I would never use silicone dielectric grease to aid in heat dissipation. The white paste is available and I would only use that not insulating grease.
Another fine problem that the nuts in Cali gave the balance of the the 49 states..
Re: dielectric grease ? [Re: hardheaded] #5436381 05/23/20 04:50 AM
L
Lubener Offline
L
Use heat sink compound to transfer the heat from the module to the mounting surface.
The "thinking" man's friend.
Re: dielectric grease ? [Re: Dave9] #5436439 05/23/20 06:48 AM
W
willbur Offline
W
True. I read an article somewhere that compared plain ol dielectric grease and heat sink grease and reported only a slight improvement. The article went on to say just use the dielectric grease.
Re: dielectric grease ? [Re: hardheaded] #5436633 05/23/20 10:09 AM
J
Jetronic Offline
J
The heat transfer compound moften is a sylicon grease with metallic filler to promote heat transfer.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus V12 evo2 235/45R17
Re: dielectric grease ? [Re: hardheaded] #5436677 05/23/20 11:21 AM
H
H
So i should be installing some of this grease before putting the module in place. I wonder if Advanced Auto carries this thermal grease ?
Re: dielectric grease ? [Re: hardheaded] #5436703 05/23/20 11:58 AM
O
OVERKILL Offline
O
You should be able to find Arctic Silver on Amazon or at a local computer store (if you still have one).
Re: dielectric grease ? [Re: OVERKILL] #5436898 05/23/20 06:19 PM
W
willbur Offline
W
Interesting about the silver. My understanding is that the purpose of heat transfer grease is to fill in the air space between the mating components. Air is a very good insulator and heat transfer is greatly reduced. These compounds can't transfer heat any better than the components themselves in contact, so anything that can transfer heat as well as the components themselves will do. Some in the PC gaming world overclock their processors, generating a lot of additional heat, and use copper antiseize for this purpose. Some use zinc heat transfer paste but its just thickened zinc sun screen.
Re: dielectric grease ? [Re: willbur] #5436904 05/23/20 06:22 PM
K
kschachn Offline
K
The zinc paste is using zinc oxide, correct? Not metallic zinc. Heat transfer or heat sink paste should be thermally conductive but electrically insulating.
FWIW Autozone near me sells the proper material, they call it "heat sink compound".
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: dielectric grease ? [Re: hardheaded] #5436905 05/23/20 06:23 PM
H
HangFire Offline
H
Different heat compounds have different heat transfer coefficients... and the differences can be repeatably measurable, with the right equipment.
Various musings: http://hangfire.net
