Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
96 registered members (2015_PSD, 2009Edge, Ag76, amblerman, 53' Stude, Alfred_B, 10 invisible), 1,920 guests, and 43 spiders.
Topics306,089
Posts5,287,201
Members71,596
Naval Jelly Removes Auto Paint? #5436144 05/22/20 07:11 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
My accord seems to be more rust prone than any vehicle I’ve owned. There are a few rock chips to the primer on my hood, sesame seed sized to maybe the size of a small popcorn kernel. On one or two the primer is starting to brown, indicating that there’s probably some porosity and surface rust.
I tried ospho but didn’t really get much of an outcome. I need something with a bit more staying power. I went to the parts store to get some Naval Jelly, but hit a pause because it says to not let it touch paint.
Not sure what kinds of paint it might remove, and how much it is contingent upon rust being under the paint.
I’m not really keen on trying it, even in an inconspicuous spot, let alone the front edge of my hood. So I’m curious about if this stuff will affect modern automotive paints.
Re: Naval Jelly Removes Auto Paint? [Re: JHZR2] #5436156 05/22/20 07:30 PM
slacktide_bitog Offline
Honda's paint is terrible crzy
Are you near any of these shops? smile
Re: Naval Jelly Removes Auto Paint? [Re: JHZR2] #5436159 05/22/20 07:35 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Not a matter of getting it sprayed. It’s a matter of prepping these little spots before putting touch up paint.
Re: Naval Jelly Removes Auto Paint? [Re: JHZR2] #5436221 05/22/20 08:41 PM
T
Trav Offline
T
Try Evapo-Rust, it is slow but should not harm paint. The trick is getting it to stay put. remove as much as you can with a fiberglass pen then use a small pad made from 3-4 small sheets of newspaper and soak it in the solution then apply to the spot, leave it for an hour or two then check it.
https://www.amazon.com/Scratch-Brush-Fiberglass-Colors-vary/dp/B0019V18D2?ref_=fsclp_pl_dp_2
Re: Naval Jelly Removes Auto Paint? [Re: JHZR2] #5436233 05/22/20 08:47 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Thanks, I may have some.
I was hesitant to scratch it, as at least some (more like most) of the primer is there. It’s just starting to turn brown, so I take that as it’s porous. Do I really want to make it more porous?
Newspaper is a great idea. I’ll top it with Saran Wrap to prevent evaporation.
The real intent of a jelly was to get it to stay in place. That should work!
Re: Naval Jelly Removes Auto Paint? [Re: JHZR2] #5436291 05/22/20 10:22 PM
Dave9 Offline
It would be good to see quality pictures of these spots, but the odds are that you don't need this level of work for tiny beginnings of rust spots.
I'd try putting a cotton swab in a cordless drill, with rubbing compound on the tip. Buff the rust out with it, wash off any debris.
This will not be enough if the paint around the spot has lifted because the rust has spread under it. Nothing will fix that except removing all lifted paint and rust under it, though sealing the hole with touch up paint would temporarily slow that down.
Re: Naval Jelly Removes Auto Paint? [Re: Dave9] #5436301 05/22/20 10:34 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
I’ll try to do this tomorrow. Definitely not under the paint. No bubbles, no lift. Tiny spots, but left unchecked Im sure it could get worse.
Re: Naval Jelly Removes Auto Paint? [Re: JHZR2] #5436390 05/23/20 05:08 AM
ABN_CBT_ENGR Offline
Here is some of my experience with phosphoric acid ( and muriatic) which I believe may be close to your inquiry.
Never done car paint but have done all types of industrial coating and I imagine the effects are similar.
Naval jelly doesn't chemically destroy and or remove paint like muriatic acid ( except latex types or coats on improperly prepared surfaces) but it does get in the pores and makes it soft or otherwise changes properties in some ways ( you can visibly see the changes)
We use it for prep ( it etches very well) but has to have residue cleaned then a protective coating PDQ.
I have noticed ( based on surface finish of the substrate) that on a smooth prepped surface it softens paint but it still mostly sticks ( except if there is a crack then it makes it peel)- that said the remaining exposed paint clearly no longer has the qualities of the original so t has been 'affected' in some way and I would recommend removing it.
I have also seen on rougher castings where it doesn't seem to soak in the cracks and damage the paint at all.
I would ask someone in auto body for specifics, surely they would know
Re: Naval Jelly Removes Auto Paint? [Re: JHZR2] #5436738 05/23/20 12:43 PM
doitmyself Offline
Ospho and naval jelly are both phosphoric acid. If anything, I would think the Ospho is higher concentrated phosporic acid compared to the naval jelly. It's hard to compare the SDS's. Ospho shows 45% acid by weight, Naval Jelly shows 10-30% (weight or volume???).
Maybe the gel part of naval jelly is more hazardous to paint? Still, I would not expect better results from naval jelly vs. Ospho since they both are based on the same type of acid.
On new tight chips, the factory applied metal treatment should mitigate rust creep. Having said that, on old paint chips I have enlarged them to find rust "veins" creeping underneath the paint on vehicles with poor paint systems.
All you can do is try. Sometimes I just prime and paint (toothpick) on tight new chips. Other times I abrade to clean metal, metal prep, prime, paint. Again, with homemade micro tooling (spot sanding tool)
[Linked Image from newmantools.com]
Re: Naval Jelly Removes Auto Paint? [Re: JHZR2] #5441947 05/29/20 04:33 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Have been so swamped... here are some pics. The screw is a #8 spax iirc.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Don’t mind the horrible pollen mess we have around here.
