I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
35 registered members (90Notch, AdRock, 2009Caraman, ArrestMeRedZ, AZjeff, Blkstanger, 4 invisible), 1,229 guests, and 47 spiders.
Topics306,032
Posts5,285,234
Members71,566
P0420 code and exhaust leak #5436065 05/22/20 05:11 PM
H
hatt Offline OP
H
F150 check engine light came on yesterday. Did a scan with Torque Pro and P0420 Bank 1 came up. Looking though whatever I can see on the app the 02 sensors seemed to be operating okay. The offending ratio was barely out of range. Heat gun showed hotter behind the cat but it was hard to get good readings in the driveway with the position of the cat and it was at idle since I didn't have an extra body. Getting under the other side I could hear what sounded like a small leak. Power and economy have not changed. How likely is the leak the culprit? Oddly, I also just got the truck back yesterday from having the speed sensor recall done, and had them look at an airbag issue. The computer was reset it appears. Could the software update have changed the acceptable range?
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: P0420 code and exhaust leak [Re: hatt] #5436079 05/22/20 05:40 PM
M
MParr Offline
M
I would take it back to the dealer and explain your problem, as you have done here. They may have inadvertently done something to cause the problem.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: P0420 code and exhaust leak [Re: hatt] #5436140 05/22/20 07:06 PM
2
2010Civic Offline
2
Reset the code and see if it comes back. If it does I'd consider a defowler for the o2 sensor. I did that on a 05 accord and the P0420 code has never returned.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: P0420 code and exhaust leak [Re: hatt] #5436147 05/22/20 07:14 PM
Charlie2015 Offline
There is a federally mandated 8 year / 80k mile warranty on converters.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 170k mi - Valvoline Maxlife 5w30
Re: P0420 code and exhaust leak [Re: 2010Civic] #5436152 05/22/20 07:25 PM
H
hatt Offline OP
H
I reset it last night. It came back.
Re: P0420 code and exhaust leak [Re: Charlie2015] #5436153 05/22/20 07:26 PM
H
hatt Offline OP
H
120K
Re: P0420 code and exhaust leak [Re: hatt] #5436265 05/22/20 09:38 PM
clinebarger Online Content
Online Content
Probably a broken manifold bolt. A precatalyst exhaust leak can certainly cause low catalyst efficiency codes. It wouldn't be the first time a new calibration caused DTC's because different failure thresholds.
If you know someone with HP-Tuners.....This can be remedied with a few keystrokes wink
2001 Chevy Camaro L92/4L80E
Re: P0420 code and exhaust leak [Re: hatt] #5440048 05/27/20 10:39 AM
H
hatt Offline OP
H
The last few times I've driven the truck I've noticed the offending ratio was back in range. Light went off today on it's own. grin
Re: P0420 code and exhaust leak [Re: hatt] #5440147 05/27/20 01:15 PM
Propflux01 Offline
What is a defowler?
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: P0420 code and exhaust leak [Re: Propflux01] #5440150 05/27/20 01:19 PM
bdcardinal Offline
Originally Posted by Propflux01
What is a defowler?
https://www.amazon.com/Dorman-42002...mp;psc=1&refRID=0AXBXJEQKVREZM3M0JY6
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: P0420 code and exhaust leak [Re: bdcardinal] #5440509 05/27/20 09:41 PM
Propflux01 Offline
What is a defowler?
Ah, yes, a converter cheater.
