Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
64 registered members (77GrandPrix, aquariuscsm, Ag76, 69Torino, Alfred_B, 6 invisible), 1,369 guests, and 44 spiders.
Topics306,271
Posts5,289,370
Members71,616
dry rot #5435937 05/22/20 02:10 PM
P
phillyFX4 Offline OP
P
Guess I drive like an old man, so my brother tells me LOL
I rotate my tires(all 5) religiously every 5K..... they have close to 30K and not much wear....
had these(BFG KO2's) installed at the stealership 4+ years ago and the young guys who worked there kept 2 of the old tires(older BFG's) that had almost 50K wink
anything on the market I could apply to the sidewalls to help slow down the dry rot ?
thanks Cheers2
Re: dry rot [Re: phillyFX4] #5435945 05/22/20 02:19 PM
stroked93 Offline
They are probably running hot. How much air pressure you running. If your door says 35 and you truck came with a P meteric tire you need to increase the pressure. I have a 1/2 to 4wd truck BFGoodrich consumer affairs said to run 44lbs
Re: dry rot [Re: phillyFX4] #5435974 05/22/20 03:07 PM
R
Rand Offline
R
303.
Re: dry rot [Re: phillyFX4] #5436022 05/22/20 04:22 PM
M
MasterSolenoid Offline
M
Do those Tire Shine sprays pull the oils out of the tires speeding up the dry rot ? ? ?
I've never used them (I'm to cheap).
OP, do you park in a garage ? / that would help.
I had 103,000 miles on my first set of tires / I admit I ran them too long.
The second set I may get 65,000.
OP - Get yourself a Digital Tire Pressure Gage if you don't already have one.
There great for adding or removing air / quick and easy.
When I check my tire pressure, I fill out a Spread-Sheet along with the Temperature.
[Linked Image]
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: dry rot [Re: phillyFX4] #5436049 05/22/20 04:48 PM
P
P
running BFG TA/KO2's 285/65/18's load range E
usually run them at btwn 50 and 60 psi …..
they're close to 32K miles now
Re: dry rot [Re: phillyFX4] #5436149 05/22/20 07:18 PM
J
jjjxlr8 Offline
J
Soap and water is really all you should use. Many of the products people put on the sidewalls to protect the rubber actually do the opposite. Tires already have anti-ozonants and anti-oxidants formulated in the rubber.
1993 Toyota MR2 Turbo
2008 Mazdaspeed3
2014 Toyota Highlander XLE
Re: dry rot [Re: phillyFX4] #5436229 05/22/20 08:45 PM
Strokenmerc Offline
Get some 303 aerospace UV protectant. "It's like sunscreen for your stuff".
2018 Kia Sportage
2011 Chevrolet Cruze
2004 Silverado 2500HD
2003 Chevrolet Trailblazer
2001 Chevrolet Camaro SS
1999 Toyota Tacoma
Re: dry rot [Re: phillyFX4] #5436245 05/22/20 09:04 PM
M
mrsilv04 Offline
M
thanks Cheers2
Stop buying tires made by Michelin... the king of dry rot. (hint: Michelin owns BFG)
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: dry rot [Re: stroked93] #5436276 05/22/20 09:55 PM
Dave9 Offline
Putting some goop on the sidewalls is a major gamble, besides by the time the sidewall gets dry rot cracks, the tread has hardened and will be less safe for ice or rain. If treated well, you shouldn't have excessive dry rot for at least the first 6 years.
There are 3 main things for tires kept on the vehicle - besides the obvious of proper inflation level, but it is unlikely that you need more than 40PSI unless you're hauling loads or these tires are smaller than the factory tires.
1) Try to park where there is not direct sun, for example out in the open facing north or south with unobstructed sun from east or west. If you do this in your driveway at home, or at work every day, expect shorter life before dryrot.
2) Don't let it sit undriven for long periods of time. Driving spreads the lubricants and protectants around and to the surface of the tire.
3) Use only mild soap to wash them, similar to what you'd use on the paint to not strip wax away. Do not use those super strong spray-on wheel cleaners either unless you know what is in them and are sure it is 100% compatible with tire rubber. Of course they (manufacturer) would say it is but that doesn't make it true. If it lifts grime off your wheels better than mild soap solution does, odds are very high that it's worse on your tires.
Re: dry rot [Re: phillyFX4] #5436324 05/22/20 11:23 PM
StarCaller Offline
@MasterSolenoid
Quote
what kind of tires ?
Re: dry rot [Re: phillyFX4] #5436383 05/23/20 04:53 AM
L
Lubener Offline
L
thanks Cheers2
Keep them out of the sun. That's about all you can do. U/V protectors do more harm than good.
The "thinking" man's friend.
Re: dry rot [Re: phillyFX4] #5436928 05/23/20 06:54 PM
P
P
cheers
Re: dry rot [Re: StarCaller] #5437682 05/24/20 04:55 PM
M
M
Originally Posted by StarCaller
@MasterSolenoid
Quote
Good Year - Wrangler, RT/S
2 Wheel Drive
3.0 Liter Engine
Re: dry rot [Re: mrsilv04] #5445422 06/03/20 02:55 PM
B
BLND1 Offline
B
thanks Cheers2
LOL
“Our tires wear so well that dry rot is more of a concern than mileage.” Sounds like a TERRIBLE problem to have.
New formulations haven’t had quite the dry rot problems of old.
