Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
24 registered members (bworley, CaspianM, bachman, BlakeB, ajchien, CDX825, 1 invisible), 1,199 guests, and 49 spiders.
Topics305,879
Posts5,281,962
Members71,528
DIY: 2018+ Camry 4-cyl ATF Change (UB80E) #5435903 05/22/20 01:39 PM
The Critic Offline OP
Also posted this on ToyotaNation.
2018 Camry XSE 4-cyl, non-hybrid. 61,800 miles.
After the car had been sitting for over 20 hours, I drained the ATF and was able to collect exactly 3 quarts after removing both the drain plug and the threaded stand pipe. The drain plug is a 10mm hex and the threaded stand pipe is a 6mm hex.
[Linked Image]
Next, I reinstalled the drain plug and pumped in 3 quarts of Idemitsu Type TLS-LV ATF using my AST fluid filler (you can also use a funnel and the appropriate-sized hose). Note: the fill plug is a 24mm and is accessed thru the driver-front fender well.
[Linked Image]
[Linked Image]
After temporarily reinstalling the fill plug, I started the engine and shifted thru each gear selector position (P-R-N-D) while keeping the gear selector in each position for 3 seconds. I performed this procedure twice. Then, I allowed the engine to idle for an additional 2 min in Park to allow for the fluid to circulate.
After the previous step was complete, I repeated the drain and refill process two additional times - for a total of 3 times.
After the 3rd drain, I replaced the drain plug gasket and refilled with 3.2qts to allow for extra fluid to drain out during the fluid level adjustment process.
I used an Autel MD808 Pro scan tool, but you can use other methods as well (e.g. IR temp gun, built-in A/T temp light, etc.). The key is to get the fluid temp between 95-113 with 104F being the ideal temperature. After the 3rd drain, you may need to allow the engine to cool for 1-1.5 hr in order for the fluid temperature to drop; the transmission heats up very quickly and the few minutes of idling between each drain and refill may put the fluid temperature outside of the allowable range.
Note: It is very important to start the fluid level adjustment process with the fluid temperature in the mid 90F range in order to allow for enough time to go thru each gear selector position and for the engine idle speed to drop.
[Linked Image]
In total, I drained about 9.3 quarts (over 3 drain and refills) and refilled with about 9.3-9.4 qt. The old fluid was dark but not burnt. After the transmission service, shifts are noticeably smoother when the transmission is cold.
Hope this helps!
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: The Critic] #5435913 05/22/20 01:48 PM
J
JMJNet Offline
J
Thanks for posting.
  • 2017 Toyota Sienna
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: The Critic] #5435918 05/22/20 01:50 PM
J
JeffKeryk Offline
J
Nice job Michael. I'm sure you know some Toyota/Lexus "purists" say to never service the transmission. It's lifetime fluid!
The Lexus GS website smacks you down for even thinking about it... Ha!
This will help me as I service the GS next week.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: The Critic] #5435925 05/22/20 01:57 PM
Delta Offline
Great info! Looks like Toyota has been keeping the "AT At Temp" monitor pin 4 and 13 on the OBD connector for a while now.
'17 VW GTI 2.0T - 6MT - 21K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 26K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 141K - RGT 5w30
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: The Critic] #5435972 05/22/20 03:05 PM
R
Ram02 Offline
R
That’s a lot of work lol but hey at you got fresh fluid
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: The Critic] #5435991 05/22/20 03:31 PM
J
JustN89 Offline
J
What pump is that? That looks pretty nifty!
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: JustN89] #5436011 05/22/20 03:57 PM
https://asttool.com/detail_page.php...t=18&stype=advanced&keywords=ATF
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: The Critic] #5436052 05/22/20 04:50 PM
M
michaelluscher Offline
M
This has been a point of discussion on /r/Camry
Good to see that it's DIYable, with some good planning
Since yours is an '18, did you get the reflash that I'm told makes things much better?
'17 CTS Performance AWD 3.6 11K
'06 Camry SE 3MZ-FE 146K
'06 Taurus SE Vulcan 65K
'01 Villager Estate VG33E 55K
'83 Grand Prix LJ 305 SBC 56K
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: michaelluscher] #5436057 05/22/20 04:54 PM
Funny you mention the reflash: the owner of the car asked me about this a few mins ago. He hates going to the dealer, so he is going to have me do the reflash later today.
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: michaelluscher] #5436098 05/22/20 06:16 PM
Reflash is in progress now.
T-SB-0152-19 Rev1
[Linked Image]
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: The Critic] #5436099 05/22/20 06:16 PM
dwcopple Offline
What a PITA. Changing fluid shouldn't be that big of a pain. So stupid.
2019 RAM Big Horn 4x4 Blackout HEMI crew cab
2011 Chrysler 200 Limited 3.6L V6
1998 Mustang GT 4.6L V8 convertible
2019 VW Jetta SEL 1.4T
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: The Critic] #5436122 05/22/20 06:40 PM
M
M
T-SB-0152-19 Rev1
[Linked Image]
Lucky man
Way to rub it in
I need my '06 updated, but I'm not paying the 2+ hours of labor my local dealer wanted
I keep a knockoff Techstream, works fine for checking deeper modules then OBD2, programming keys and TPMS
But I don't trust it for reflashing
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: The Critic] #5436135 05/22/20 06:59 PM
G
Gebo Offline
G
How did you decide to use TLS for the fluid? Just asking. I believe the AT calls for WS.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: Gebo] #5436334 05/22/20 11:40 PM
Lucky man
Way to rub it in
How much did your dealer quote you? Drewtech's RAP2 service can do a remote programming session for you for $125. Their rental box which contains a tablet, 4G internet, cables and power maintainer is $50/mo to rent, so $175 total.
http://drewtech.com/RAP/capabilities.html
I used Type TLS-LV.
Re: DIY: 2018+ Camry 4-cyl ATF Change (UB80E) [Re: The Critic] #5437757 05/24/20 06:11 PM
A
Amkeer Offline
A
Nice write up! Thanks for sharing.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
