e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
86 registered members (4WD, 2015_PSD, 94astro, Avery4, 2010Civic, 10 invisible), 2,271 guests, and 101 spiders.
Topics306,301
Posts5,289,831
Members71,618
Page 1 of 3 1 2 3
why don't makers use Stainless Steel #5435851 05/22/20 12:22 PM
W
WhyMe Offline OP
W
for mower decks. seems that many rust out before the engines give out. my aluminum toro seems to be holding up fine after 20 years . i would think if they made them of SS that would cure the rusting issue
Re: why don't makers use Stainless Steel [Re: WhyMe] #5435852 05/22/20 12:22 PM
H
hallstevenson Offline
H
Re: why don't makers use Stainless Steel [Re: WhyMe] #5435864 05/22/20 12:44 PM
Dave9 Offline
Yes, more expensive and they generally assume the average owner isn't going to repair much so it'll last as long as the engine does. Granted, depends on what you spend an how old it is, some cheap decks today are thinner than they used to be.
You can get longer life out of a steel deck by spraying the underside with cooking spray (oil) before mowing if the grass has much moisture in it. That also makes cleaning it out easier, so you don't have wet grass sitting there, promoting rust. Push mowers, I'd just tilt them up (not enough to let oil leak out) and spray with a hose after mowing. If you want a cheaper alternative to cooking oil, use leftover old 2 cycle oil/gas mix but put a little more oil in it, and it'll still be thin enough to spray with a typical spray bottle. Do wait till the gas evaporates to run the engine, don't spray with a hot engine (odds of a problem are low but why rush it?).
If you've let it go for too long, you can do the same as any other rusty metal and wire brush it to a hard surface then rustoleum/etc enamel paint, but anything you do to keep water from soaking into crusty rusty metal is going to help.
Re: why don't makers use Stainless Steel [Re: WhyMe] #5435872 05/22/20 12:53 PM
J
JTK Offline
J
I want to say there was a particular make/model made with a SS deck some years back. May have been a Sam's Club thing. I'd imagine it's a cost thing and they don't want to make them TOO good.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: why don't makers use Stainless Steel [Re: WhyMe] #5435874 05/22/20 12:55 PM
B
brages Offline
B
Would stainless be better than aluminum?
Re: why don't makers use Stainless Steel [Re: WhyMe] #5435877 05/22/20 12:58 PM
Dave9 Offline
^ Yes unquestionably better for rust resistance, but more expensive and heavier for same rigidity, so "better" depends on whether your deck really needs to outlast everything else or whether it's just more money tied up in a mower which after ~20 years (even drawing interest), could've been put towards a new replacement mower.
Too many factors to try to make a universal case one way or the other. It'd make more sense for a higher end mower, used in a very rainy climate.
I'd like to see stainless used more on unibody vehicle undercarriages, the floor pan, frame rail and wheel well housing strut support areas.
Re: why don't makers use Stainless Steel [Re: hallstevenson] #5435884 05/22/20 01:10 PM
G
gman2304 Offline
G
Originally Posted by hallstevenson
This, plus weight. My 1998 JD JX75 has an aluminum deck and still weighs just over 100 lbs.
Re: why don't makers use Stainless Steel [Re: WhyMe] #5435891 05/22/20 01:21 PM
A
Alfred_B Offline
A
I don't think a lot of mowers get discarded due to rusted decks.
Re: why don't makers use Stainless Steel [Re: WhyMe] #5435892 05/22/20 01:23 PM
H
H
Originally Posted by WhyMe
....that would cure the rusting issue
Also, there is no rusting "issue" to the manufacturers though. Realize that the vast majority of mowers out there are sub-$200 models from Walmart and the big-box hardware stores (and in more recent years, sub-$150). There's no interest in making them that much better. Honda has a deck made out of a very durable "plastic" but they run $400+.
Re: why don't makers use Stainless Steel [Re: WhyMe] #5435958 05/22/20 02:38 PM
CR94 Offline
My brother still has the Murray mower our parents bought in 1958, and it still does its job, although the engine had to be replaced when it was only 9 years old. The deck (what's left of it) is steel.
2011 Toyota Prius now at 110K
Re: why don't makers use Stainless Steel [Re: brages] #5435959 05/22/20 02:38 PM
ABN_CBT_ENGR Offline
Depends on the scenario you would be addressing
Re: why don't makers use Stainless Steel [Re: WhyMe] #5435966 05/22/20 02:51 PM
E
Eddie Offline
E
Cost and weight and will outlast the owner and many replacement engines. Ed
2014 CX5 Touring 2.5L :-)
Re: why don't makers use Stainless Steel [Re: WhyMe] #5436017 05/22/20 04:05 PM
A
andyd Offline
A
stainless is more expensive to form
Thick oil is better grin2
Re: why don't makers use Stainless Steel [Re: WhyMe] #5436018 05/22/20 04:13 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I always thought the plastic deck Honda mowers were kind of neat. But theyre heavy too!
Re: why don't makers use Stainless Steel [Re: WhyMe] #5436077 05/22/20 05:34 PM
W
Wolf359 Offline
W
Yeah, I've never had a gas mower last more than a couple years. Either they broke out of warranty or they got stolen...
Page 1 of 3 1 2 3
