This stuff gets two thumbs up. It is not a quick detailer. It is thick or has sem-solids(fine polish?) in it. You can feel it settled in the bottom of the spray bottle. Wash car and dry or don't. Shake bottle well. Spray on one area and work in with a soft cloth and then remove with a different one. Not saying its the "end all be all" but if you are pressed for time and/or want to touch up a finish It works well in my book. YMMV. It leaves a very slick surface behind and the gloss is GREAT! Several Youtubers have tested it much more in depth than me and give it a good rating as well. I will keep a bottle handy on my shelf from now on.
