Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
Aluminum Welding Question
by George7941 - 06/05/20 01:21 PM
Will 0w40 be good for next winter?
by mahanddeem - 06/05/20 01:21 PM
Motor Oil Saver less than 10.00 shipped
by cknight49090 - 06/05/20 12:27 PM
Taking my kid fishing
by Quattro Pete - 06/05/20 12:22 PM
How to rebuilt a starter
by LazyDog - 06/05/20 12:11 PM
LouK2, Michael328i, tyman, Knot_A_Mekanik, Matts59
71615 Registered Users
100 registered members (Astro_Guy, 4WD, 2whlgeezer, 77GrandPrix, amblerman, Avery4, 12 invisible), 1,875 guests, and 76 spiders.
Topics306,263
Posts5,289,230
Members71,615
Royco or Aeroshell 555 turbine oil #5435557 05/22/20 12:53 AM
H
HiCountry Offline OP
H
Good day,
I didn't see this on the forum anywhere so I thought I would ask. Has anyone here every tried the Royco or Aeroshell oil in their transmission? I know it's used by some at the dragstrip and wondered how it would be in a"normal" transmission.
Re: Royco or Aeroshell 555 turbine oil [Re: HiCountry] #5435609 05/22/20 06:34 AM
T
thastinger Offline
T
I use the rayco in my supercharger. I've never ran it in a transmission, I run RP synchromax in my manual transmissions
Re: Royco or Aeroshell 555 turbine oil [Re: HiCountry] #5435685 05/22/20 08:42 AM
T
Tom NJ Online Content
Online Content
T
The AeroShell and Royco "Triple Nickel" turbine oils are based entirely on POEs and contain anti-oxidant, anti-wear, extreme pressure, anti-corrosion and anti-foam additives. They do not contain some typical transmission additives such as detergents, dispersants, ZDDP, S/P EP additives, or friction modifiers. They are very stable at high very temperatures, but more important for transmissions is viscosity and frictional properties. At only 5.3 cSt @ 100°C, these oils are about 15-30% thinner than most ATFs and much thinner than most typical manual gearbox oils. I have no idea what the frictional properties are like. Keep in mind that with a 100% light POE base oil these oils may attack elastomer seals. If you want to try it I would consider it a risky experiment.
Re: Royco or Aeroshell 555 turbine oil [Re: HiCountry] #5435694 05/22/20 09:02 AM
Cujet Offline
I work in the aviation industry and from time to time, I see a younger tech pouring 2380 or 254 into his engine! We had one kid who used waste jet engine oil (still very clean) exclusively in his 2.8L powered GM car. The super thin oil did not result in quiet engine operation. But I don't recall any failures.
It's good to remember that these turbine engine oils are tasked to lubricate some very highly loaded gearboxes. Examples include the Pratt PT-6 and the Pratt Geared turbofan, to the Garret 731 geared engines. All of which use gears to reduce the engine's HP output to drive a prop or fan at a much lower RPM.
Re: Royco or Aeroshell 555 turbine oil [Re: HiCountry] #5435801 05/22/20 11:24 AM
T
Online Content
T
AeroShell 555 is a high load carrying version of MIL-PRF-23699 and AS5780 spec oils and contains an extreme pressure additive, so it is designed to handle highly loaded gearboxes in helicopters and turboprops. Oils like Eastman 2380 and Mobil 254 do not contain an EP additive, only anti-wear (TCP). I would be wary of running an engine or transmission on these oils. It may take time for the damage to be noticeable, but with no ZDDP, detergents, or dispersants you are not doing an engine any good.
Re: Royco or Aeroshell 555 turbine oil [Re: HiCountry] #5435803 05/22/20 11:25 AM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by HiCountry
Good day,
What do you mean by "normal" transmission? Manual or Automatic???
It has been discussed before .
It is not suitable for either transmission type because:
1) it does not the proper friction modification package,
2) it does not have the proper AW content
3) since it is about 99% POE, the tranny seals and gaskets might have a problem with leakage.
My BIL and I go to the dragstrip with his highly modified S-10 but I can report to you those guys that admitted to using pure turbine oil sure do a lot of tranny rebuilding.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: Royco or Aeroshell 555 turbine oil [Re: MolaKule] #5436021 05/22/20 04:19 PM
N
nascarnation Offline
N
Originally Posted by MolaKule
[quote=HiCountry]
I assume this is the quest for lower spin loss? Maybe they should try kerosene.....
Re: Royco or Aeroshell 555 turbine oil [Re: Tom NJ] #5437399 05/24/20 11:01 AM
Cujet Offline
Thanks, that's great information. We are now required to use a specific lubricant in our heli gearboxes called Castrol "Transmax". I don't know anything about it, other than it's $2300 initial cost. It came in nondescript grey bottles with no mil spec. (not the automotive stuff) I'd guess it contains the EP additives, as the gear wear patterns are one of the things they were trying to address.
The Pratt PT-6 often comes from the factory, serviced with 2380. They don't seem to experience any gearbox related failures, even over decades of 2380 use (on our PC-12's) . Our Helicopter engines, Troublemeca Arrius 2B1's have internal gearboxes that reduce the free turbine's 56,000 RPM to 6000 RPM. We use 254, not for gearbox protection, but to help reduce coking. In over 20 years of operating these engines, the gearbox is the least of the worries with these junkers, er engines .... smile smile smile (3 catastrophic engine failures within 1000 hours)
Re: Royco or Aeroshell 555 turbine oil [Re: HiCountry] #5441794 05/29/20 12:25 PM
T
Online Content
T
From what I can see online, Castrol Transmax is just a line of synthetic ATF and manual transmission oils and sell at Walmart for about $20/gallon. Apparently yours is a special version designed for helicopter gearboxes.
Eastman 2380 is a bit different than all other 23699/AS5780 oils. Like Mobil Jet II it is an old (1964) 2nd generation jet turbine oil, but unlike the other turbine oils all based on PE type POEs, Eastman 2380 is based on a dumbbell blend of TMP and DiPE POEs. The high dose of DiPE type POE and longer fatty acids on the TMP gives it an advantage with respect to lubricity, however it is a negative for deposits at very high temperatures (not an issue in gearboxes).
Mobil Jet 254 is a 3rd generation oil (1979) designed to reduce high temperature coking through the use of a special anti-oxidant. The current 4th generation low coking benchmark oil is Eastman 2197 which uses a special anti-oxidant combined with a low coking POE (for which I have a patent). ExxonMobil and Shell also have 4th generation oils going through approvals, Mobil Jet 387 and AeroShell Ascender respectively.
