Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
15 registered members (Char Baby, bachman, blufeb95, BlakeB, E365, 1 invisible), 1,092 guests, and 44 spiders.
Topics306,047
Posts5,286,360
Members71,593
2020 Toyota 4Runner Differential Front & Rear #5435529 05/21/20 11:29 PM
J
jrommelt Offline OP
J
Calls for 75W-85.
Can I use 75W-110 (Amsoil) ?
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435531 05/21/20 11:36 PM
02SE Offline
You can if you want. I'd probably wait until you had at least 5k on the truck first, though. Just to get some of the break-in material out of the rear axle in particular.
Toyota went to lighter viscosities in the USA, to try to eek out a few extra percent of MPG.
What model and color?
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435583 05/22/20 04:48 AM
dave123 Offline
Why not 75w90 Amsoil I see no need for 110
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435585 05/22/20 05:21 AM
B
BlakeB Online Content
Online Content
B
I’m going with 75w90 on a 2016 4Runner @ 30,000 miles.
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: dave123] #5435591 05/22/20 05:41 AM
Astro14 Offline
+1 - and that's exactly what's in my Tundra, which has the same specification.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435598 05/22/20 05:56 AM
Delta Offline
75w90 synthetic and call it a day. I run ST Synthetic 75w90 in the front and rear on my older 2nd gen Taco, but they're still very similar to your setup. Mobil 1 75w90 is also popular. AFAIK you do not need a limited slip additive as they use the ABS system for mimicking LSD. Most syns have the additive already in there, but there's no harm. You could use the Amsoil if you expect to be running the snot out of it, but just for daily driving and snow, IMO there's no need to spend that much...
The transfer case does require a different fluid compared to the older years, but there's a recent thread with good information.
'17 VW GTI 2.0T - 6MT - 21K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 26K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 141K - RGT 5w30
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435632 05/22/20 07:16 AM
Chris142 Offline
Autozone sells Chevron Delo Synthetic 75w-90 for $7/qt.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435646 05/22/20 07:44 AM
Z
zfasts03 Offline
Z
I plan on doing my diffs and transfer case around 30,000-50,000 miles. Probably with Amsoil 75w-90 Severe gear in diffs and Toyota 75w in the Transfer case.
I will also do the Transmission pan drop. fluid and filter. Probably with Amsoil Sig. Series low vicosity.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435670 05/22/20 08:15 AM
P
PowerSurge Offline
P
Why not make it easy and go back with what Toyota calls for?
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435673 05/22/20 08:20 AM
stockrex Offline
Thicker oil = more work for diffy, if you are NOT running very high temps i.e. pulling a trailer full time, you are fine using the spec'd oil.
if you pick a heavier oil you will lose some mpg.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435675 05/22/20 08:24 AM
2
2004tdigls Offline
2
why not just use a GL5 80w90, the difference in viscosity would be nearly irrelevant ???
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435710 05/22/20 09:23 AM
Chris Meutsch Offline
I just bought Red Line's 75W-85 for mine. Cheaper than Toyota's and is exactly correct.
I'm sure 75w-90 would be fine also. I still have warranty coverage......
2016 Toyota 4Runner Trail Premium, 58k
*RIP* 2005 Honda CR-V EX, 284k
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435787 05/22/20 11:04 AM
CT8 Offline
It depends upon your useage thicker oil helps with the shock loading and protection with greater loads I use 75W140 in my Toyotas [now my sons] rear differentials I never noticed and MPG differences.
2015 F150 2.7
2018 F350 6.2
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435791 05/22/20 11:06 AM
R
Reddy45 Offline
R
75w90
Re: 2020 Toyota 4Runner Differential Front& Rear [Re: jrommelt] #5435870 05/22/20 12:50 PM
K
Kamele0N Offline
K
Pay attention if rear diff needs LSD oil/additive...
My LC has clutches in rear one...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
