Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
85 registered members (830Lee, 97prizm, ABN_CBT_ENGR, 4WD, 55hambone, 555, 5 invisible), 2,093 guests, and 66 spiders.
Topics306,053
Posts5,286,519
Members71,593
Baldwin oil filter on ATS 2.0 turbo #5435458 05/21/20 09:14 PM
Dd3 Offline OP
Currently using wix wl10290 which I think is a good, solid filter for 5-6 k oci’s, but I have a Baldwin on the shelf that I’d purchased just before I read the ADBV pressure was lower (20psi) vs the stock PF64 (and the wix I have) both @ 22psi. (which is what Cadillac says I need for my car) My question is will the engine even realize the difference of 2psi? Other than the psi difference, do the Baldwin and Wix compare similarly?
Thanks.
2014 Cadillac ATS 2.0T AWD
Re: Baldwin oil filter on ATS 2.0 turbo [Re: Dd3] #5435460 05/21/20 09:18 PM
slacktide_bitog Online Content
Online Content
It will be fine smile
Re: Baldwin oil filter on ATS 2.0 turbo [Re: Dd3] #5435470 05/21/20 09:28 PM
Z
ZeeOSix Offline
Z
Thanks.
The bypass valve setting will differ slightly between different brand oil filters for the same vehicle because the bypass valve setting is also dependent on the filter design, and not all based on the vehicle it's going on.
Re: Baldwin oil filter on ATS 2.0 turbo [Re: ZeeOSix] #5435498 05/21/20 10:07 PM
Dd3 Offline OP
thanks guys. I think I have it now.....so each filter will work for whatever application it’s designed for despite it possibly being off a couple psi because that was taken into consideration while constructing the filter for said application.
Re: Baldwin oil filter on ATS 2.0 turbo [Re: Dd3] #5435534 05/21/20 11:46 PM
O
oldhp Offline
O
Remember the couple of pounds difference is only if filter becomes plugged or severe cold starts when oil would be at it's thickest. Bypass settings have no effect on fully warmed up engine running oil pressure
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Baldwin oil filter on ATS 2.0 turbo [Re: Dd3] #5435542 05/22/20 12:15 AM
Z
ZeeOSix Offline
Z
Some oil filters are specified by the filter designer to fit literally dozens of different vehicle engines. All those vehicles can't be designed exactly the same to require exactly the same oil filter with the same exact bypass valve setting. So that goes to show that the bypass setting is probably more dependent on the filter's design than the design of the engine it's going on.
Re: Baldwin oil filter on ATS 2.0 turbo [Re: ZeeOSix] #5436355 05/23/20 02:21 AM
Dd3 Offline OP
Got it. Thanks all for the replies. Any thoughts on the filtering/flow of ea of the two aforementioned filters? I’ve red that the Baldwin’s aren’t anything to write home about in regards to filtering, but with 5-6k oci’s, will it be that big of an issue? How MUCH better is the wix? (Using regular wix.... not the long OCI upgraded ones)
Thanks
Re: Baldwin oil filter on ATS 2.0 turbo [Re: Dd3] #5436405 05/23/20 05:43 AM
B
Bighorn2500 Offline
B
They are both solid filters.
Wix may have a slight edge in filter media and micron rating.
I have experience using Baldwin filters on my truck, they are a good product and are very forthcoming regarding information if you email them.
I’d use either without issue.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: Baldwin oil filter on ATS 2.0 turbo [Re: Dd3] #5436438 05/23/20 06:48 AM
silversport Offline
you could also try the UPF-64R (formally their UltraGuard line) which is AC Delco's best filter...
Bill
Re: Baldwin oil filter on ATS 2.0 turbo [Re: Dd3] #5436580 05/23/20 09:01 AM
F
Farnsworth Offline
F
What is the single number quoting, the start, or in the middle of the valve stroke? Fram quotes 19-25, the middle of that being 22. So if the Fram were to quote a starting number it would be 19. Baldwin could be a 20-24 range and the middle is 22, but they call the pressure 20. You are definitely OK imo.
https://www.fram.com/parts-search/X...AGhDAZgNgBYAdAOy1IFcAbazK2%20muhl5p2gXSA
Re: Baldwin oil filter on ATS 2.0 turbo [Re: silversport] #5436748 05/23/20 01:01 PM
Dd3 Offline OP
Bill
Thanks for the replies everyone.
I haven’t looked it up yet, but I’d imagine the bypass valve pressure is 22 on the UPF-64R as well?
Just looked it up. Looks like the bypass pressure for that is 35 psi.
Re: Baldwin oil filter on ATS 2.0 turbo [Re: Dd3] #5436783 05/23/20 02:18 PM
L
LMG1 Offline
L
Bill
Where did you see the spec for that?
Re: Baldwin oil filter on ATS 2.0 turbo [Re: LMG1] #5437061 05/23/20 09:47 PM
Dd3 Offline OP
Bill
Hmmm I think I just googled PF64R bypass pressure or something to that effect. Came right up without me even having to click on anything
