Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
75 registered members (ArrestMeRedZ, 4WD, 762fermeandyou, 86cutlass307, 55hambone, aquariuscsm, 5 invisible), 1,943 guests, and 35 spiders.
Topics306,299
Posts5,289,808
Members71,618
Change in weights and specs #5435375 05/21/20 07:44 PM
DaveSwan Offline OP
I have a 2008 Mercury Mariner with a V6 and have always used 5w/20 blend, usually Motorcraft. Changes are every 6k and I have to add a quart or so between changes.
For my car, Castrol recommends Edge 5w/30 that in addition to SN, is also ACEA A5. I do know that in Europe Ford calls for that, also Jaguars with that engine in that time used it.
Do they know something I don't know?
Re: Change in weights and specs [Re: DaveSwan] #5435383 05/21/20 07:50 PM
O
oldhp Online Content
Online Content
O
welcome The short version. USA wants MPG, CAFE standards. Across the pond they're more concerned with engine protection, less on MPG or/and EPA.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Change in weights and specs [Re: DaveSwan] #5435389 05/21/20 07:58 PM
bdcardinal Offline
Have you ever done the valve cover gaskets on that V6? If you haven't, check for leaks and while you have the covers off check the torque on the cam cap bolts. https://www.youtube.com/watch?v=V5azm1NS2_M
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Change in weights and specs [Re: DaveSwan] #5435409 05/21/20 08:22 PM
J
Jackson_Slugger Online Content
Online Content
J
It depends on the company. My 01' Duratec says 5W-20 on the cap and Mobil concurs, whereas Pennzoil and Valvoline say to use 5W-30. I doubt it makes much difference, in your case I'd consider using a full syn HM oil like Mobil 1 HM 5W-20 if you change it yourself...
Re: Change in weights and specs [Re: DaveSwan] #5435421 05/21/20 08:34 PM
Sonic Offline
Engine oil comes in grades. The term weight has nothing to do with oil.
Re: Change in weights and specs [Re: DaveSwan] #5435440 05/21/20 08:57 PM
MolaKule Offline
Global Moderator
Global Moderator
Here on BITOG we usually discuss the oil's viscosity or the ranges of viscosity with respect to the grade.
https://www.bobistheoilguy.com/viscosity-charts
What Castrol may recommend and what Ford may recommend may be two different things.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: Change in weights and specs [Re: DaveSwan] #5435524 05/21/20 11:17 PM
Chris142 Offline
I would try the 5w-30 to see of consumption lessens
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Change in weights and specs [Re: oldhp] #5435575 05/22/20 03:11 AM
demarpaint Offline
thumbsup
God Bless Our Troops
Re: Change in weights and specs [Re: DaveSwan] #5435631 05/22/20 07:15 AM
O
OilUzer Offline
O
op,
I would use 5W30.
The higher the weight the better ...
Heavier = more solid
iirc, in old days Chinese, Eastern European and Soviet Union used to add lead to the bottom of appliances to make them heavier as consumers preferred heavier stuff.
Yugo needed a little more lead to be successful. shocked2
Re: Change in weights and specs [Re: OilUzer] #5435642 05/22/20 07:37 AM
R
ragtoplvr Offline
R
Originally Posted by OilUzer
op,
I would use 5W30.
Seemed like when I was in college delivering appliances, every basement washing machine had concrete blocks bolted to the mechanism. Or was full of water. We had a shop vac but you can not suck out all the water. Then once you get it out you can drain it before you pack up the stairs, some houses did not have a sink to pour out the ship vac so you got to pack it up the stairs a few times to dump it.
Rod
Re: Change in weights and specs [Re: ragtoplvr] #5435651 05/22/20 07:53 AM
K
kschachn Offline
K
Yeah but those are counterweights that perform a valid function in the machine. You can observe this function by removing the blocks and then running a load of bath towels.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Change in weights and specs [Re: oldhp] #5435832 05/22/20 12:04 PM
dave1251 Offline
No.
https://www.car-engineer.com/the-different-driving-cycles/
Notice the significant driving differences.
don't use.
Re: Change in weights and specs [Re: DaveSwan] #5436831 05/23/20 04:28 PM
DaveSwan Offline OP
I went ahead and have changed to the 5w/30 Edge. We will see how it does. By the way, I grew up referring to oil weights
Re: Change in weights and specs [Re: DaveSwan] #5440122 05/27/20 12:29 PM
DavidJones Offline
It's all good Dave.
Some of these folks have nothing else to do.
My garage.....2012 Toyota Highlander (wife's), 2016 Ford 2.7EB F150(mine), 1969 Pontiac GTO, 2005 Double cab Tundra(son), 2015 Honda Accord EX(son).
