Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
29 registered members (Danno, CB900F2, bachman, Delta, ctechbob, Char Baby, 3 invisible), 749 guests, and 35 spiders.
Topics306,228
Posts5,288,638
Members71,608
engine oil and drive oil help #5435331 05/21/20 06:30 PM
T
theoctagon Offline OP
T
Hi all,
I work in a small engine shop and we are looking to go with 55 gallon drums for our engine oil and our hydro drive oil. For the engine oil we are going with a 10w40 or 15w40 and the drives require 15w50 or 20w50. I am trying to find the happy medium between quality and price when it comes to the bulk product. We have amsoil and mfg oil in containers to carry out or if it is requested.
What brand would you recommend that slides into that " just right" spot??? I am not for or against conventional, syn blend or fully synthetic though i figure any quality fully synthetic oil will be higher in price by a fair margin.
Thank you for your help.
Randy
Re: engine oil and drive oil help [Re: theoctagon] #5435334 05/21/20 06:37 PM
M
MParr Offline
M
You will be fine with 15w40 for engine oil and 20w50 for hydrostatic oil. You can get by with conventional oils.
Check with your local lube and fuel jobbers for prices.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: engine oil and drive oil help [Re: theoctagon] #5435428 05/21/20 08:43 PM
IMSA_Racing_Fan Offline
Re: engine oil and drive oil help [Re: theoctagon] #5435436 05/21/20 08:52 PM
T
tundraotto Offline
T
Hydrogear drives spec 20W-50.....some people succesfully use Mobil 1 15W-50. Factory fill is Castrol GTX 20W-50.....that 50W is the important part. I'm not sure I'd start improvising there, they are expensive and sensitive.
Engine wise - 15W-40 seems always solid for small engines as most is lawnmowers etc that dont get run when its too cold....
Generators - maybe 5W-40, but not sure I'd bother.
Re: engine oil and drive oil help [Re: theoctagon] #5435454 05/21/20 09:09 PM
T
T
Perfect thank you for the help so far. does anyone recommend any brand over another? Part of me was thinking shell rotella t 15w40 and then they have formula shell 20w50 but im not very familiar with the formula shell. thoughts?
I like the deal on that delvac too! maybe walmart can get me a barrel???
Re: engine oil and drive oil help [Re: tundraotto] #5435490 05/21/20 09:58 PM
T
T
Do you know why they use 20w50 in the drives? Seems so heavy... is it for the heat or did they just design em all with that oil in mind?
Re: engine oil and drive oil help [Re: theoctagon] #5435517 05/21/20 10:57 PM
T
tundraotto Offline
T
its for the heat, they run hot and the oil thins out a lot.....I bet if 60W was available - they would have gone for it.
Re: engine oil and drive oil help [Re: theoctagon] #5435519 05/21/20 11:02 PM
T
tundraotto Offline
T
Formula shell is a solid conventional 20W-50, just like all the others with the API certifications.
Rotella is also a solid oil, and can be had much more economically in 55gal form, but performance-wise - I am not sure if anyone could point out the difference between Rotella, Delvac, Delo or any other properly rated oil.....unless it was made in China with corn oil filler or something.
I was mainly thinking you could maybe get by with 2 drums of oil.....20W-50 of your choice and maybe 10W-30 of also your choice since in MN - although I'd pick 15W-40 HDEO for the engines just for price and availability.
Re: engine oil and drive oil help [Re: tundraotto] #5435889 05/22/20 01:18 PM
T
T
Sounds good i have a call in to see what it will cost. The 15w40 appears to be really easy to find the 20w50 maybe less so. Thank you for all your help.
Re: engine oil and drive oil help [Re: theoctagon] #5436071 05/22/20 05:25 PM
B
bchannell Offline
B
Hydrogear actually approves half a dozen or so oils for their hydro units. I had the official list at one time, but couldn't find it now. It does list 20w50 dino oil and Mobil 1 15w50, along with at least one other M1 oil, and I can't remember the rest.
Re: engine oil and drive oil help [Re: theoctagon] #5436091 05/22/20 06:04 PM
E
Eddie Offline
E
I would be concerned with additive separation and fall-out unless the 55 gal can be used up in >>2 years. The other option is to shake it-haha
2014 CX5 Touring 2.5L :-)
Re: engine oil and drive oil help [Re: bchannell] #5441394 05/28/20 11:08 PM
T
T
That is interesting i didnt know they had a list. I will give them a call tomorrow and see if i can get it.
Re: engine oil and drive oil help [Re: Eddie] #5441396 05/28/20 11:11 PM
T
T
At the rate we are currently going we should use up a barrel each year so hopefully that wont be an issue. I had not thought of that though.
Re: engine oil and drive oil help [Re: bchannell] #5441539 05/29/20 08:13 AM
J
jeepman3071 Offline
J
+1
I know Hydrogear specs 20w50 or synthetic 15w50. I would get 15w50 synthetic in bulk if you could, since I know Tuff Torq also changed their spec to a 15w50 synthetic for the heat, as their factory fill of 10w30 is known to break down over time. Castrol or Mobil 15w50 is what I put in Tuff Torque and Hydrogear units when they come through my shop.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
