Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
106 registered members (77GrandPrix, Astro14, Alfred_B, A_Harman, 2015_PSD, 2010Civic, 8 invisible), 2,229 guests, and 21 spiders.
Topics306,108
Posts5,286,590
Members71,586
Where to start? auto finish #5434830 05/21/20 07:12 AM
supton Offline OP
Gave in the other day and hosed off the truck, bit early for its annual wash but what they heck, been home for 2 months. I noticed it isn't getting as clean as it used to, I think things are growing or getting embedded in the paint. After it dried, I ran my hand over the paint and I can rub off white chalk--I'm guessing it's paint that is oxidizing, and quite badly. What should I try to do here? Get some sort of buffer? Or is there something I could do by hand, out in the sun? What product should I try? This is not a garaged vehicle, so it's basically been outside for 10 years (and has all the damage you'd expect after 10 NH winters).
I haven't done much other than wash a car in years... have some Turtle wax somewhere. At some point I got Mother's Clay Bar, that did remove some of what is growing. Honestly, I think she's a goner, needs a paint job to look good again, but it might be worth a bit of effort to bring some shine out.
Wife's car could use the same thing. At least that I could shine up in the garage, out of the sun. My car... ain't nothing helping that!
[Linked Image]
Edit: after some claybar effort. Much of the black is gone, but there is plenty of pitting from rocks.
[Linked Image]
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Where to start? auto finish [Re: supton] #5434888 05/21/20 08:31 AM
drtyler Offline
Many white Toyota's do not have a clearcoat. If you use a cleaner wax, it will perk the paint up nicely.
If you first use a polish or polishing compound, that will help more, but you would need to follow up with a wax or cleaner/wax for more shine and protection. Meguiars Ultimate Compound might be worth a try, but for less $$ the Turtle Wax liquid compounds work pretty good.
You can use these products by hand or with a buffer. You will get better results with a buffer, but try hand application first. The results may surprise you with a little elbow grease.
Re: Where to start? auto finish [Re: supton] #5434937 05/21/20 09:37 AM
supton Offline OP
Few years ago I got chewed out on a Tundra forum by those who insist that white does have a clearcoat... I'm not convinced mine does, it just doesn't have a sheen and there's spots where it looks like it was reworked. Doesn't matter, as a white truck everyone calls it a plumber's truck. To which I don't care, it's just a tool to me.
Meguiars Ultimate is only $10 or so at Walmart. That's cheap enough to try out.
Re: Where to start? auto finish [Re: supton] #5435001 05/21/20 10:28 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
If it doesnt have a clear, Meguiars #7 might ultimately help. Look up Mike Phillips how to over on autogeek. Even if it does have a clear, that process, using the terry towel to help gently remove the top level of oxidation might be good. Youll likely need some harder work on it though.
Id wash it well, probably use a pressure washer. Maybe put it through an automatic no touch carwash first, because some of those chemicals may be stronger. There is a purple power degreaser that some recommend as well, might be worth it here.
Id want to run iron X on this to get any embedded particulates. Id probably then try the glaze personally, but others might recommed to clay and light polish at least first.
Re: Where to start? auto finish [Re: supton] #5435010 05/21/20 10:39 AM
The Critic Online Crying
Online Crying
As first steps I would use Tar and Iron Removers, followed by Clay. After those steps, you can try the #7 that JHZR2 mentioned, followed by machine compounding and polishing (if you desire).
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Where to start? auto finish [Re: supton] #5435028 05/21/20 11:04 AM
supton Offline OP
Iron X to remove iron, something to remove tar, then clay, then maybe #7? Could try that. Will look into sourcing those things.
Re: Where to start? auto finish [Re: supton] #5435344 05/21/20 07:01 PM
G
gofast182 Offline
G
Sounds like you don't want your paint to fail. Maybe you should try making some regular effort to take care of it; annual washes do not constitute effort. To *attempt* to save it you'll want to follow what The Critic said. To keep it that way put just a little effort in, it will go a long way.
2006 S2000 - Berlina Black - PU 10w30, PCX-004
2020 M340i xDrive - Portimao Blue - Dlr Fill, 114...898
2019 X5 xDrive 40i - Mineral White - Dlr Fill, 114...898
Re: Where to start? auto finish [Re: supton] #5435388 05/21/20 07:58 PM
supton Offline OP
Braved the crowds and got some Meguiars Cleaning Wax and towels. After about the third application I started getting a shine on the hood. Few more attempts and it might start to look decent. Afterwards I realized I should probably use the foam applicator thing for applying, but I kinda wanted something more aggressive to lift anything off the paint.
I was surprised, it did lift some dirt, and even some rust staining around a chip.
What would be good to strip this off? I'm finding rock chips here and there, some of which will need addressing. Some IPA?
This is the first vehicle that I would like to trade out of with value; I have been starting to think about keeping it longer, but usually I get rid of after 10 years and 250k, and they're just not worth anything by then. A calculated estimation on my part says to not sweat the paint. I neglected to take this into account when I bought this vehicle, but I'm coming up on it's 10yr/100k calculation (different than prior vehicles), and I'm realizing I overlooked this aspect--a 13 year old truck with 180k is probably going to be worth more than a 10 year old econobox with 250k.
With that said, this single stage white paint chips if you look at it sideways.
Re: Where to start? auto finish [Re: supton] #5435612 05/22/20 06:39 AM
Delta Offline
My Tacoma is the same single stage white, and let me tell you it's a total bear to try and keep clean and shiny. Unfortunately at this point doing something by hand is not gonna do much and just wear you out for little results. If you're serious in getting it up to par, you'll need at minimum a DA type polisher and a polish/compound. You don't need a paint job. When I bought my truck it was so neglected and had no shine at all. Took about 6-7 hours, light compound, and multiple pads as they were getting loaded up with dead, spent paint. I already had a product laying around, Poorboy's SSR1 that I ordered online years ago, but parts stores have options. Autozone carries Griots Garage Complete Compound that would work really well for a one-step so to say. I guess you could do this by hand, but for an extra $100-$150 will save your body tremendously. This should also get rid of the junk in your paint. After that you need to protect your work. You can try any one of the easy to use Hybrid Ceramic waxes, but if you don't mine ordering online Collinite 845 works very well and holds up to the harsh winter conditions you see. I've used both, and the Collinite has the edge IMO. Like I said, you don't need a paint job, just a day or two worth of work, and I guess a little bit of money buying a DA, compound/polish, and sealant of your choice.
'17 VW GTI 2.0T - 6MT - 21K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 26K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 141K - RGT 5w30
Re: Where to start? auto finish [Re: supton] #5435617 05/22/20 06:53 AM
supton Offline OP
I still think the leading edge of the hood is kaput, but I'm no expert.
I started looking into the DA, might see if I can pick up a cheap one today, as I tend to work best when it's hot on my mind. Some reading indicates that while it needs to go one "thick" the pad would need to be changed often, so I'd need a DA and a stack of pads to go with it. It was quite a bit of work to get uneven results last night, but it did do something, which I was content with.
Re: Where to start? auto finish [Re: supton] #5435626 05/22/20 07:06 AM
Delta Offline
Grab an older microfiber towel (or even a clean old dish towel) and while the machine is off hold down the towel hard, turn on the machine at a low speed while holding the towel on there. It'll take off alot of the gunk and let you use a couple less pads. Do this occasionally. I went through 4 on the Tacoma, so you'll likely need 5 if not cleaning them in between.
Also you're going to hate yourself if you use too much product, that's one of the biggest beginner mistakes. Prime the pad slightly wet with product and just use 5-6 pea size dots afterwards. Too much product and it won't work as intended. That and make a mess...
Re: Where to start? auto finish [Re: supton] #5435629 05/22/20 07:13 AM
supton Offline OP
Re: Where to start? auto finish [Re: supton] #5435635 05/22/20 07:19 AM
Delta Offline
At this point your truck is probably beyond an AIO, but it wouldn't hurt to try. It might get the results you're looking for.
That post is definitely intriguing to me; I've never used that much product "compounding" even going oldschool wool and rotary. But different strokes for different folks. I might be doing it completely wrong, but I've always gotten good results. That and I work in smaller sections. Another case of your mileage may vary...
Re: Where to start? auto finish [Re: supton] #5435641 05/22/20 07:34 AM
supton Offline OP
YMMV, as they always say.
I just want to bring it 2 steps forward without going overboard. If nothing else... can always redo!
Just running my hand over it last night, compared to the other panels (only did hood and front fenders)--there was quite a difference. Looking at it this morning, definitely not polished, rather dull looking actually. But all the scratches and chips are popping out quite nicely now! The camera certainly hides the worst.
[Linked Image]
[Linked Image]
[Linked Image]
Re: Where to start? auto finish [Re: supton] #5435653 05/22/20 07:55 AM
supton Offline OP
Gave in and took a look at kits. My head spins with the options...
https://www.autogeek.net/pocapobuki.html
