Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
76 registered members (alcyon, Ag76, AlaskaMike, 2009Caraman, alchargo, 7 invisible), 1,631 guests, and 69 spiders.
Topics306,269
Posts5,289,352
Members71,616
Switch 5w30 to heavier? 233k #5434729 05/21/20 01:39 AM
M
mendozer Offline OP
M
Wife's 03 Subaru has 233k and while me engine wear levels are fine (Blackstone testing 1x/year) I am noticing oil consumption, not leaking. One change I had to hadd .5 qt, another 1.5 qts. I run 5w30 full synthetic. Been thinking of 10w-30, my mechanic buddy said he switched to 25w-50 for his old honda CRX that sucked up oil. seems a bit drastic, but he knows more about cars than I. I know it's an old timer thought to use heavier weight oil to get better sealing, but does that compromise anything else? The tech at Blackstone even said it may quiet lifter noise and be overall smoother.
I also have noticed vibration lately, but don't think that's correlated to the oil levels.
Re: Switch 5w30 to heavier? 233k [Re: mendozer] #5434733 05/21/20 01:54 AM
B
blufeb95 Online Content
Online Content
B
10w30 isn't any heavier than 5w30 at operating temp, it tends to be less volatile and more shear stable at least when comparing oils from the same product line. but otherwise will perform pretty much identical. What kind of OCI are you running, losing a quart or so on a 18 year old high mileage engine over the course of an oil change sounds pretty normal to me.
Re: Switch 5w30 to heavier? 233k [Re: mendozer] #5434739 05/21/20 02:25 AM
Char Baby Offline
I agree. At what mileage are you having to add/top off the oil?
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Switch 5w30 to heavier? 233k [Re: mendozer] #5434749 05/21/20 03:09 AM
IMSA_Racing_Fan Offline
A flat opposed 4 cyl may be more prone to oil ring seepage but I defer to any Porsche/Subaru gurus. At that mileage going to a 10W40 high mileage may be a good experiment since it is warming to summer.
Check and change your spark plugs. If becoming oily your O2 sensors and catalytic converter is at risk.
Re: Switch 5w30 to heavier? 233k [Re: mendozer] #5434832 05/21/20 07:16 AM
K
krismoriah72 Offline
K
I have owned three Foresters.
Have you ruled out head gaskets? is there oil in your coolant?
If not then suspect valve seals.
If you plan on keeping it up to 400K get the head gaskets done and go thru the heads and install new valve seals.
If you just want to try the 'different oil will fix it' Give Maxlife 10w40 a run
I
Re: Switch 5w30 to heavier? 233k [Re: mendozer] #5434854 05/21/20 07:42 AM
K
ka9mnx Offline
K
When was the last time the PCV was checked/changed?
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Switch 5w30 to heavier? 233k [Re: mendozer] #5435047 05/21/20 11:44 AM
T
tundraotto Online Content
Online Content
T
Changing from 5W-30 to 10W-30 most likely wont change anything as the only thing different is the Winter grade....Still a 30 grade at operating temp....
I would consider a 5W-40 - don't a lot of Subaru owners love using that in their engines anyway?
Re: Switch 5w30 to heavier? 233k [Re: mendozer] #5435145 05/21/20 02:11 PM
H
HyundaiAbuser Offline
H
Not a Subaru but for my Tiburon I run a 40wt in the summer and didn’t notice it burn any oil but when I went to a 30wt for the winter it burned a quart over 1k so stepping up a grade could help and it’s worth a shot going into warmer weather.
03 Hyundai Tiburon:
PP High Mileage 5w30
Redline MT85
94 Mazda B4000
Supertech 10w40 High Mileage (RIP)
Valvoline Maxlife
Re: Switch 5w30 to heavier? 233k [Re: mendozer] #5435169 05/21/20 02:48 PM
demarpaint Offline
As mentioned, moving from a 5W30 to a 10W30, you're still a 30 grade at operating temperatures. If there are no oil leaks and the PCV is working properly, I would try adding something towards the end of an OCI like, Kreen, Rislone, or MMO to clean up the ring packs. Run it for 1,000 miles or so and keep an eye on the oil level. Drain the sump and repeat at the last 1,000-1,500 miles of the following OCI. If that doesn't work you could move up to a 0W40 or a 5W40 oil.
God Bless Our Troops
Re: Switch 5w30 to heavier? 233k [Re: demarpaint] #5435247 05/21/20 04:28 PM
B
bbhero Online Content
Online Content
B
This is good advice in my opinion ^^^^^^^^^^^^^
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Wix Gold 57356
"Treat your family like your friends and treat your friends like your family."
Re: Switch 5w30 to heavier? 233k [Re: mendozer] #5435252 05/21/20 04:33 PM
A
aquariuscsm Offline
A
Would the thicker 10W base oil help any?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
