Forums Migration
Please read this thread
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Swimming Pool Chlorination
by Al - 07/08/20 02:30 PM
Purolator Boss
by RazorsEdge - 07/08/20 02:01 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
63 registered members (BlakeB, Alex38, AITG, blufeb95, alcyon, 379KITTY, 4 invisible), 1,117 guests, and 38 spiders.
Topics307,625
Posts5,314,452
Members71,888
CVT idling in Neutral - bad? #5434653 05/20/20 09:59 PM
cos Offline OP
I have a 2020 Accord and was wondering if it would damage the CVT trans to leave it neutral when stopped at a light. Why? I don't like to hold brake pads against hot rotors.
I know, I can throw it in park but was just wondering about neutral.
'15 Cadillac SRX
- Castrol Magnatec 5W30
- Valvoline Maxlife ATF
Re: CVT idling in Neutral - bad? [Re: cos] #5434656 05/20/20 10:03 PM
clinebarger Online Content
Online Content
Park & Neutral are usually the same thing (Hydraulically) besides the Parking Pawl being engaged in Park which is mechanical.
2001 Chevy Camaro L92/4L80E
Re: CVT idling in Neutral - bad? [Re: cos] #5434663 05/20/20 10:18 PM
slacktide_bitog Online Content
Online Content
I don't think you will have any problems doing this, but it does seem pointless. Pads and rotors are relatively easy and inexpensive to replace. Also, they don't get that hot in that kind of driving, not hot enough to burn in the rotors at least
Maybe you should've gotten the manual drive
The Accord is the last midsize sedan standing that still has a manual transmission available (Mazda dropped theirs last year)
I have heard of some automatic transmissions shifting to neutral at idle. It's possible a CVT can do this, too.
Re: CVT idling in Neutral - bad? [Re: cos] #5434681 05/20/20 10:59 PM
MolaKule Offline
Global Moderator
Global Moderator
I don't see any reason to do so as your car's computer adjusts the fuel ratio for in-gear idling and I think there will be more engagement wear.
"So many shows out there dumb-down the country. It's so admirable to be part of a show that wants people to think." (David Krumholtz 'Charlie Epps' of NUMB3RS)
Re: CVT idling in Neutral - bad? [Re: cos] #5434691 05/20/20 11:20 PM
V
Vladiator Offline
V
This VIDEO may not be a direct answer to your question, but does touch on the topic and provides a few other CVT tips along the way.
2000 Honda CR-V 2.0L I4, RTAWD and a 5-speed manual. 215k miles.
2010 Volvo XC70, 3.2L I6 AWD. 255k miles.
2006 Toyota Camry 3.0L V6 FWD 200K miles.
2000 Lexus GS300 3.0L I6 RWD 365k miles.
Re: CVT idling in Neutral - bad? [Re: Vladiator] #5434703 05/21/20 12:01 AM
J
JimPghPA Offline
J
s
The video link did not work for me.
Would not the area where the slip was occurring during idle be the torque converter, and torque converters can handle idling with no wear.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: CVT idling in Neutral - bad? [Re: cos] #5434715 05/21/20 12:32 AM
2
2009Caraman Offline
2
Haha. Brakes are meant to be applied at lights in case you get rear-ended. You really want to t-bone someone cuz your brake pads don't like getting hot?
Re: CVT idling in Neutral - bad? [Re: cos] #5434765 05/21/20 05:16 AM
gathermewool Offline
How hot are your brakes, man!? If I have to come to a sudden stop and stay stopped, I try to leave a bit of room to creep forward, so the pads don't stay at the same spot on the rotor.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: CVT idling in Neutral - bad? [Re: cos] #5434818 05/21/20 06:56 AM
T
tcp71 Offline
T
Unless you've just completed a multi-mile downhill run while riding your brakes, this is a non-issue. If you can't smell them, they're not hot enough to cause issues.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: CVT idling in Neutral - bad? [Re: cos] #5434874 05/21/20 08:07 AM
A
ARCOgraphite Offline
A
I wouldnt do it unless its a LONG light and your shutting it off.
I used to have a 45 second light at work and I would shut the car off.
As for brake material transfer causing pulsation - that's mainly a MYTH for commuting.
It would likely be more of a hill descent issue on trucks trailering with red or yellow hot rotors.
Plus brake pads are $30 and axle, rotors @ $30 >70 each;
transmission clutches would be a few thousand more than that.
Plus the engine likes to have a viscous dampened load when running which a converter provides.
Some CVT don't have converters - my Wife's Subaru Impreza CVT has a mini-converter that locks immediately in first gear once it gets moving a bit.(5mph)
I don't know why most planetary gear units didn't do that decades ago. I guess the lockup clutches were weak and torque limited.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: CVT idling in Neutral - bad? [Re: cos] #5436167 05/22/20 07:47 PM
L
lexus114 Offline
L
Gosh here in GA where I live now. Some of the traffic lights I encounter every day are three freaking minutes long! It’s ridiculous 🙄
2020 Nissan Kicks SR
