Toyota 500(k)
Wednesday, May 20, 2020 - Darlington Raceway
6:00pm/et
Green flag: 6:23pm/et
Laps: 228 - Stages: 60/125/228
TV: FS1 - Radio: MRN, Sirius XM NASCAR
Cars to the rear: #78-McLeod (multiple inspection failures) #32-LaJoie (multiple inspection failures), #27-Gaulding (driver change), #77-Yeley (driver change)
Starting lineup process:
Positions 1-20: Invert the top 20 from the May 17th race at Darlington
Positions 21-40: In finishing order from the May 17th race at Darlington (not inverted), followed by new entries
Pit selection process:
Order based on finishing position from the May 17th race at Darlington, followed by new entries in order of points. Pit stalls will be picked in advance and the pit boxes will be in the stalls when the teams arrive
Tire:
Goodyear Eagle Speedway Radials
Set limits:
Cup - May 17: 12 sets for the race;
Cup - May 20: 9 sets for the race;
Xfinity: 6 sets for the race
Tire Codes:
Left-side - D-4928;
Right-side - D-4930
Tire Circumference:
Left-side - 2,225 mm (87.60 in.);
Right-side - 2,248 mm (88.50 in.)
Minimum Recommended Inflation:
Left Front - 18 psi; Left Rear - 18 psi;
Right Front - 48 psi; Right Rear - 44 psi
6:00pm/et
Tire:
Set limits:
Tire Codes:
Left-side - D-4928;
Right-side - D-4930
Tire Circumference:
